11-23-2018, 19:03 | #1 (permalink) |
Freak Poster Join Date: Mar 2016 Location: gsm would
Member: 2550445 Status: Offline Thanks Meter: 26 | H870DS Reset FRP problem [Solved] -------------------------------------------------------------------------------- Platform LG Qualcomm Selected port COM20 Selected model H870 Reading info... Model ID LG-H870DS IMEI 356145-08-485695-7 Android version 8.0.0 Battery level 97% SW Version H87020f Mode Emergency Initializing flash...OK Platform msm8996 SW version LGH870DSAT-00-V20f-AME-XX-JUL-20-2018+0 Android version 8.0.0 LAF Version 1.1 Product ID PT01S180116002284 IMEI 356145-08-485695-7 Target operator GLOBAL Hardware rev_10 Performed by 2.8.9 Software version. Last edited by Octopus box; 11-23-2018 at 21:59. |
11-23-2018, 19:21 | #2 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,412 | So what is the problem exactly? Install the latest Software version from the Support Area (here is direct link for You: https://drive.google.com/open?id=1Je...SifY3RCa7hZDLR) and perform "Reset FRP" operation via Download Mode. Post here the result. |
11-23-2018, 19:25 | #3 (permalink) |
Member: 2550445 Status: Offline Thanks Meter: 26 | LG g6 h870ds frp solve, thanks octopus box... Performed by 2.8.9.8 Software version. Please select Reset FRP Method! -------------------------------------------------------------------------------- Checking data...OK Platform: LG Qualcomm Selected port: COM20 Selected model: H870DS Please, put the phone into download mode manually (Power phone OFF, press and hold "Vol+" button and connect the cable). Reading info... Model ID: LG-H870DS IMEI: 356145-08-485695-7 Android version: 8.0.0 Battery level: 100% SW Version: H87020f Mode: Emergency Initializing flash...OK Platform: msm8996 SW version: LGH870DSAT-00-V20f-AME-XX-JUL-20-2018+0 Android version: 8.0.0 LAF Version: 1.1 Product ID: PT01S180116002284 IMEI: 356145-08-485695-7 Target operator: GLOBAL Hardware: rev_10 Reading partitions...OK Reading BOOT... ID: 0005F0E100310000 Operation is not safe and exist risk to damage the device! Do You want to continue?OK Backup saved to "H870DS_356145084856957_23-11-2018_21-19-58.oct" Switching to Qualcomm 9008 mode... Found port COM22 Connecting...OK Sending loader...OK Reconnecting phone...OK Checking request... Request has been successfully sent! Obtaining response...OK Reading partitions...OK Restoring BOOT...OK Searching signatures... Step 1... Step 2... Step 3... Resetting FRP Lock...OK Resetting FRP lock successfully completed! Rebooting phone... Performed by 2.8.9.8 Software version. |
The Following User Says Thank You to mrmmethun555 For This Useful Post: |
11-23-2018, 19:28 | #4 (permalink) | |
Member: 2550445 Status: Offline Thanks Meter: 26 | is ok now before is dead .. aftar open and again resat is okk Quote:
thanks ...for replay | |
01-16-2019, 18:17 | #5 (permalink) | |
Freak Poster Join Date: Mar 2006
Member: 241855 Status: Offline Sonork: 1623913 Thanks Meter: 89 | Quote:
Welcome to Octoplus/Octopus Box LG Software version 2.9.0 Please, select Reset FRP Method! Opening "H870DS_356145083038698_15-01-2019_16-06-35.oct"... Restore device from backup file? Please, connect the phone... Found port COM200 Connecting...Failed! Performed by 2.9.0 Software version. Please, select Reset FRP Method! Opening "H870DS_356145083038698_15-01-2019_16-06-35.oct"... Restore device from backup file? Please, connect the phone... Found port COM200 Connecting...Failed! Performed by 2.9.0 Software version. I have tried with even latest software in support 2.9.2 had to remove and try 2.9.0 I used Frp tool same fail and can't find any other test software in support I changed usb too and ports and used with PC directly pls how to revive phone back thanks | |
01-17-2019, 09:52 | #6 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,412 | Please, try to do next: 1. Download and install the latest Software version 2. Reboot your device, press Vol- and Vol + with Power button for about 15 sec. 3. Connect your device to PC, open Device manager and check if Qcomm 9008 appeared. 4. Then You can try to restore from backup again. 5. Post here full Software log. Last edited by Octopus box; 01-17-2019 at 10:35. |
