05-20-2015, 13:04 | #1 (permalink) |
Crazy Poster Join Date: Nov 2006 Location: Hungary Age: 45
Member: 386438 Status: Offline Thanks Meter: 8 | H340n Freez LG logo after unlock [Solved] Last edited by Octopus box; 08-14-2015 at 12:10. |
05-20-2015, 20:03 | #3 (permalink) |
Member: 386438 Status: Offline Thanks Meter: 8 | 2015.05.18. 23:21:54 > Checking data...2015.05.18. 23:21:55 > OK 2015.05.18. 23:21:55 > Platform: LG Qualcomm 2015.05.18. 23:21:55 > Selected port: COM42 2015.05.18. 23:21:55 > Selected model: H340N 2015.05.18. 23:21:55 > Reading info... 2015.05.18. 23:21:58 > Model ID: LG-H340n 2015.05.18. 23:21:58 > IMEI: 358816-06-136341-9 2015.05.18. 23:21:58 > Android version: 5.0.1 2015.05.18. 23:21:58 > Battery level: 48% 2015.05.18. 23:22:02 > Trying to enable Diagnostics ports... 2015.05.18. 23:22:02 > Initializing ADB...2015.05.18. 23:22:03 > OK 2015.05.18. 23:22:03 > Waiting for phone...2015.05.18. 23:22:10 > OK 2015.05.18. 23:22:10 > Checking root access... 2015.05.18. 23:22:11 > Phone is not rooted. 2015.05.18. 23:22:11 > Sending exploit...2015.05.18. 23:22:15 > OK 2015.05.18. 23:22:15 > Switching to Download mode...2015.05.18. 23:22:34 > OK 2015.05.18. 23:22:34 > Initializing flash...2015.05.18. 23:22:35 > OK 2015.05.18. 23:22:35 > Executing exploit...2015.05.18. 23:23:29 > OK 2015.05.18. 23:23:29 > Press "Grant" button on the phone every time when superuser dialog appears 2015.05.18. 23:25:21 > Initializing ADB...2015.05.18. 23:25:22 > OK 2015.05.18. 23:25:22 > Waiting for phone... 2015.05.18. 23:25:22 > Please, reconnect phone, enable USB debugging, and try again. 2015.05.18. 23:25:22 > To enable USB debugging, please perform the following steps: 1. Disconnect cable 2. Install LG Android ADB drivers 3. Go to "Settings" -> "About phone" -> "Software information" 4. Click on Build number 5 times 5. Enable "Settings" -> "Developer options" -> "USB debugging" option 6. Connect the cable and check, whether ADB interface has appeared in PC Device Manager.2015.05.18. 23:25:28 > Canceled! 2015.05.18. 23:25:28 > Failed! 2015.05.18. 23:25:32 > Connecting to server support.octoplusbox.com:82...2015.05.18. 23:25:33 > OK 2015.05.18. 23:25:33 > Authorizing...2015.05.18. 23:25:35 > OK |
05-21-2015, 08:51 | #4 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,411 | Please upload flash file, which You have for H340N, and send us download link. We will prepare test Software version with "Write Firmware" operation for You. |
05-21-2015, 12:34 | #5 (permalink) |
Member: 386438 Status: Offline Thanks Meter: 8 | So, here is the flash file for H340N: https://www.dropbox.com/s/v0je8j500k...0c_00.zip?dl=0 |
05-21-2015, 16:20 | #6 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,411 | Please check your PM, we have sent You test Software version. Try to perform "Write Firmware" operation and post results here. |
05-21-2015, 20:19 | #7 (permalink) |
Member: 386438 Status: Offline Thanks Meter: 8 | So, the phone its work fine! 2015.05.21. 20:40:04 > Checking data...2015.05.21. 20:40:05 > OK 2015.05.21. 20:40:05 > Platform: LG Qualcomm 2015.05.21. 20:40:05 > Selected port: COM42 2015.05.21. 20:40:05 > Selected model: H340N 2015.05.21. 20:40:05 > Reading info... 2015.05.21. 20:40:08 > Mode: Emergency 2015.05.21. 20:40:08 > Initializing flash...2015.05.21. 20:40:09 > OK 2015.05.21. 20:40:10 > SW version: LGH340nAT-01-V10a-EUR-XX-FEB-19-2015+0 2015.05.21. 20:40:10 > LAF Version: 1.1 2015.05.21. 20:40:10 > Product ID: CY18S150429001798 2015.05.21. 20:40:10 > IMEI: 358816-06-136341-9 2015.05.21. 20:40:10 > Target operator: GLOBAL 2015.05.21. 20:40:10 > Hardware: rev_10 2015.05.21. 20:40:10 > Opening "H340n10c_00.oct"...2015.05.21. 20:40:10 > OK 2015.05.21. 20:40:10 > Setting options...2015.05.21. 20:40:12 > OK 2015.05.21. 20:40:12 > Reading partition...2015.05.21. 20:40:17 > OK 2015.05.21. 20:40:17 > Formating USERDATA...2015.05.21. 20:40:21 > OK 2015.05.21. 20:40:21 > Writing PrimaryGPT...2015.05.21. 20:40:22 > OK 2015.05.21. 20:40:22 > Writing sbl1...2015.05.21. 20:40:23 > OK 2015.05.21. 20:40:23 > Writing tz...2015.05.21. 20:40:25 > OK 2015.05.21. 20:40:25 > Writing hyp...2015.05.21. 20:40:26 > OK 2015.05.21. 20:40:26 > Writing rpm...2015.05.21. 20:40:27 > OK 2015.05.21. 20:40:27 > Writing aboot...2015.05.21. 20:40:29 > OK 2015.05.21. 20:40:29 > Writing sbl1bak...2015.05.21. 20:40:30 > OK 2015.05.21. 20:40:30 > Writing tzbak...2015.05.21. 20:40:32 > OK 2015.05.21. 20:40:32 > Writing hypbak...2015.05.21. 20:40:33 > OK 2015.05.21. 20:40:33 > Writing rpmbak...2015.05.21. 20:40:34 > OK 2015.05.21. 20:40:34 > Writing abootbak...2015.05.21. 20:40:36 > OK 2015.05.21. 20:40:36 > Writing persist...2015.05.21. 20:40:39 > OK 2015.05.21. 20:40:39 > Writing laf...2015.05.21. 20:40:48 > OK 2015.05.21. 20:40:48 > Writing boot...2015.05.21. 20:40:56 > OK 2015.05.21. 20:40:56 > Writing recovery...2015.05.21. 20:41:03 > OK 2015.05.21. 20:41:03 > Writing cust...2015.05.21. 20:41:32 > OK 2015.05.21. 20:41:32 > Writing factory...2015.05.21. 20:41:41 > OK 2015.05.21. 20:41:41 > Writing modem...2015.05.21. 20:42:07 > OK 2015.05.21. 20:42:07 > Writing system...2015.05.21. 21:00:42 > OK 2015.05.21. 21:00:42 > Writing BackupGPT...2015.05.21. 21:00:43 > OK 2015.05.21. 21:00:43 > Reading partition...2015.05.21. 21:00:47 > OK 2015.05.21. 21:00:47 > Formating RCT...2015.05.21. 21:00:51 > OK 2015.05.21. 21:00:51 > Formating MPT...2015.05.21. 21:00:55 > OK 2015.05.21. 21:00:55 > Finalizing...2015.05.21. 21:00:58 > OK 2015.05.21. 21:00:58 > Writing firmware done! Now is ready to unlock...! :-) Many thanks to Octopus Team! |
08-14-2015, 10:06 | #11 (permalink) |
No Life Poster Join Date: Mar 2008 Location: FOCSANI Age: 39
Member: 718470 Status: Offline Thanks Meter: 79 | i write H340n10c_00.oct now not working any network that was locked i write backup Welcome to Octoplus/Octopus Box LG Software version 2.0.3 --------------------------------------------------------------- Platform: LG Qualcomm Selected port: COM13 Selected model: H340N Reading info... Model ID: LG-H340n IMEI: 000000-00-000000-0 Android version: 5.0.1 Battery level: 100% Mode: Normal Firmware compiled date: Feb 24 2015 Firmware compiled time: 02:00:00 Firmware released date: Apr 17 2015 Firmware released time: 15:03:06 SW Version: MPSS.DPM.2.0.c11-00011-M8936FAAAANUZM-1 SPC: 000000 Selecting input file...OK Source file: "H340_358816060692859_13-08-2015_15-11-56.qcn" Do You want to write IMEI from QCN file or to leave current IMEI? Write IMEI from QCN file! Send SPC...OK Writing QCN... Writing EFS...OK Writing NV_Numbered Items...OK Writing NV_Numbered SIM1 Items...OK Writing NV_Numbered SIM2 Items...OK Writing Provisioning Items...OK Writing QCN done! -------------------------------------------------------------------------------- Checking data...OK Platform: LG Qualcomm Selected port: COM13 Selected model: H340N Reading info... Model ID: LG-H340n IMEI: 358816-06-069285-9 Android version: 5.0.1 Battery level: 100% Mode: Normal Firmware compiled date: Feb 24 2015 Firmware compiled time: 02:00:00 Firmware released date: Apr 17 2015 Firmware released time: 15:03:06 SW Version: MPSS.DPM.2.0.c11-00011-M8936FAAAANUZM-1 IMEI: 358816-06-069285-9 SPC: 000000 Unlocking... Reading QCN... Send SPC...OK Reading Mobile Property...OK Reading Feature Mask...OK Reading Roaming List 0...OK Reading NV_Numbered Items...OK Reading NV_Numbered SIM1 Items...OK Reading NV_Numbered SIM2 Items...OK Reading NV Items...OK Reading EFS...OK Reading Provisioning Items...OK Reading QCN done! Backup saved to "H340_358816060692859_14-08-2015_11-52-47.qcn" Switching to Download mode...OK Initializing flash...OK Reading partition...OK Reading security area...OK Backup saved to "H340_358816060692859_14-08-2015_12-00-30.SEC" Writing security area...OK Switching to Normal mode... Found model EAAAANWZ at port COM13 Send SPC...OK Writing QCN... Writing NV_Numbered Items...OK Writing NV_Numbered SIM1 Items...OK Writing NV_Numbered SIM2 Items...OK Writing QCN done! Phone successfully unlocked! Please, reboot the phone manually. error Curent version is not avaiable for user . Can t find matched cust for nt-code mcc/mnc 22601 subset(ff) |
08-14-2015, 10:17 | #12 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,411 | Please do the next: 1. Write "H340_358816060692859_14-08-2015_11-52-47.qcn" QCN backup back into the phone. 2. Restart the phone. 3. Wait 2-5 minutes, then try to find and select Network manually. |
