01-14-2015, 18:22 | #1 (permalink) |
Freak Poster Join Date: Feb 2014 Location: Greece
Member: 2130293 Status: Offline Sonork: 100.1637594 Thanks Meter: 68 | f100s error after flash finalizing failed plz help Searching Diagnostic Ports...OK -------------------------------------------------------------------------------- Checking data...OK Platform: LG Qualcomm Selected port: COM258 Selected model: F100S Reading info...OK Mode: Emergency Model ID: 8660-AAABQNBYA-34730 SW version: F100S-MDM9200-V40d-JUN-11-2013-X Product ID: SM04S12041900152000000 IMEI: 352217-05-316775-9 Opening "LGF100SAT-00-V40d-450-05-JUN-11-2013+0.oct"...OK Initializing device...OK Initializing flash...OK Formating USERDATA...OK Formating GROW...OK Writing MODEM...OK Writing SBL1...OK Writing SBL2...OK Writing EXT...OK Writing RPM...OK Writing SBL3...OK Writing ABOOT...OK Writing BOOT...OK Writing TZ...OK Writing PERSIST...OK Writing RECOVERY...OK Writing MDM...OK Writing TOMBSTONES...OK Writing SYSTEM...OK Writing GROW...OK Finalizing...Failed! Searching Diagnostic Ports...OK -------------------------------------------------------------------------------- Checking data...OK Platform: LG Qualcomm Selected port: COM258 Selected model: F100S Reading info...OK Mode: Emergency Model ID: 8660-AAABQNBYA-34730 SW version: Opening "LGF100SAT-00-V40d-450-05-JUN-11-2013+0.oct"...OK Initializing device...OK Initializing flash...OK Formating USERDATA...OK Formating GROW...OK Writing MODEM...OK Writing SBL1...OK Writing SBL2...OK Writing EXT...OK Writing RPM...OK Writing SBL3...OK Writing ABOOT...OK Writing BOOT...OK Writing TZ...OK Writing PERSIST...OK Writing RECOVERY...OK Writing MDM...OK Writing TOMBSTONES...OK Writing SYSTEM...OK Writing GROW...OK Finalizing...Failed! Last edited by Octopus box; 01-15-2015 at 07:39. |
01-14-2015, 19:04 | #4 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,411 | Please install latest Software version and repeat "Write Firmware" operation. |
01-15-2015, 03:47 | #5 (permalink) | |
Freak Poster Join Date: Apr 2013 Location: Đà Nẵng - Việ Age: 44
Member: 1911593 Status: Offline Sonork: 100.1645151 Thanks Meter: 130 | Quote:
You can try the following : 1 You remove batter 2 Press hold Vol (+) and (-) and plug usb cap ( phone in download mode ) 3 Run Octoplus LG Tool and flash FW. | |
01-15-2015, 09:17 | #6 (permalink) | |
Member: 2130293 Status: Offline Sonork: 100.1637594 Thanks Meter: 68 | Quote:
01-15-2015, 09:27 | #8 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,411 | Try to write firmware on another PC. Try to find another firmware and write it. If the problem is the same - check phone's HW. |
01-15-2015, 11:23 | #9 (permalink) |
Member: 1911593 Status: Offline Sonork: 100.1645151 Thanks Meter: 130 | You can try the following : 1 You remove battery (with F100S you don't use battery) 2 Press hold Vol (+) and (-) and plug usb cap ( phone in download mode ) 3 Run Octoplus LG Tool and flash FW. I usually do so when up FW |
