09-18-2018, 18:51 | #1 (permalink) |
Freak Poster Join Date: Jan 2006 Location: El Salvador
Member: 225008 Status: Offline Thanks Meter: 11 | H345 unlock problem [Answered] 18/09/2018 9:56:59 > Searching for server... 18/09/2018 9:56:59 > Trying to ping server...18/09/2018 9:56:59 > ok 18/09/2018 9:56:59 > Trying connect to server... 18/09/2018 9:56:59 > Server greeting: Card updates server v.2.2 18/09/2018 9:57:00 > Searching installed cards... 18/09/2018 9:57:00 > Found card with s/n: 00039F5E 18/09/2018 9:57:00 > Server check... 18/09/2018 9:57:00 > Server Check succesfull! 18/09/2018 9:57:00 > Server Check succesfull! 18/09/2018 9:57:04 > Bienvenido en Octoplus/Octopus Box LG Software version 2.8.8 18/09/2018 9:59:41 > -------------------------------------------------------------------------------- 18/09/2018 9:59:41 > Connecting to server ...18/09/2018 9:59:42 > OK 18/09/2018 9:59:42 > Username: bbb_p8k9k8 18/09/2018 9:59:42 > Authorizing...18/09/2018 9:59:43 > OK 18/09/2018 9:59:43 > Checking balance...18/09/2018 9:59:43 > OK 18/09/2018 9:59:43 > Your balance: 0 credits. 18/09/2018 10:00:42 > -------------------------------------------------------------------------------- 18/09/2018 10:00:42 > Connecting to server ...18/09/2018 10:00:43 > OK 18/09/2018 10:00:43 > Username: ccc_q5w5d2 18/09/2018 10:00:43 > Authorizing...18/09/2018 10:00:44 > OK 18/09/2018 10:00:44 > Checking balance...18/09/2018 10:00:44 > OK 18/09/2018 10:00:44 > Your balance: 100 credits. 18/09/2018 10:10:52 > -------------------------------------------------------------------------------- 18/09/2018 10:10:52 > Checking data...18/09/2018 10:10:53 > OK 18/09/2018 10:10:54 > Plataforma: LG Qualcomm 18/09/2018 10:10:54 > Puerto seleccionado: COM701 18/09/2018 10:10:54 > Modelo seleccionado: H345 18/09/2018 10:10:54 > Lectura de la información... 18/09/2018 10:10:55 > Model ID: LG-H345 18/09/2018 10:10:55 > IMEI: 359562-06-806174-2 18/09/2018 10:10:55 > Android version: 5.1.1 18/09/2018 10:10:55 > Battery level: 87% 18/09/2018 10:10:55 > Versión de SW: 18/09/2018 10:10:55 > H34510h 18/09/2018 10:11:04 > Trying to enable Diagnostics ports... 18/09/2018 10:11:04 > Found model EAAAANVZ: ÿd at port COM701 18/09/2018 10:11:05 > Checking root access... 18/09/2018 10:11:05 > Initializing ADB...18/09/2018 10:11:06 > OK 18/09/2018 10:11:06 > Waiting for phone... 18/09/2018 10:11:06 > Please, reconnect phone, enable USB debugging, and try again. 18/09/2018 10:11:06 > To enable USB debugging, please perform the following steps: 1. Disconnect cable 2. Install LG Android ADB drivers 3. Go to "Settings" -> "About phone" -> "Software information" 4. Click on Build number 5 times 5. Enable "Settings" -> "Developer options" -> "USB debugging" option 6. Connect the cable and check, whether ADB interface has appeared in PC Device Manager.18/09/2018 10:11:46 > OK 18/09/2018 10:11:50 > Phone is already rooted. 18/09/2018 10:11:52 > -------------------------------------------------------------------------------- 18/09/2018 10:11:52 > Connecting to server...18/09/2018 10:11:55 > OK 18/09/2018 10:11:55 > Octopus smart card is present. 18/09/2018 10:11:55 > Checking smart card...18/09/2018 10:12:02 > OK 18/09/2018 10:12:02 > Username: ccc_q5w5d2 18/09/2018 10:12:02 > Authorizing...18/09/2018 10:12:03 > OK 18/09/2018 10:12:03 > Checking balance...18/09/2018 10:12:04 > OK 18/09/2018 10:12:04 > Checking operation...18/09/2018 10:12:07 > OK 18/09/2018 10:12:07 > Sending device information...18/09/2018 10:12:08 > OK 18/09/2018 10:12:08 > Get credits, needed for current operation...18/09/2018 10:12:09 > OK 18/09/2018 10:12:09 > Your balance: 100 credits. 18/09/2018 10:12:09 > To perform "Unlock" operation you need to have 100 credits. 18/09/2018 10:12:13 > Sending exploit...18/09/2018 10:12:14 > OK 18/09/2018 10:12:14 > Executing exploit...18/09/2018 10:12:20 > OK 18/09/2018 10:12:21 > Sending data to server...18/09/2018 10:13:01 > OK 18/09/2018 10:13:01 > Calculating. Please Wait...18/09/2018 10:13:45 > OK 18/09/2018 10:13:46 > Liberación... 18/09/2018 10:14:10 > ¡El teléfono está liberado con éxito! 18/09/2018 10:14:10 > Rebooting phone... 18/09/2018 10:14:10 > Performed by 2.8.8 Software version. 18/09/2018 10:14:10 > Elapsed Time: 0:03:22 Last edited by Octopus box; 09-19-2018 at 05:14. |
09-19-2018, 05:14 | #2 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,407 | Probably (most likely) your device has non-original security. In this case you can try to re-flash the phone and then try to repeat the «Unlock» operation again. If the problem will remains, unfortunately, it is not possible to unlock such device by this "Unlock" method. |
