08-26-2018, 15:12 | #2 (permalink) |
Banned Join Date: Jan 2017 Location: Algeria DZ
Member: 2669781 Status: Offline Thanks Meter: 1,839 | in this case, LG module detects phones in diag mode, to do so, follow the instructions below Enable "USB Debugging" mode: type 277634#*# or *#546368#*840# or 3845*#840#, go to "Port Check Test" (or "SVC Menu -> Port Check Test") and switch "Port Check Test" to "Enabled". Good luck |
08-26-2018, 16:07 | #4 (permalink) | |
Freak Poster Join Date: Mar 2018 Location: USA
Member: 2816635 Status: Offline Thanks Meter: 12 | Quote:
I have tired it but it still not detect it. EDL maybe ? I can bring the device manually to EDL. so what option can i do with EDL on the SW? | |
08-26-2018, 16:26 | #5 (permalink) |
Member: 2669781 Status: Offline Thanks Meter: 1,839 | EDL? No, you don't need so, unless your phone is bricked!! Which is not supported Via USB loader Whats wrong with your phone? And what oepration you wanna conduct with LG soft? Try to tick manual selection of ports, and select diag... Open device manager and check whether the drivers are properly installed, if not install the following drivers, and try again.. https://octoplusbox.com/en/download/drivers/ |
08-27-2018, 07:49 | #6 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,413 | Hi. What device(s) exactly appear in Windows Device Manager, when You connect the phone to PC? Please post here screenshot of Device Managed with opened "Ports" items, we will check. |
