02-07-2016, 10:54 | #1 (permalink) |
Junior Member Join Date: Mar 2010 Location: Pilipinas Age: 36
Member: 1253304 Status: Offline Sonork: kurt666 Thanks Meter: 0 | frp lg h900 v10 reset failed! please help octopus team -------------------------------------------------------------------------------- Platform: LG Qualcomm Selected port: COM38 Selected model: H901 Please, put the phone into download mode manually (Power phone OFF, press and hold "Vol+" button and connect the cable). Reading info... Model ID: LG-H900 Incompatible model ID! Please, select correct model! please add h900 |
02-08-2016, 09:46 | #2 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,412 | Hello. Unfortunately, this phone model H900 is currently not supported, we will try to add to support in future updates, we can try to prepare test software version for You, Please, contact us to Skype, or Yahoo! Messenger. Our contacts You can find in our profile. |
03-15-2016, 19:24 | #5 (permalink) |
Major Poster Join Date: Nov 2015
Member: 2487860 Status: Offline Thanks Meter: 1 | with tot? whats that? I have a H901 and I just downloaded the latest LG from March 13 2016 and there is no FRP unlock option .. look at the post below... that is not working on H901 because it just stay loading and you can't see the google play store program like in the video |
08-31-2016, 18:18 | #7 (permalink) |
Junior Member Join Date: Sep 2015 Location: Puerto Rico
Member: 2458163 Status: Offline Thanks Meter: 5 | LG V10 H900 reset FRP lock stuck on step 1 Welcome to Octoplus/Octopus Box LG Software version 2.4.0 -------------------------------------------------------------------------------- Platform: LG Qualcomm Selected port: COM41 Selected model: H900 Reading info... Model ID: LG-H900 IMEI: 353074-07-028716-2 Android version: 6.0 Battery level: 100% Mode: Emergency Initializing flash...OK SW version: LGH900AT-00-V20j-310-410-MAR-27-2016-ARB01+0 LAF Version: 1.1 Product ID: HD56S151022001080 IMEI: 353074-07-028716-2 Target operator: ATT Hardware: rev_10 Performed by 2.4.0 software version. -------------------------------------------------------------------------------- Checking data...OK Platform: LG Qualcomm Selected port: COM41 Selected model: H900 Please, put the phone into download mode manually (Power phone OFF, press and hold "Vol+" button and connect the cable (or P990 cable)). Reading info... Model ID: LG-H900 IMEI: 353074-07-028716-2 Android version: 6.0 Battery level: 100% Mode: Emergency Initializing flash...OK SW version: LGH900AT-00-V20j-310-410-MAR-27-2016-ARB01+0 LAF Version: 1.1 Product ID: HD56S151022001080 IMEI: 353074-07-028716-2 Target operator: ATT Hardware: rev_10 Reading partitions...OK Resetting FRP Lock... Step 1... Octoplus Box LG software version 2.4.0 |
09-01-2016, 07:19 | #8 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,412 | Hello. Please, disconnect phone from the PC, connect it directly to USB port of your motherboard and repeat operation again, if problem still remain, perform Read Full Flash at least ~10-12GB and send us, we will research it. |
02-21-2017, 18:41 | #9 (permalink) | |
No Life Poster Join Date: Nov 2005 Location: Sindhu Desh Age: 36
Member: 199814 Status: Offline Thanks Meter: 1,960 | Quote:
02-22-2017, 09:29 | #11 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,412 | Try to reflash the phone with V10b firmware version for (H900PR phone model) or higher, after check phone's work again. Last edited by Octopus box; 02-22-2017 at 10:03. |
10-14-2017, 12:27 | #13 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,412 | Hello. Please, post here full Software log, we will check it. |
