09-20-2015, 16:12 | #1 (permalink) |
Freak Poster Join Date: Sep 2015
Member: 2452660 Status: Offline Thanks Meter: 22 | Failed to flash F200K -------------------------------------------------------------------------------- Checking data...OK Platform: LG Qualcomm Selected port: COM41 Selected model: F200K Reading info... Model ID: LG-F200K IMEI: 353964-05-072924-3 Android version: 4.4.2 Battery level: 82% Mode: Emergency Model ID: BS/VU2KT/1 SW version: LGF200KAT-00-V30g-KT-KR-AUG-12-2014+0 Product ID: SM02S121024000777 IMEI: 353964-05-072924-3 Opening "F200K20f_2.oct"...OK Initializing flash...OK Testing connection...OK Writing PrimaryGPT...OK Writing modem...Failed! |
09-21-2015, 10:23 | #4 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,413 | Disconnect all other devices from PC, re-boot the PC, re-start the phone, connect it directly to another motherboard USB port (don't use any USB hubs, this is important) and try to write firmware again. Try to write firmware on another PC. Try to perform "Reset Screen Lock" operation and check, whether phone powers on correctly. |
09-21-2015, 12:50 | #7 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,413 | We will check what could cause this problem and will notify You about possible solution. |
