07-10-2018, 13:12 | #1 (permalink) |
No Life Poster Join Date: Apr 2005 Location: Italiaf Age: 65
Member: 135097 Status: Offline Thanks Meter: 22 | H870 Android 8.0 Reset FRP question [Answered] Welcome to Octoplus/Octopus Box LG Software version 2.8.7 Please select Reset FRP Method! Checking data...OK Platform: LG Qualcomm Selected port: COM29 Selected model: H870 Please, put the phone into download mode manually (Power phone OFF, press and hold "Vol+" button and connect the cable). Reading info... Model ID: LG-H870 IMEI: ----------------------- Android version: 8.0.0 Battery level: 98% SW Version: H87020a Mode: Emergency Initializing flash...OK SW version: LGH870AT-00-V20a-222-01-APR-28-2018+0 Android version: 8.0.0 LAF Version: 1.1 Product ID: YE01S170330001835 IMEI: 356144-08-181322-8 Target operator: GLOBAL Hardware: rev_10 Reset FRP operation is currently not supported for your phone's firmware. Performed by 2.8.7 Software version. Please select Reset FRP Method! -------------------------------------------------------------------------- Last edited by Octopus box; 07-10-2018 at 13:51. |
07-10-2018, 13:55 | #2 (permalink) | |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,412 | Hello. As You can see from Software log: Quote:
06-25-2019, 18:03 | #3 (permalink) |
Major Poster Join Date: Aug 2015 Location: basque country
Member: 2446408 Status: Offline Thanks Meter: 8 | how i can unbrick it because when try to frp bricked here is logs Log file "C:\Program Files (x86)\Octoplus\Octoplus_LG\LOG\25-06-2019_18-39-22.log" created. 25/06/2019 18:39:24 > Searching for server... 25/06/2019 18:39:24 > Trying to ping server...25/06/2019 18:39:24 > ok 25/06/2019 18:39:24 > Trying connect to server... 25/06/2019 18:39:24 > Server greeting: Card updates server v.2.2 25/06/2019 18:39:25 > Searching installed cards... 25/06/2019 18:39:25 > Found card with s/n: 00098682 25/06/2019 18:39:25 > Server check... 25/06/2019 18:39:32 > Server Check succesfull! 25/06/2019 18:39:32 > Server Check succesfull! 25/06/2019 18:39:35 > Welcome to Octoplus/Octopus Box LG Software version 2.9.5 25/06/2019 18:40:16 > Please, select Reset FRP Method! 25/06/2019 18:40:22 > -------------------------------------------------------------------------------- 25/06/2019 18:40:22 > Checking data...25/06/2019 18:40:23 > OK 25/06/2019 18:40:23 > Platform: LG Qualcomm 25/06/2019 18:40:23 > Selected port: COM1178 25/06/2019 18:40:23 > Selected model: H870 25/06/2019 18:40:23 > Please, put the phone into download mode manually (Power phone OFF, press and hold "Vol+" button and connect the cable). 25/06/2019 18:40:23 > Reading info... 25/06/2019 18:40:24 > Model ID: LG-H870 25/06/2019 18:40:24 > IMEI: 356144-08-668231-3 25/06/2019 18:40:24 > Android version: 8.0.0 25/06/2019 18:40:24 > Battery level: 51% 25/06/2019 18:40:25 > Mode: Emergency 25/06/2019 18:40:25 > Initializing flash...25/06/2019 18:40:27 > OK 25/06/2019 18:40:28 > Platform: msm8996 25/06/2019 18:40:28 > SW version: 25/06/2019 18:40:28 > LGH870AT-00-V20g-EUR-XX-NOV-22-2018+0 25/06/2019 18:40:28 > Android version: 8.0.0 25/06/2019 18:40:28 > LAF Version: 1.1 25/06/2019 18:40:28 > Product ID: PT01S170621003502 25/06/2019 18:40:28 > IMEI: 356144-08-668231-3 25/06/2019 18:40:28 > Target operator: GLOBAL 25/06/2019 18:40:28 > Hardware: rev_10 25/06/2019 18:40:28 > Reading partitions...25/06/2019 18:40:34 > OK 25/06/2019 18:40:34 > Reading BOOT... 25/06/2019 18:40:35 > ID: 0005F0E100310000 25/06/2019 18:40:36 > Operation is not safe and exist risk to damage the device! Do You want to continue?25/06/2019 18:40:47 > OK 25/06/2019 18:40:47 > Backup saved to "H870_356144086682313_25-06-2019_18-40-47.oct" 25/06/2019 18:40:47 > Switching to Qualcomm 9008 mode... 25/06/2019 18:42:31 > "Qualcomm HS-USB QDLoader 9008" device not found. Please, don't disconnect cable, this can damage your device! Install "Qualcomm USB Driver" and press "Continue" button 25/06/2019 18:45:52 > "Qualcomm HS-USB QDLoader 9008" device not found. Please, don't disconnect cable, this can damage your device! Install "Qualcomm USB Driver" and press "Continue" button 25/06/2019 18:46:22 > Canceled! 25/06/2019 18:46:22 > Performed by 2.9.5 Software version. 25/06/2019 18:46:22 > Elapsed Time: 0:06:09 |
