12-07-2016, 11:40 | #1 (permalink) |
No Life Poster Join Date: Mar 2008 Location: City of Temples
Member: 729381 Status: Offline Thanks Meter: 248 | H634 security error [Solved] i need to repair this set i shows security error and doesn't turn ON completely no option for repair security in octopus lg tool Last edited by Octopus box; 12-08-2016 at 10:42. |
12-07-2016, 12:40 | #3 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,411 | Hello. We have prepared test Software version for You, that supports Reset Security operation. You can download it form the Support Area ("LG/TEST SOFTWARE/" folder). Perform Reset Security operation and post here full Software log. Last edited by Octopus box; 12-07-2016 at 12:45. |
12-08-2016, 08:22 | #4 (permalink) |
Member: 729381 Status: Offline Thanks Meter: 248 | hello, tried with test version but phone still shows security error and not boot ON completely Code: Welcome to Octoplus/Octopus Box LG Software version 2.5.2.5 -------------------------------------------------------------------------------- Checking data...OK Platform: LG Qualcomm Selected port: COM36 Selected model: H634 Reading info... Model ID: LG-H634 IMEI: 359565-06-477082-8 Android version: 5.1.1 Battery level: 100% SW Version: H63410e Mode: Emergency Initializing flash...OK SW version: LGH634AT-01-V10e-310-150-NOV-17-2015-ARB00+0 Android version: 5.1.1 LAF Version: 1.1 Product ID: CT69S151023002008 IMEI: 359565-06- Target operator: CRK Hardware: rev_10 Switching to Normal mode... Trying to enable Diagnostics ports... Performed by 2.5.2.5 Software version. |
12-08-2016, 08:33 | #5 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,411 | Please do the following: 1. Put the phone in Download Mode. 2. Enable (check) ”Skip read / write QCN ....” option in Software. 3. Perform "Reset security" again. 4. Write here the result. |
12-08-2016, 08:57 | #6 (permalink) |
Member: 729381 Status: Offline Thanks Meter: 248 | hello, no progress phone restart in security error screen Code: Welcome to Octoplus/Octopus Box LG Software version 2.5.2.5 -------------------------------------------------------------------------------- Checking data...OK Platform: LG Qualcomm Selected port: COM36 Selected model: H634 Reading info... Model ID: LG-H634 IMEI: 359565-06-477082-8 Android version: 5.1.1 Battery level: 100% SW Version: H63410e Mode: Emergency Initializing flash...OK SW version: LGH634AT-01-V10e-310-150-NOV-17-2015-ARB00+0 Android version: 5.1.1 LAF Version: 1.1 Product ID: CT69S151023002008 IMEI: 359565-06- Target operator: CRK Hardware: rev_10 Skip Read/Write QCN Reading partitions...OK Reading security area...OK Backup saved to "H634_35956506xxxxxxx_08-12-2016_13-40-26.SEC" Resetting secutiy area...OK Switching to Normal mode... Trying to enable Diagnostics ports... Performed by 2.5.2.5 Software version. |
12-08-2016, 09:04 | #7 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,411 | Please, try to re-flash the phone, then check phone's work and post result here. Last edited by Octopus box; 12-08-2016 at 09:13. |
12-08-2016, 09:14 | #9 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,411 | At first try to re-flash with the same as in the phone V10e version ("LGH634AT-01-V10e-310-150-NOV-17-2015-ARB00+0"). If this will not help - try to write higher version. |
12-08-2016, 10:07 | #10 (permalink) |
Member: 729381 Status: Offline Thanks Meter: 248 | thank u phone flashed with this firmware [LGH634AT-01-V10g-310-150-JAN-06-2016-ARB00+0]and fixed imei and now set is working Code: Welcome to Octoplus/Octopus Box LG Software version 2.5.2.5 -------------------------------------------------------------------------------- Platform: LG Qualcomm Selected port: COM41 Selected model: H634 Reading info... Model ID: LG-H634 IMEI: 000000-00-000000-0 Android version: 5.1.1 Battery level: 100% SW Version: H63410g Mode: Normal Performed by 2.5.2.5 Software version. -------------------------------------------------------------------------------- Checking data...OK Platform: LG Qualcomm Selected port: COM41 Selected model: H634 Reading info... Model ID: LG-H634 IMEI: 000000-00-000000-0 Android version: 5.1.1 Battery level: 100% SW Version: H63410g Trying to enable Diagnostics ports... Found model EAAAANVZ* ÿd at port COM41 Fixing IMEI... New IMEI A: 359565-06- Finalizing...OK IMEI successfully fixed! Rebooting phone... Performed by 2.5.2.5 Software version. Last edited by bimes; 12-08-2016 at 10:14. |
