06-26-2014, 10:16 | #1 (permalink) |
No Life Poster Join Date: Dec 2005 Location: PAKISTAN Age: 35
Member: 210880 Status: Offline Sonork: 100.1577765 Thanks Meter: 151 | f200s flashing error -------------------------------------------------------------------------------- Platform: LG Qualcomm Selected port: COM33 Selected model: F200S Reading info...OK Mode: Emergency Model ID: BS/VU2SK/1 (F200S) SW version: LGF200SAT-00-V20g-SKT-KR-DEC-19-2013+0 Product ID: HD52S121024003686 IMEI: 353962-05-078320-2 Opening "LGF200SAT-00-V20f-SKT-KR-NOV-21-2013+0.oct"...OK Initializing flash...OK Reading partition...OK Formating userdata...OK Writing Խgskʡүۺ...Failed! File reading error! Platform: LG Qualcomm Selected port: COM33 Selected model: F200S Reading info...OK Mode: Emergency Model ID: BS/VU2SK/1 (F200S) SW version: LGF200SAT-00-V20g-SKT-KR-DEC-19-2013+0 Product ID: HD52S121024003686 IMEI: 353962-05-078320-2 Opening "LGF200SAT-00-V20f-SKT-KR-NOV-21-2013+0.oct"...OK Initializing flash...OK Reading partition...OK Formating userdata...OK Writing Խgskʡүۺ...Failed! File reading error! Connecting to server octopus-server0.no-ip.biz:82...OK Authorizing...OK i download this file from server 3 times but same error i think file corrupt on server |
06-26-2014, 10:25 | #2 (permalink) | |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,411 | Hello. As I see, the problem is with frimware: Quote:
06-26-2014, 12:15 | #5 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,411 | We have re-uploaded firmware into the Support Area. Please, try to redownload it, write again and post here the result. Also, here is alternative link: https://mega.co.nz/#!zNE3WAZA!Ad-YsL...r9AIigmy-ZBbrk. |
06-26-2014, 16:31 | #7 (permalink) |
Member: 210880 Status: Offline Sonork: 100.1577765 Thanks Meter: 151 | Model ID: BS/VU2SK/1 (F200S) SW version: LGF200SAT-00-V20g-SKT-KR-DEC-19-2013+0 Product ID: HD52S121024003686 IMEI: 353962-05-078320-2 Opening "LGF200SAT-00-V20f-SKT-KR-NOV-21-2013+0.oct"...OK Initializing flash...OK Reading partition...OK Writing Ria—wŠ”N eŽ…躝...Failed! |
06-26-2014, 20:06 | #8 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,411 | We have uplaoded another firmware for You. Please download this firmware and try to re-flash the phone with it. https://mega.co.nz/#!zcVi1SyC!t8CsXw...BuFU4ZJ97hZEKc |
07-22-2014, 10:36 | #9 (permalink) |
No Life Poster Join Date: Jul 2005 Location: philippine
Member: 159757 Status: Offline Thanks Meter: 461 | same problem here Platform: LG Qualcomm Selected port: COM71 Selected model: F200S Reading info...OK Mode: Emergency Model ID: BS/VU2SK/1 (F200S) SW version: LGF200SAT-00-V30d-SKT-KR-JUN-02-2014+0 Product ID: HD52S120920000908 IMEI: 353962-05-039268-1 Opening "LGF200SAT-00-V20f-SKT-KR-NOV-21-2013+0_2.oct"...OK Initializing flash...OK Reading partition...OK Formating userdata...OK Writing z/=%ˣ*ҨuO%>q?ǻU...Failed! File reading error! |
07-22-2014, 10:39 | #10 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,411 | Have You downloaded the firmware by the link above? Also, as I see, You tried to downgrade phone's firmware - there V30 firmware version and You try to write V20. |
07-23-2014, 11:19 | #11 (permalink) | |
Member: 159757 Status: Offline Thanks Meter: 461 | Quote:
Selected port: COM5 Selected model: F200S Reading info...OK Mode: Emergency Model ID: BS/VU2SK/1 (F200S) SW version: LGF200SAT-00-V30d-SKT-KR-JUN-02-2014+0 Product ID: HD52S120920000908 IMEI: 353962-05-039268-1 Opening "F200S30d.oct"...OK Initializing flash...OK Reading partition...OK Formating userdata...OK Writing modem...Failed! Read Failed! convert a tot to oct but fail phone still HANG on LG LOGO | |
07-23-2014, 11:28 | #12 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,411 | Try to write firmware on another PC, connect the phone directly to PC motherboard USB port, don't use any USB hubs or PCI USB cards, this is important. If the problem is the same - check phone's HW. |
07-24-2014, 22:15 | #13 (permalink) | |
No Life Poster Join Date: Mar 2014 Location: Rawalpindi, Pakistan Age: 35
Member: 2157308 Status: Offline Sonork: 100.1655088 Thanks Meter: 677 | Quote:
1-go to Firmware download mode by pressing volum up+home and inset usb its different from download mode no vol up + vol down and usb cable. Then follow the thread given below install adb files follow the instructions provided there and type "adb reboot recovey"il in cmd and your phone will be hardreset. http://forum.xda-developers.com/show....php?t=1853159 Good luck Br Babar Abbasi | |
The Following User Says Thank You to androidlabs For This Useful Post: |
