01-10-2017, 15:41 | #1 (permalink) |
Freak Poster Join Date: Jan 2004 Location: hong kong Age: 56
Member: 51463 Status: Offline Sonork: 100.1596671 Thanks Meter: 29 | New version LG H961N FRP remove Help Authorizing...OK -------------------------------------------------------------------------------- Checking data...OK Platform: LG Qualcomm Selected port: COM33 Selected model: H961N Please, put the phone into download mode manually (Power phone OFF, press and hold "Vol+" button and connect the cable (or P990 cable)). Reading info... Model ID: LG-H961N IMEI: 353829-07-212411-3 Android version: 6.0 Battery level: 24% SW Version: H961N20t Mode: Emergency Initializing flash...OK SW version: LGH961NAT-00-V20t-HKG-XX-DEC-15-2016+0 Android version: 6.0 LAF Version: 1.1 Product ID: YE02S160210000467 IMEI: 353829-07-212411-3 Target operator: GLOBAL Hardware: rev_10 Reading partitions...OK Resetting FRP Lock...Failed! .................................................. .Failed for this version LAF Error: 80000121. Reset FRP operation is currently not supported for your phone's firmware. Performed by 2.5.5 Software version. ..........................................Please Help ...................... Last edited by Octopus box; 01-10-2017 at 15:53. |
The Following User Says Thank You to kin88 For This Useful Post: |
01-10-2017, 15:59 | #2 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,411 | Hello. Please, download and install test Software version form the Support Area (LG/TEST SOFTWARE/), then repeat operation which You need again, post here full Software log. Last edited by Octopus box; 01-10-2017 at 16:41. |
01-12-2017, 14:40 | #4 (permalink) |
Member: 51463 Status: Offline Sonork: 100.1596671 Thanks Meter: 29 | H961n Welcome to Octoplus/Octopus Box LG Software version 2.5.6.3 -------------------------------------------------------------------------------- Checking data...OK Platform: LG Qualcomm Selected port: COM33 Selected model: H961N Please, put the phone into download mode manually (Power phone OFF, press and hold "Vol+" button and connect the cable (or P999 cable)). Reading info... Model ID: LG-H961N IMEI: 353829-07-212411-3 Android version: 6.0 Battery level: 98% SW Version: H961N20t Mode: Emergency Initializing flash...OK SW version: LGH961NAT-00-V20t-HKG-XX-DEC-15-2016+0 Android version: 6.0 LAF Version: 1.1 Product ID: YE02S160210000467 IMEI: 353829-07-212411-3 Target operator: GLOBAL Hardware: rev_10 Reading partitions...OK Resetting FRP Lock...Failed! LAF Error: 80000121. Reset FRP operation is currently not supported for your phone's firmware. Reading partitions...OK Resetting FRP Lock... Resetting FRP lock successfully completed! Performed by 2.5.6.3 Software version. But phone still have FRP lock , can help ?????????????? |
01-12-2017, 14:52 | #5 (permalink) |
Member: 51463 Status: Offline Sonork: 100.1596671 Thanks Meter: 29 | H961n 20t this version very high and very strange , i use some solution and want install quickshotcut But Unknown sources is inhibit cannot check , can help ???????? |
01-12-2017, 14:52 | #6 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,411 | We will research where can be the problem and try to find solution for You. |
