Flash GW300? As per title, is it possible to flash/debrand a gw300. Is there unbranded firmware is support area? Br |
Did you check or not GSMBAGUIO |
Hello. Yes, Octopus Box software supports Unlock (by reading codes) via USB, Read/Write EEPROM via USB, Read/Write Full flash via USB, Write Firmware via USB and Repair phone after unsuccesfully flashing. All needed firmwares you can download from the support area. Read codes of LG GW300GO |
And, there is unbranded firmware in support area? Br |
Here Is Firmware Description,you can found easily http://forum.gsmhosting.com/vbb/f594...iption-945707/ XXX-XX means that the firmware is not associated with any service provider and is free to use with any phone. |
Added support for the following phone models: GW300 - Unlocking (by reading codes) via USB, Reading/Writing EEPROM via USB, Reading/Writing Full flash via USB, Writing Firmware via USB, Repairing phone after unsuccesfully flashing - World first |
Hello. To write firmware into GW300 please perform the next steps: 1. Please connect phone without battery to PC and install USB driver. http://www.octopusbox.com/files/driv...B%20Driver.zip 2. After that, press "Connect" button and connect phone without battery to PC. 3. Choose firmware and press "Write firmware" button. |
try to unlock but code is increct !!!!! Code: Selected model: GW300 |
Attach USB cable now ... Phone detected ! USB Port opened ! RamLoader download success; Config done ! Authorising; Authorisation passed; Getting memory info; Memory: EC000000B1 Getting unlock data; Checking unlock data; Calculating; IMEI: 3529xxxxxxx Codes: 4528493727904474 4528493727904474 3214753770750020 Enter codes using 2945#*71001# Restarting; Time needed - 00:00:20 |
I have a LG GW300 after factory reset-HWK with USF, the phone stays on and displays "PLEASE WITE. Forgive me help! |
Hello. Please try to re-flash phone with checked "Repair mode" option. |
