09-19-2016, 10:39 | #1 (permalink) |
Freak Poster Join Date: May 2007 Location: cebu city philippines
Member: 505947 Status: Offline Sonork: 100.1658758 Thanks Meter: 8 | F600L FRP [Solved] after reset frp lock lg-f600l now only lg logo blinking Welcome to Octoplus/Octopus Box LG Software version 2.4.3 -------------------------------------------------------------------------------- Checking data...OK Platform: LG Qualcomm Selected port: COM296 Selected model: F600L Please, put the phone into download mode manually (Power phone OFF, press and hold "Vol+" button and connect the cable (or P990 cable)). Reading info... Model ID: LG-F600L IMEI: 353584-07-023032-7 Android version: 5.1.1 Battery level: 46% SW Version: F600L10s Mode: Emergency Initializing flash...OK SW version: LGF600LAT-00-V10s-LGU-KR-DEC-23-2015+0 Android version: 5.1.1 LAF Version: 1.2 Product ID: SM03S150925000804 IMEI: 353584-07-02 Target operator: LGU Hardware: rev_11 Reading partitions...OK Resetting FRP Lock...OK Resetting screen lock successfully completed! Performed by 2.4.3 software version. Last edited by Octopus box; 09-20-2016 at 11:00. |
09-19-2016, 14:10 | #2 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,413 | Hello. Unfortunately, firmwares for this phone aren't available, we will try to find them and add to the Support Area. Please, try to reflash phone with LGF600LAT-00-V10s-LGU-KR-DEC-23-2015+0 firmware version or higher, You can convert firmware via Octoplus LG Tool( Firwmare convertor button in Software) into *.oct file format that You can reflash the phone. |
09-20-2016, 10:41 | #4 (permalink) |
Member: 505947 Status: Offline Sonork: 100.1658758 Thanks Meter: 8 | thank you taem octopus after flash my lg-f600l now alive then reset frp again now my phone back to normal Welcome to Octoplus/Octopus Box LG Software version 2.4.3 -------------------------------------------------------------------------------- Checking data...OK Platform: LG Qualcomm Selected port: COM39 Selected model: F600L Reading info... Mode: Emergency Initializing flash...OK SW version: LGF600LAT-00-V10s-LGU-KR-DEC-23-2015+0 Android version: 5.1.1 LAF Version: 1.2 Product ID: SM03S150925000804 IMEI: 353584-07-023032-7 Target operator: LGU Hardware: rev_11 Writing phone firmware without real necessity is at your own risk. Downgrade may lead to phone damage! Please, make sure the phone's battery is fully charged. Disconnect all other devices from the computer (including phones, modems, etc.) and close all other running programs. To avoid errors in the flashing process, use a clean PC (without any installed drivers for other Qualcomm-based devices). You should not run any other programs or attach new devices to your computer during the flashing! Opening "F600L_V20e_00_0216.oct"...OK Setting options...OK Reading partitions...OK Formating USERDATA...OK Writing PrimaryGPT...OK Writing modem...OK Writing pmic...OK Writing sbl1...OK Writing tz...OK Writing sdi...OK Writing hyp...OK Writing rpm...OK Writing aboot...OK Writing sbl1bak...OK Writing pmicbak...OK Writing hypbak...OK Writing tzbak...OK Writing rpmbak...OK Writing abootbak...OK Writing sdibak...OK Writing persist...OK Writing sec...OK Writing laf...OK Writing boot...OK Writing recovery...OK Writing raw_resources...OK Writing raw_resourcesbak...OK Writing factory...OK Writing system...OK Writing BackupGPT...OK Reading partitions...OK Formating RCT...OK Formating MPT...OK Finalizing...OK Writing firmware done! Performed by 2.4.3 software version. -------------------------------------------------------------------------------- Checking data...OK Platform: LG Qualcomm Selected port: COM39 Selected model: F600L Please, put the phone into download mode manually (Power phone OFF, press and hold "Vol+" button and connect the cable (or P990 cable)). Reading info... Model ID: LG-F600L IMEI: 353584-07-023032-7 Android version: 6.0 Battery level: 36% SW Version: F600L20e Mode: Emergency Initializing flash...OK SW version: LGF600LAT-00-V20e-LGU-KR-FEB-16-2016+0 Android version: 6.0 LAF Version: 1.1 Product ID: SM03S150925000804 IMEI: 353584-07-023032-7 Target operator: LGU Hardware: rev_11 Reading partitions...OK Resetting FRP Lock...OK Resetting screen lock successfully completed! Performed by 2.4.3 software version. |
