05-08-2017, 17:10 | #1 (permalink) |
No Life Poster Join Date: Apr 2014 Location: istanbul
Member: 2171555 Status: Offline Thanks Meter: 129 | h540 new firmware repair failed [Answered] not repair 08.05.2017 18:17:19 > -------------------------------------------------------------------------------- 08.05.2017 18:17:19 > Checking data...08.05.2017 18:17:20 > OK 08.05.2017 18:17:20 > Platform: LG MTK 08.05.2017 18:17:20 > Selected port: COM1 08.05.2017 18:17:20 > Selected baudrate: 115200 08.05.2017 18:17:20 > Selected model: H540 08.05.2017 18:17:20 > Selected USB connection type 08.05.2017 18:17:22 > Please, disconnect cable, reconnect battery, connect P999 cable (with 910k resistor) 08.05.2017 18:17:22 > or 08.05.2017 18:17:22 > Reconnect battery, press and hold "Vol+" for 10 seconds and connect Micro USB cable. 08.05.2017 18:17:35 > Phone found. 08.05.2017 18:17:39 > Mode: Emergency 08.05.2017 18:17:39 > Initializing flash...08.05.2017 18:17:41 > OK 08.05.2017 18:17:42 > Model ID: LG-H540 08.05.2017 18:17:42 > SW version: LGH540AT-00-V20a-AME-XX-AUG-10-2016+0 08.05.2017 18:17:42 > LAF Version: 1.1 08.05.2017 18:17:42 > Product ID: HD57S160421000066 08.05.2017 18:17:42 > IMEI: 358285-07-078083-3 08.05.2017 18:17:42 > Target operator: GLOBAL 08.05.2017 18:17:42 > Hardware: rev_10 08.05.2017 18:17:42 > Battery level: 100% 08.05.2017 18:17:42 > Reading partitions...08.05.2017 18:17:42 > Failed! 08.05.2017 18:17:42 > Reading partitions... 08.05.2017 18:17:42 > Performed by 2.6.4 Software version. 08.05.2017 18:18:12 > -------------------------------------------------------------------------------- 08.05.2017 18:18:12 > Checking data...08.05.2017 18:18:13 > OK 08.05.2017 18:18:13 > Platform: LG MTK 08.05.2017 18:18:13 > Selected port: COM1 08.05.2017 18:18:13 > Selected baudrate: 115200 08.05.2017 18:18:13 > Selected model: H540 08.05.2017 18:18:13 > Selected USB connection type 08.05.2017 18:18:16 > Please, disconnect cable, reconnect battery, connect P999 cable (with 910k resistor) 08.05.2017 18:18:16 > or 08.05.2017 18:18:16 > Reconnect battery, press and hold "Vol+" for 10 seconds and connect Micro USB cable. 08.05.2017 18:18:19 > Phone found. 08.05.2017 18:18:37 > Mode: Emergency 08.05.2017 18:18:37 > Initializing flash...08.05.2017 18:18:40 > OK 08.05.2017 18:18:41 > Model ID: LG-H540 08.05.2017 18:18:41 > SW version: LGH540AT-00-V20a-AME-XX-AUG-10-2016+0 08.05.2017 18:18:41 > LAF Version: 1.1 08.05.2017 18:18:41 > Product ID: HD57S160421000066 08.05.2017 18:18:41 > IMEI: 35828xx 08.05.2017 18:18:41 > Target operator: GLOBAL 08.05.2017 18:18:41 > Hardware: rev_10 08.05.2017 18:18:41 > Battery level: 100% 08.05.2017 18:18:41 > Reading partitions...08.05.2017 18:18:41 > Failed! 08.05.2017 18:18:41 > Reading partitions... 08.05.2017 18:18:41 > Performed by 2.6.4 Software version. |
The Following User Says Thank You to cr@zyboy For This Useful Post: |
05-08-2017, 17:24 | #2 (permalink) |
Member: 2171555 Status: Offline Thanks Meter: 129 | no downgrade.... Checking data...OK Platform: LG MTK Selected port: COM34 Selected baudrate: 921600 Selected model: H540 Selected USB connection type Please, disconnect cable, reconnect battery, connect P999 cable (with 910k resistor) or Reconnect battery, press and hold "Vol+" for 10 seconds and connect Micro USB cable. Phone found. Mode: Emergency Initializing flash...OK Model ID: LG-H540 SW version: LGH540AT-00-V20a-AME-XX-AUG-10-2016+0 LAF Version: 1.1 Product ID: HD57S160421000066 IMEI: 358285-07-078083-3 Target operator: GLOBAL Hardware: rev_10 Battery level: 100% Reading partitions...Failed! Reading partitions... Performed by 2.6.4 Software version. |
05-09-2017, 08:36 | #3 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,413 | We have prepared test Software version for You. Please download and install it form the Support Area ("LG/TEST SOFTWARE" folder), then perform "Read Full Flash" operation, after send us the file, we will check what cause the problem. Last edited by Octopus box; 05-09-2017 at 08:48. |
The Following 3 Users Say Thank You to Octopus box For This Useful Post: |
02-01-2019, 15:02 | #4 (permalink) | |
No Life Poster Join Date: May 2005 Age: 40
Member: 146708 Status: Offline Sonork: 100.108221 Thanks Meter: 1,603 | Quote:
Code: Welcome to Octoplus/Octopus Box LG Software version 2.9.2 -------------------------------------------------------------------------------- Platform: LG MTK Selected port: COM1 Selected baudrate: 921600 Selected model: H540 Selected USB connection type Please, disconnect cable, reconnect battery, connect P999 cable (with 910k resistor) or Reconnect battery, press and hold "Vol+" for 10 seconds and connect Micro USB cable. Phone found at port COM672 Port is not active! Performed by 2.9.2 Software version. -------------------------------------------------------------------------------- Platform: LG MTK Selected port: COM1 Selected baudrate: 921600 Selected model: H540 Selected USB connection type Please, disconnect cable, reconnect battery, connect P999 cable (with 910k resistor) or Reconnect battery, press and hold "Vol+" for 10 seconds and connect Micro USB cable. Phone found at port COM142 Mode: Emergency Initializing flash...OK Model ID: LG-H540 Platform: mt6592 Android version: 6.0 SW version: LGH540AT-00-V20a-AME-XX-AUG-10-2016+0 LAF Version: 1.1 Product ID: BS08S151210001889 IMEI: 351776-xx-xxxxxx-8 Target operator: GLOBAL Hardware: rev_10 Battery level: 28% Reading partitions...Failed! Reading partitions... Checking security...Failed! -------------------------------------------------------------------------------- IMEI A: 351776-xx-xxxxxxx-8 IMEI B: Bad Bluetooth address: Unknown Wi-Fi MAC address: Unknown -------------------------------------------------------------------------------- Performed by 2.9.2 Software version. Connecting to server support2.octoplusbox.com:82...OK Authorizing...OK | |
02-01-2019, 16:45 | #5 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,413 | Please, download and install the latest test Software version from the Support Area, after repeat operation again |
02-02-2019, 10:44 | #6 (permalink) | |
it was the latest software..and again i reinstalled it same error.. Performed by 2.9.2 Software version. -------------------------------------------------------------------------------- Checking data...OK Platform: LG MTK Selected port: COM1 Selected baudrate: 921600 Selected model: H540 Selected USB connection type Please, disconnect cable, reconnect battery, connect P999 cable (with 910k resistor) or Reconnect battery, press and hold "Vol+" for 10 seconds and connect Micro USB cable. Phone found at port COM672 Mode: Emergency Initializing flash...OK Model ID: LG-H540 Platform: mt6592 Android version: 6.0 SW version: LGH540AT-00-V20a-AME-XX-AUG-10-2016+0 LAF Version: 1.1 Product ID: BS08S151210001889 IMEI: 35xxxx-xx-8xxxx25-8 Target operator: GLOBAL Hardware: rev_10 Battery level: 31% Reading partitions...Failed! Reading partitions... Checking security...Failed! -------------------------------------------------------------------------------- IMEI A: 35xxxx-xxx-8xxxxx25-8 IMEI B: Bad Bluetooth address: Unknown Wi-Fi MAC address: Unknown -------------------------------------------------------------------------------- Detecting writing method...OK Fixing IMEI A... New IMEI A: 351xxxx-xxx-8xxxxx25-8 Reading security area...OK Backup saved to "H540_351xxxxxxxxx258_02-02-2019_11-41-38.EEP" Patching security...Failed! Performed by 2.9.2 Software version. [/CODE] | |
