05-18-2017, 06:58 | #2 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,413 | Hello. We have prepared Test Software version for You. Please download and install it from the Support Area ("LG/TEST SOFTWARE" folder), then perform "Repair Wi-Fi" operation. Post here full Software log, we will check it. Last edited by Octopus box; 05-18-2017 at 07:32. |
05-20-2017, 23:22 | #3 (permalink) |
No Life Poster Join Date: Mar 2007 Location: ALGERIA Age: 17
Member: 467636 Status: Offline Sonork: Double Kanon Thanks Meter: 2,654 | hi in Octo_Root folder there is only busybox.zip file no supersu.zip & quick-reboot.zip there Code: -------------------------------------------------------------------------------- Platform: LG Qualcomm Selected port: COM1 Selected model: H791 Reading info... Initializing ADB...OK Waiting for phone...OK Model ID: Nexus 5X Phone firmware version: Kernel version: 3.10.73-gc33d1bd ([email protected]) (gcc version 4.9.x-google 20140827 (prerelease) (GCC) ) #1 SMP PREEMPT Fri Oct 21 04:43:24 UTC 201 Android version: 7.1.1 Hardware: Qualcomm Technologies, Inc MSM8992 AArch64 Processor rev 3 (aarch64) Performed by 2.6.6 Software version. -------------------------------------------------------------------------------- Checking data...OK Platform: LG Qualcomm Selected port: COM1 Selected model: H791 Reading info... Initializing ADB...OK Waiting for phone...OK Model ID: Nexus 5X Phone firmware version: Kernel version: 3.10.73-gc33d1bd ([email protected]) (gcc version 4.9.x-google 20140827 (prerelease) (GCC) ) #1 SMP PREEMPT Fri Oct 21 04:43:24 UTC 201 Android version: 7.1.1 Hardware: Qualcomm Technologies, Inc MSM8992 AArch64 Processor rev 3 (aarch64) Trying to enable Diagnostics ports... Initializing ADB...OK Waiting for phone...OK Checking root access... Phone is not rooted. Sending exploit...OK Switching to Fastboot mode...OK Unlocking Bootloader... Bootloader is unlocked. Writing Recovery...OK To Root the phone, please perform the following steps: 1. Select "Recovery mode" (use Vol+, Vol-), then boot into "Recovery" (press "Power" button); 2. Press "Install" and go into "Octo_Root" folder in the phone; 3. Select "supersu.zip" and press "Add more zips"; 4. Select "busybox.zip" and press "Add more zips"; 5. Select "quick-reboot.zip" then swipe to confirm flash; 6. Press "Reboot System"; 7. Please, wait while the phone will turn on and press "OK" button. Press "Grant" button on the phone every time when superuser dialog appears Checking root access... Initializing ADB...OK Waiting for phone...OK Phone is not rooted. Root access garanted! Diagnostics ports are enbled! Switching to Serial Port... Failed! Performed by 2.6.6 Software version. |
05-20-2017, 23:46 | #4 (permalink) |
Member: 467636 Status: Offline Sonork: Double Kanon Thanks Meter: 2,654 | after all steps adress is the same 02:00:00:00:00:00 Code: -------------------------------------------------------------------------------- Checking data...OK Platform: LG Qualcomm Selected port: COM1 Selected model: H791 Reading info... Initializing ADB...OK Waiting for phone...OK Model ID: Nexus 5X Phone firmware version: Kernel version: 3.10.73-gc33d1bd (android- [email protected]) (gcc version 4.9.x-google 20140827 (prerelease) (GCC) ) #1 SMP PREEMPT Fri Oct 21 04:43:24 UTC 201 Android version: 7.1.1 Hardware: Qualcomm Technologies, Inc MSM8992 AArch64 Processor rev 3 (aarch64) Trying to enable Diagnostics ports... Initializing ADB...OK Waiting for phone...OK Checking root access... Phone is already rooted. Diagnostics ports are enbled! Switching to Serial Port... Found model FAAAANAZ:ÿš iù at port COM307 Reading info... Mode: Normal Firmware compiled date: Aug 16 2016 Firmware compiled time: 18:00:00 Firmware released date: Oct 6 2016 Firmware released time: 15:15:57 SW Version: M8994F-2.6.36.2.20 IMEI: 353627-07-204918-5 SPC: 000000 Switching to Download mode...OK Fixing Wi-Fi MAC address... New Wi-Fi MAC address: 00:A0:C6:EB:5C:6F Reading partitions... Initializing flash...OKOK Reading misc...OK Writing misc...OK Wi-Fi MAC address successfully fixed! Performed by 2.6.6 Software version. Last edited by Octopus box; 05-21-2017 at 08:17. |
05-22-2017, 15:01 | #5 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,413 | We will research where can be the problem and write the result here. |
05-23-2017, 07:37 | #6 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,413 | Try to reflash the device with 6.0.1 firmware version via Nexus Root Toolkit, after re-root the phone and try to perform Repair Wi-Fi operation. |
05-24-2017, 07:23 | #8 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,413 | After You have performed Repair Wi-Fi operation on Android 6.0.x version, please perform Factory Data Reset operation, then You can try to update your phone via OTA. |
05-25-2017, 12:29 | #10 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,413 | Please, download and install test Software version from the Support Area (LG/TEST SOFTWARE/), then perform next steps: 1. Reflash the phone with NRT with Android 6.0.1 firmware. 2. Root the device. 3. Perform Repair Wi-FI operation. 4. Reflash the phone with NRT with Android 7.0x fimware version. |
