10-20-2018, 13:22 | #1 (permalink) |
No Life Poster Join Date: Jan 2010 Location: iraq
Member: 1215266 Status: Offline Thanks Meter: 129 | H910 unlock question [Answered] -------------------------------------------------------------------------------- Checking data...OK Platform: LG Qualcomm Selected port: COM228 Selected model: H910 Reading info... Could not detect mode! Performed by 2.8.9 Software version. -------------------------------------------------------------------------------- Checking data...OK Platform: LG Qualcomm Selected port: COM228 Selected model: H910 Reading info... Could not detect mode! Performed by 2.8.9 Software version. -------------------------------------------------------------------------------- Checking data...OK Platform: LG Qualcomm Selected port: COM27 Selected model: H910 Reading info... Model ID: LG-H910 IMEI: 351746-08-036267-9 Android version: 7.0 Battery level: 39% SW Version: H91010l Mode: Emergency Initializing flash...OK Platform: msm8996 SW version: LGH910AT-00-V10l-ATT-US-DEC-21-2016-ARB00+0 Android version: 7.0 LAF Version: 1.1 Product ID: YE04S161007000814 IMEI: 351746-08-012862-5 Target operator: ATT Hardware: rev_10 Unlocking... Write security backup function doesn't work for this device with latest firmware versions. If you'll encounter any problem during Unlock operation - you won't be able to restore the phone to it's initial state, so proceed at your own risk. Continue? Switching to Normal mode... Please perform the following steps: 1. Disconnect cable 2. Put phone into Normal mode manually 3. Press "Ok" buttonFailed! Performed by 2.8.9 Software version. Last edited by Octopus box; 10-21-2018 at 10:30. |
10-20-2018, 13:57 | #2 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,413 | Hello. Please, connect the phone in Normal mode, make sure that You rease Software manual attentive, press Cable & Manual button and try to perform Unlock operation again. |
10-20-2018, 14:05 | #4 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,413 | What do You mean exactly? Please, explain the problem in more detail. |
10-20-2018, 14:35 | #7 (permalink) |
Insane Poster Join Date: May 2015 Location: KPK Pakistan
Member: 2395555 Status: Offline Sonork: 100.1681674 Thanks Meter: 33 | Service Disable Problem Fix.... find the Show Hidden Network Option Botton in menu option in android tab.... (Show Hidden Network Option Botton) select any model of lg winch is show that botton working & highlight press Show Hidden Network Botton... its bring the network menu. then select Network mod Automatic.. restart mobile then enjoy |
10-20-2018, 15:08 | #8 (permalink) |
Member: 1215266 Status: Offline Thanks Meter: 129 | Welcome to Octoplus/Octopus Box LG Software version 2.8.9 -------------------------------------------------------------------------------- Checking data...OK Platform: LG Qualcomm Selected port: COM228 Selected model: LS991 Reading info... Initializing ADB...OK ADB Server was found. Trying to kill... Waiting for phone... Please, reconnect phone, enable USB debugging, and try again. To enable USB debugging, please perform the following steps: 1. Disconnect cable 2. Install LG Android ADB drivers 3. Go to "Settings" -> "About phone" -> "Software information" 4. Click on Build number 5 times 5. Enable "Settings" -> "Developer options" -> "USB debugging" option 6. Connect the cable and check, whether ADB interface has appeared in PC Device Manager. Performed by 2.8.9 Software version. -------------------------------------------------------------------------------- Checking data...OK Platform: LG Qualcomm Selected port: COM228 Selected model: LS991 Reading info... Initializing ADB...OK Waiting for phone...OK Model ID: LG-H910 Incompatible model ID! Phone firmware version: LGH910AT-00-V10l-ATT-US-DEC-21-2016- ARB00+0 Kernel version: 3.18.31-perf-g9048bd5 (lgmobile@LGEACI6R2) (gcc version 4.9 20150123 (prerelease) (GCC) ) #1 SMP PREEMPT Wed Dec 21 14:13:13 KST 201 Android version: 7.0 Hardware: Qualcomm Technologies, Inc MSM8996 AArch64 Processor rev 1 (aarch64) Sending exploit...OK Executing exploit...Failed! Performed by 2.8.9 Software version. -------------------------------------------------------------------------------- Checking data...OK Platform: LG Qualcomm Selected port: COM228 Selected model: LS991 Reading info... Initializing ADB...OK Waiting for phone...OK Model ID: Incompatible model ID! Phone firmware version: Kernel version: Android version: Hardware: Opening Mobile Networks Menu...Failed! Performed by 2.8.9 Software version. |
10-20-2018, 15:17 | #9 (permalink) |
Member: 1215266 Status: Offline Thanks Meter: 129 | Welcome to Octoplus/Octopus Box LG Software version 2.8.9 -------------------------------------------------------------------------------- Checking data...OK Platform: LG Qualcomm Selected port: COM228 Selected model: LS991 Reading info... Initializing ADB...OK ADB Server was found. Trying to kill... Waiting for phone... Please, reconnect phone, enable USB debugging, and try again. To enable USB debugging, please perform the following steps: 1. Disconnect cable 2. Install LG Android ADB drivers 3. Go to "Settings" -> "About phone" -> "Software information" 4. Click on Build number 5 times 5. Enable "Settings" -> "Developer options" -> "USB debugging" option 6. Connect the cable and check, whether ADB interface has appeared in PC Device Manager. Performed by 2.8.9 Software version. -------------------------------------------------------------------------------- Checking data...OK Platform: LG Qualcomm Selected port: COM228 Selected model: LS991 Reading info... Initializing ADB...OK Waiting for phone...OK Model ID: LG-H910 Incompatible model ID! Phone firmware version: LGH910AT-00-V10l-ATT-US-DEC-21-2016- ARB00+0 Kernel version: 3.18.31-perf-g9048bd5 (lgmobile@LGEACI6R2) (gcc version 4.9 20150123 (prerelease) (GCC) ) #1 SMP PREEMPT Wed Dec 21 14:13:13 KST 201 Android version: 7.0 Hardware: Qualcomm Technologies, Inc MSM8996 AArch64 Processor rev 1 (aarch64) Sending exploit...OK Executing exploit...Failed! Performed by 2.8.9 Software version. -------------------------------------------------------------------------------- Checking data...OK Platform: LG Qualcomm Selected port: COM228 Selected model: LS991 Reading info... Initializing ADB...OK Waiting for phone...OK Model ID: Incompatible model ID! Phone firmware version: Kernel version: Android version: Hardware: Opening Mobile Networks Menu...Failed! Performed by 2.8.9 Software version. -------------------------------------------------------------------------------- Platform: LG Qualcomm Selected port: COM228 Selected model: LS991 Reading info... Initializing ADB...OK Waiting for phone...OK Model ID: LG-H910 Incompatible model ID! Phone firmware version: LGH910AT-00-V10l-ATT-US-DEC-21-2016- ARB00+0 Kernel version: 3.18.31-perf-g9048bd5 (lgmobile@LGEACI6R2) (gcc version 4.9 20150123 (prerelease) (GCC) ) #1 SMP PREEMPT Wed Dec 21 14:13:13 KST 201 Android version: 7.0 Hardware: Qualcomm Technologies, Inc MSM8996 AArch64 Processor rev 1 (aarch64) Please, type ##3424# to get SPC / MSL / Service Code...OK Go to "Diag" menu and select "Enable" option. Performed by 2.8.9 Software version. -------------------------------------------------------------------------------- Checking data...OK Platform: LG Qualcomm Selected port: COM228 Selected model: H910 Reading info... Could not detect mode! Performed by 2.8.9 Software version. -------------------------------------------------------------------------------- Checking data...OK Platform: LG Qualcomm Selected port: COM228 Selected model: H910 Reading info... Could not detect mode! Performed by 2.8.9 Software version. -------------------------------------------------------------------------------- Checking data...OK Platform: LG Qualcomm Selected port: COM228 Selected model: H910 Reading info... Could not detect mode! Performed by 2.8.9 Software version. Access violation at address 00BD2FE8 in module 'OctoplusLG.exe'. Read of address 0000000C Access violation at address 00BD2FE8 in module 'OctoplusLG.exe'. Read of address 0000000C Access violation at address 00BD2FE8 in module 'OctoplusLG.exe'. Read of address 0000000C Access violation at address 00BD2FE8 in module 'OctoplusLG.exe'. Read of address 0000000C -------------------------------------------------------------------------------- Checking data...OK Platform: LG Qualcomm Selected port: COM228 Selected model: LS450 Reading info... Initializing ADB...OK Waiting for phone...OK Model ID: LG-H910 Incompatible model ID! Phone firmware version: LGH910AT-00-V10l-ATT-US-DEC-21-2016- ARB00+0 Kernel version: 3.18.31-perf-g9048bd5 (lgmobile@LGEACI6R2) (gcc version 4.9 20150123 (prerelease) (GCC) ) #1 SMP PREEMPT Wed Dec 21 14:13:13 KST 201 Android version: 7.0 Hardware: Qualcomm Technologies, Inc MSM8996 AArch64 Processor rev 1 (aarch64) Opening Mobile Networks Menu...OK Performed by 2.8.9 Software version. |
10-20-2018, 15:28 | #10 (permalink) |
Member: 1215266 Status: Offline Thanks Meter: 129 | same problem Welcome to Octoplus/Octopus Box LG Software version 2.8.9 -------------------------------------------------------------------------------- Checking data...OK Platform: LG Qualcomm Selected port: COM228 Selected model: LS991 Reading info... Initializing ADB...OK ADB Server was found. Trying to kill... Waiting for phone... Please, reconnect phone, enable USB debugging, and try again. To enable USB debugging, please perform the following steps: 1. Disconnect cable 2. Install LG Android ADB drivers 3. Go to "Settings" -> "About phone" -> "Software information" 4. Click on Build number 5 times 5. Enable "Settings" -> "Developer options" -> "USB debugging" option 6. Connect the cable and check, whether ADB interface has appeared in PC Device Manager. Performed by 2.8.9 Software version. -------------------------------------------------------------------------------- Checking data...OK Platform: LG Qualcomm Selected port: COM228 Selected model: LS991 Reading info... Initializing ADB...OK Waiting for phone...OK Model ID: LG-H910 Incompatible model ID! Phone firmware version: LGH910AT-00-V10l-ATT-US-DEC-21-2016- ARB00+0 Kernel version: 3.18.31-perf-g9048bd5 (lgmobile@LGEACI6R2) (gcc version 4.9 20150123 (prerelease) (GCC) ) #1 SMP PREEMPT Wed Dec 21 14:13:13 KST 201 Android version: 7.0 Hardware: Qualcomm Technologies, Inc MSM8996 AArch64 Processor rev 1 (aarch64) Sending exploit...OK Executing exploit...Failed! Performed by 2.8.9 Software version. -------------------------------------------------------------------------------- Checking data...OK Platform: LG Qualcomm Selected port: COM228 Selected model: LS991 Reading info... Initializing ADB...OK Waiting for phone...OK Model ID: Incompatible model ID! Phone firmware version: Kernel version: Android version: Hardware: Opening Mobile Networks Menu...Failed! Performed by 2.8.9 Software version. -------------------------------------------------------------------------------- Platform: LG Qualcomm Selected port: COM228 Selected model: LS991 Reading info... Initializing ADB...OK Waiting for phone...OK Model ID: LG-H910 Incompatible model ID! Phone firmware version: LGH910AT-00-V10l-ATT-US-DEC-21-2016- ARB00+0 Kernel version: 3.18.31-perf-g9048bd5 (lgmobile@LGEACI6R2) (gcc version 4.9 20150123 (prerelease) (GCC) ) #1 SMP PREEMPT Wed Dec 21 14:13:13 KST 201 Android version: 7.0 Hardware: Qualcomm Technologies, Inc MSM8996 AArch64 Processor rev 1 (aarch64) Please, type ##3424# to get SPC / MSL / Service Code...OK Go to "Diag" menu and select "Enable" option. Performed by 2.8.9 Software version. -------------------------------------------------------------------------------- Checking data...OK Platform: LG Qualcomm Selected port: COM228 Selected model: H910 Reading info... Could not detect mode! Performed by 2.8.9 Software version. -------------------------------------------------------------------------------- Checking data...OK Platform: LG Qualcomm Selected port: COM228 Selected model: H910 Reading info... Could not detect mode! Performed by 2.8.9 Software version. -------------------------------------------------------------------------------- Checking data...OK Platform: LG Qualcomm Selected port: COM228 Selected model: H910 Reading info... Could not detect mode! Performed by 2.8.9 Software version. Access violation at address 00BD2FE8 in module 'OctoplusLG.exe'. Read of address 0000000C Access violation at address 00BD2FE8 in module 'OctoplusLG.exe'. Read of address 0000000C Access violation at address 00BD2FE8 in module 'OctoplusLG.exe'. Read of address 0000000C Access violation at address 00BD2FE8 in module 'OctoplusLG.exe'. Read of address 0000000C -------------------------------------------------------------------------------- Checking data...OK Platform: LG Qualcomm Selected port: COM228 Selected model: LS450 Reading info... Initializing ADB...OK Waiting for phone...OK Model ID: LG-H910 Incompatible model ID! Phone firmware version: LGH910AT-00-V10l-ATT-US-DEC-21-2016- ARB00+0 Kernel version: 3.18.31-perf-g9048bd5 (lgmobile@LGEACI6R2) (gcc version 4.9 20150123 (prerelease) (GCC) ) #1 SMP PREEMPT Wed Dec 21 14:13:13 KST 201 Android version: 7.0 Hardware: Qualcomm Technologies, Inc MSM8996 AArch64 Processor rev 1 (aarch64) Opening Mobile Networks Menu...OK Performed by 2.8.9 Software version. |
