07-23-2015, 11:46 | #1 (permalink) |
Freak Poster Join Date: Nov 2013 Location: India
Member: 2069212 Status: Offline Sonork: 12345678 Thanks Meter: 5 | Help me OCTOPLUS TEAM about lg p925... I have a lg p925 handset, for this i just want to do network unlock, and there is android version 4.0.4... when i connect this in lg octoplus tool like this error showing Platform: LG Infineon Connection mode: Modem Selected model: P925 Initializing device...OK Please, power phone ON, connect P990 cable (with 56k resistor), type 3845#*925#, go to "Port Setting", select "CP Reset" (or "CP Image download") and click "OK"...Canceled! i have done this procedure also team 3845#*925#, go to "Port Setting", select "CP Reset... And when i press cp image dowload is not showing in my phone team... kindly help me team.. |
07-23-2015, 12:15 | #2 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,411 | Hello. Please do the next: 1. Install the latest Software version (Software). 2. Power phone ON. 3. Connect the phone directly to PC motherboard USB port via special LG P990 cable with 56 kOhm resistor inside (don't use any USB hubs or PCI USB extension cards). 4. Type 3845#*925#, go to "Port Setting", select "CP Reset" (or "CP Image download") and click "OK". Try to use different USB ports of PC motherboard for connection. Last edited by Octopus box; 07-24-2015 at 13:27. |
07-24-2015, 13:22 | #3 (permalink) |
Member: 2069212 Status: Offline Sonork: 12345678 Thanks Meter: 5 | Sir i tried in other pc also still same issue, and i am connecting cable to direct hubs, and i am not using pci usb also, and i am using 56 kOhm resistor cable, you are telling i should select "CP Reset" or cp image download, but in my phone only showing cp reset, and not showing cp image download... kindly help me team... |
07-24-2015, 13:31 | #4 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,411 | You should select one of "CP Reset", "CP Image download" options, depending on which one is available, not both. What devices appear in PC Device Manager after You connected the phone directly to PC via P990 cable (with 56kOm resistor) and have selected CP reset? |
07-24-2015, 14:08 | #5 (permalink) |
Member: 2069212 Status: Offline Sonork: 12345678 Thanks Meter: 5 | already i have selected cp reset sir, but its nt connecting... in pc device manager like this showing here is image link http://i59.tinypic.com/6qgl6g.jpg |
07-24-2015, 14:22 | #6 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,411 | Try to use another LG P990 cable with 56 kOhm resistor inside, connect the phone directly to PC motherboard USB port. |
