09-30-2015, 15:44 | #1 (permalink) |
No Life Poster Join Date: Aug 2014 Location: brazil - brasilia
Member: 2235684 Status: Offline Thanks Meter: 417 | h818p imei failed [Solved] Welcome to Octoplus/Octopus Box LG Software version 2.0.6 -------------------------------------------------------------------------------- Platform: LG Qualcomm Selected port: COM54 Selected model: H818P Reading info... Model ID: LG-H818P IMEI: 359492-06-190153-0 Android version: 5.1 Battery level: 10% Mode: Normal -------------------------------------------------------------------------------- Checking data...OK Platform: LG Qualcomm Selected port: COM54 Selected model: H818P Reading info... Model ID: LG-H818P IMEI: 359492-06-190153-0 Android version: 5.1 Battery level: 10% Trying to enable Diagnostics ports... Initializing ADB...OK ADB Server was found. Trying to kill... Waiting for phone...Failed! Please, reconnect phone, enable USB debugging, and try again. To enable USB debugging, please perform the following steps: 1. Disconnect cable 2. Install LG Android ADB drivers 3. Go to "Settings" -> "About phone" -> "Software information" 4. Click on Build number 5 times 5. Enable "Settings" -> "Developer options" -> "USB debugging" option 6. Connect the cable and check, whether ADB interface has appeared in PC Device Manager. -------------------------------------------------------------------------------- Checking data...OK Platform: LG Qualcomm Selected port: COM54 Selected model: H818P Reading info... Model ID: LG-H818P IMEI: 359492-06-190153-0 Android version: 5.1 Battery level: 10% Trying to enable Diagnostics ports... Initializing ADB...OK Waiting for phone...OK Diagnostics ports are enbled! Switching to Serial Port... Found model LGH818PA: ÿd at port COM54 Fixing IMEI... New IMEI A: 359492-06-248748-9 New IMEI B: 359492-06-458730-2 Reading QCN... Send SPC...OK Reading Mobile Property...OK Reading Feature Mask...OK Reading Roaming List 0...OK Reading NV_Numbered Items...OK Reading NV_Numbered SIM1 Items...OK Reading NV_Numbered SIM2 Items...OK Reading NV Items...OK Reading EFS...OK Reading Provisioning Items...OK Reading QCN done! Backup saved to "H818P_359492061901530_30-09-2015_11-32-13.qcn" Switching to Download mode...OK Initializing flash...OK Reading partition...OK Reading security area...OK Backup saved to "H818P_359492061901530_30-09-2015_11-39-43.SEC" Writing security area...OK Switching to Normal mode... Found model LGH818PA* ÿd at port COM54 Send SPC...OK Writing QCN... Writing NV_Numbered Items...Failed! Error code: ZXLCALSZXD Last edited by Octopus box; 09-30-2015 at 17:35. |
09-30-2015, 16:16 | #2 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,413 | Hello. Please repeat "Repair IMEI" operation with enabled "Skip Read/Write QCN during Repair IMEI operation" option. Post here result and full Software log of the operation. |
