03-01-2018, 10:37 | #1 (permalink) |
No Life Poster Join Date: Jul 2005 Location: Georgia GE
Member: 162473 Status: Offline Sonork: Not have Thanks Meter: 592 | Error when close or disconnect Octoplus Software [Answered] Code: Welcome to Octoplus/Octopus Box LG Software version 2.8.0 -------------------------------------------------------------------------------- Checking data...OK Platform: LG Infineon Connection mode: Modem Selected model: MS769 Initializing device...OK Please, power phone ON, connect P990 cable (with 56k resistor), type 3845#*769#, go to "Port Setting", select "CP Reset" (or "CP Image download") and click "OK"...OK Sending preloader...OK Sending loader...OK Reading info...OK IMEI: 013647-00-620809-7 Bluetooth address: BC:F5:AC:70:A9:D7 Wi-Fi MAC address: 8C:3A:E3:41:9E:34 Locks: Service Provider Lock MCC=310 (USA) MNC=160 Unlocking... Reading EEPROM...OK Backup saved to "MS769_013647006208097_01-03-2018_13-32-46.EEP" Writing EEPROM...OK Phone successfully unlocked! Cannot terminate an externally created thread Cannot terminate an externally created thread Please fix it. For close need manualy end process from Windows Task Manager. Last edited by Octopus box; 03-01-2018 at 11:11. |
03-01-2018, 11:10 | #2 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,411 | Hello. Was this error also present on previous Software versions or only on 2.8.0? What OS do You use exactly on your PC? |
03-01-2018, 11:30 | #3 (permalink) |
Member: 162473 Status: Offline Sonork: Not have Thanks Meter: 592 | Code: 1/3/2018 18:13:54 > -------------------------------------------------------------------------------- 1/3/2018 18:13:54 > Checking data...1/3/2018 18:13:55 > OK 1/3/2018 18:13:55 > Platform: LG Qualcomm 1/3/2018 18:13:55 > Selected port: COM1 1/3/2018 18:13:55 > Selected model: LS676 1/3/2018 18:13:55 > Reading info... 1/3/2018 18:14:08 > Initializing ADB...1/3/2018 18:14:09 > OK 1/3/2018 18:14:09 > Waiting for phone... 1/3/2018 18:14:09 > Please, reconnect phone, enable USB debugging, and try again. 1/3/2018 18:14:09 > To enable USB debugging, please perform the following steps: 1. Disconnect cable 2. Install LG Android ADB drivers 3. Go to "Settings" -> "About phone" -> "Software information" 4. Click on Build number 5 times 5. Enable "Settings" -> "Developer options" -> "USB debugging" option 6. Connect the cable and check, whether ADB interface has appeared in PC Device Manager. 1/3/2018 18:14:15 > Cannot terminate an externally created thread 1/3/2018 18:14:31 > Cannot terminate an externally created thread 1/3/2018 18:14:35 > Cannot terminate an externally created thread 1/3/2018 18:14:39 > Performed by 2.7.8 Software version. Do not laugh It works very well |
The Following User Says Thank You to IkaMazini For This Useful Post: |
03-01-2018, 12:31 | #4 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,411 | OK, we will check, where can be the problem and try to fix in future Software undates. |
