02-22-2018, 08:40 | #2 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,411 | Hello. Please press "Cable & Manual" button in Software and read manual on how to perform "Repair IMEI" operation: Code: 1. Remove SD and SIM cards from the phone; 2. Connect powered-on phone to PC with Micro USB Type-C cable; 3. Install necessary driver; 4. Enter correct IMEI; 5. Click "IMEI fix" button; 6. Follow software instructions (prompts). Note: To connect the phone in Normal Mode, do the next: - Select "File transfer" mode in "Use USB connection for" window, then press "Always"; - Type 277634#*# or *#546368#*820# or 3845*#820#, go to "Port Check Test" (or "SVC Menu -> Port Check Test") and switch "Port Check Test" to "Enabled". |
