03-11-2010, 08:56 | #3 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,413 | Hello. Yes, Octopus Box software supports Unlock (by reading codes) via USB, Read/Write EEPROM via USB, Read/Write Full flash via USB, Write Firmware via USB and Repair phone after unsuccesfully flashing. All needed firmwares you can download from the support area. Read codes of LG GW300GO |
03-11-2010, 15:02 | #4 (permalink) | |
No Life Poster Join Date: Jan 2005 Age: 50
Member: 104911 Status: Offline Thanks Meter: 42 | Quote:
And, there is unbranded firmware in support area? Br | |
03-11-2010, 15:14 | #5 (permalink) |
Freak Poster Join Date: Jan 2010 Location: ? Age: 57
Member: 1198691 Status: Offline Sonork: 1589060 Thanks Meter: 148 | Here Is Firmware Description,you can found easily http://forum.gsmhosting.com/vbb/f594...iption-945707/ XXX-XX means that the firmware is not associated with any service provider and is free to use with any phone. |
04-15-2010, 11:17 | #6 (permalink) | |
No Life Poster Join Date: Oct 2002 Location: Romania
Member: 16269 Status: Offline Sonork: 1604924 Thanks Meter: 62 | Quote:
04-15-2010, 11:30 | #7 (permalink) |
No Life Poster Join Date: Aug 2009 Location: Ph country
Member: 1104730 Status: Offline Thanks Meter: 446 | Added support for the following phone models: GW300 - Unlocking (by reading codes) via USB, Reading/Writing EEPROM via USB, Reading/Writing Full flash via USB, Writing Firmware via USB, Repairing phone after unsuccesfully flashing - World first |
The Following User Says Thank You to Babyunlocker For This Useful Post: |
04-15-2010, 12:11 | #8 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,413 | Hello. To write firmware into GW300 please perform the next steps: 1. Please connect phone without battery to PC and install USB driver. http://www.octopusbox.com/files/driv...B%20Driver.zip 2. After that, press "Connect" button and connect phone without battery to PC. 3. Choose firmware and press "Write firmware" button. |
04-15-2010, 13:07 | #9 (permalink) | |
04-15-2010, 14:38 | #10 (permalink) |
Member: 16269 Status: Offline Sonork: 1604924 Thanks Meter: 62 | try to unlock but code is increct !!!!! Code: Selected model: GW300 Disconnect battery and connect USB cable to phone! Phone found. Sending preloader...OK Reconnecting phone...OK Sending first loader...OK Sending second loader...OK Flash ID: ECB1 Flash type: Samsung Reading info. Please wait...OK IMEI: 355737-03-,,,,..... ---------------------------------------------------------------------------------- Reading codes. Please wait...OK Unlock code: 9464 9716 7259 5897 Unlock code: 9464 9716 7259 5897 Unlock code: 5215 8703 0230 0733 To finish the operation, please perform the following steps: 1. Insert the original SIM card and type 2945#*71001# 2. Enter the code. |
The Following 2 Users Say Thank You to glontz For This Useful Post: |
06-25-2010, 07:17 | #11 (permalink) | |
No Life Poster Join Date: May 2008 Location: U.A.E Age: 34
Member: 767368 Status: Offline Sonork: 100.1590347 Thanks Meter: 570 | Quote:
Attach USB cable now ... Phone detected ! USB Port opened ! RamLoader download success; Config done ! Authorising; Authorisation passed; Getting memory info; Memory: EC000000B1 Getting unlock data; Checking unlock data; Calculating; IMEI: 3529xxxxxxx Codes: 4528493727904474 4528493727904474 3214753770750020 Enter codes using 2945#*71001# Restarting; Time needed - 00:00:20 | |
The Following User Says Thank You to gsmshapon For This Useful Post: |
07-13-2010, 13:02 | #13 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,413 | Hello. Please try to re-flash phone with checked "Repair mode" option. |
Lg gw300 - flashing / usb flashing | Alex_G | VygisToolbox | 3 | 06-02-2010 09:54 |
Lg gw300 unlock sucessfully-------gw300 usb driver | GSMHEART | FuriousGold | 4 | 03-12-2010 17:33 |
gw300 flash | newerno | VygisToolbox | 1 | 11-27-2009 00:34 |
Please Help, just need few flashing/unlocking answers - P520 | lomna | Samsung Flashers, Software, Firmware. | 3 | 02-03-2009 23:42 |
