03-17-2018, 13:19 | #1 (permalink) |
No Life Poster Join Date: Apr 2009 Location: Cuba Age: 45
Member: 1020744 Status: Offline Thanks Meter: 428 | Help with H631 Custom recovery [Solved] .twrp-3.2.1-0-ph2n.img .twrp-3.2.0-0-h631.img .twrp-2.8.7.0-10j.img none of this worked, returns: writing 'recovery'... FAILED (remote: unknown command) all the time. Any idea? thanks Last edited by Octopus box; 03-19-2018 at 13:26. |
03-17-2018, 14:13 | #2 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,407 | Hello. Please, read Software manual attentive, press "Cable & Manual" button, also please post here full Software log, we will check it: To connect the phone in Normal Mode, do the next: 1. Select "File transfer" mode in "Use USB connection for" window, then press "Always" (it's important) 2.Type 277634#*#, go to "Port Check Test" (or "SVC Menu -> Port Check Test") and switch "Port Check Test" to "Enabled". |
03-17-2018, 14:39 | #3 (permalink) | |
Freak Poster Join Date: Apr 2013 Location: Lagos, Nigeria
Member: 1918881 Status: Offline Thanks Meter: 44 | Quote:
C:\Program Files (x86)\Minimal ADB and Fastboot>fastboot flash recovery recovery.img target reported max download size of 268435456 bytes sending 'recovery' (11300 KB)... OKAY [ 0.368s] writing 'recovery'... FAILED (remote: unknown command) finished. total time: 0.373s | |
The Following User Says Thank You to satech_gsm For This Useful Post: |
03-17-2018, 18:26 | #6 (permalink) | |
Member: 1020744 Status: Offline Thanks Meter: 428 | Quote:
