06-02-2016, 11:52 | #1 (permalink) |
No Life Poster Join Date: Jan 2010 Location: iraq
Member: 1215266 Status: Offline Thanks Meter: 129 | G4 FRP Lock Failed [Solved] Platform: LG Qualcomm Selected port: COM979 Selected model: H811 Please, put the phone into download mode manually (Power phone OFF, press and hold "Vol+" button and connect the cable (or P990 cable)). Reading info... Model ID: LG-H811 IMEI: 352392-07-055406-3 Android version: 5.1 Battery level: 80% Mode: Emergency Initializing flash...OK SW version: LGH811AT-01-V10n-310-260-AUG-17-2015-ARB02+0 LAF Version: 1.1 Product ID: BS08S150529002923 IMEI: 352392-07-055406-3 Target operator: TMO Hardware: rev_10 Reading partitions...OK Resetting FRP Lock...Failed! Error code: WHU8CHON7C Performed by 2.3.1 software version. Last edited by Octopus box; 09-27-2016 at 15:32. |
06-02-2016, 14:04 | #5 (permalink) |
Member: 1215266 Status: Offline Thanks Meter: 129 | Checking data...OK Platform: LG Qualcomm Selected port: COM979 Selected model: H811 Please, put the phone into download mode manually (Power phone OFF, press and hold "Vol+" button and connect the cable (or P990 cable)). Reading info... Model ID: LG-H811 IMEI: 352392-07-055406-3 Android version: 5.1 Battery level: 80% Mode: Emergency Initializing flash...OK SW version: LGH811AT-01-V10n-310-260-AUG-17-2015-ARB02+0 LAF Version: 1.1 Product ID: BS08S150529002923 IMEI: 352392-07-055406-3 Target operator: TMO Hardware: rev_10 Reading partitions...OK Resetting FRP Lock... Resetting screen lock successfully completed! Performed by 2.3.1.3 software version. |
06-02-2016, 17:58 | #6 (permalink) |
Junior Member Join Date: Dec 2014
Member: 2313555 Status: Offline Thanks Meter: 0 | I have a same problem.. Checking data...OK Platform: LG Qualcomm Selected port: COM979 Selected model: H811 Please, put the phone into download mode manually (Power phone OFF, press and hold "Vol+" button and connect the cable (or P990 cable)). Reading info... Model ID: LG-H811 IMEI: 352392-07-055406-3 Android version: 5.1 Battery level: 80% Mode: Emergency Initializing flash...OK SW version: LGH811AT-01-V10n-310-260-AUG-17-2015-ARB02+0 LAF Version: 1.1 Product ID: BS08S150529002923 IMEI: 352392-07-055406-3 Target operator: TMO Hardware: rev_10 Reading partitions...OK Resetting FRP Lock...Failed! Error code: WHU8CHON7C Performed by 2.3.1 software version. |
06-03-2016, 13:29 | #9 (permalink) |
Member: 2313555 Status: Offline Thanks Meter: 0 | Reading info... Model ID: LG-H810 IMEI: 357905-06-387021-5 Android version: 6.0 Battery level: 11% Mode: Emergency Initializing flash...OK SW version: LGH810AT-01-V20n-310-410-JAN-18-2016-ARB02+0 LAF Version: 1.1 Product ID: PT02S160119001830 IMEI: xxxxxxxxxxxxx Target operator: ATT Hardware: rev_10 Reading partitions...OK Resetting FRP Lock... Resetting screen lock successfully completed! Ist work... Tanks so much... |
06-03-2016, 17:21 | #10 (permalink) |
Junior Member Join Date: Oct 2006
Member: 377845 Status: Offline Thanks Meter: 0 | Battery level: 48% Mode: Normal Switching to Download mode...Failed! Please perform the following steps: 1. Disconnect cable 2. Put phone into download mode manually (Power phone OFF, press and hold "Vol+" button and connect the cable (or P990 cable)) 3. Connect cable and press "Ok" button. Initializing flash...OK Reading partitions...OK Resetting FRP Lock...Failed! Error code: WHU8CHON7C Performed by 2.3.1 software version. I have same problem with two phone g4. |
06-04-2016, 13:43 | #11 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,407 | Please install the latest Software version and repeat "Reset FRP Lock". |
06-09-2016, 22:44 | #14 (permalink) |
Junior Member Join Date: Jun 2013
Member: 1968791 Status: Offline Thanks Meter: 0 | Checking data...OK Platform: LG Qualcomm Selected port: COM83 Selected model: H818P Please, put the phone into download mode manually (Power phone OFF, press and hold "Vol+" button and connect the cable (or P990 cable)). Reading info... Model ID: LG-H818P IMEI: xxxxxxxxxxxxxxx Android version: 5.1 Battery level: 4% Mode: Emergency Initializing flash...OK SW version: LGH818PAT-00-V10d-BRA-XXX-JAN-29-2016+0 LAF Version: 1.1 Product ID: YE04S150528003145 IMEI: 359492-06-213665-6 Target operator: GLOBAL Hardware: rev_10 Reading partitions...OK Resetting FRP Lock...Failed! Resetting screen lock successfully completed! Performed by 2.3.0 software version. Please help! |
