11-18-2016, 05:15 | #1 (permalink) |
No Life Poster Join Date: Oct 2005 Location: .:Planet Namek:.
Member: 189984 Status: Offline Thanks Meter: 112 | Help Rooting LG G4s Beat H735P Android 6.0 [Solved] I want to unlock this model but root is needed. I´ve tried several rotting methods but all not working, any idea? Checking data...OK Platform: LG Qualcomm Selected port: COM28 Selected model: H735P Reading info... Model ID: LG-H735P IMEI: samusprime Android version: 6.0 Battery level: 90% SW Version: H73520a Mode: Normal Unlocking... Skip Read/Write QCN Do you want to create security backup? Writing security area...Failed! Performed by 2.4.9 Software version. -------------------------------------------------------------------------------- Checking data...OK Platform: LG Qualcomm Selected port: COM28 Selected model: H735P Reading info... Model ID: LG-H735P IMEI: samusprime Android version: 6.0 Battery level: 90% SW Version: H73520a Mode: Normal Unlocking... Skip Read/Write QCN Do you want to create security backup? Switching to Download mode...OK Initializing flash...OK Reading partitions...OK Reading security area...OK Backup saved to "H735P_samusprime_17-11-2016_23-12-29.SEC" Switching to Normal mode... Trying to enable Diagnostics ports... Initializing ADB...OK Waiting for phone... Please, reconnect phone, enable USB debugging, and try again. To enable USB debugging, please perform the following steps: 1. Disconnect cable 2. Install LG Android ADB drivers 3. Go to "Settings" -> "About phone" -> "Software information" 4. Click on Build number 5 times 5. Enable "Settings" -> "Developer options" -> "USB debugging" option 6. Connect the cable and check, whether ADB interface has appeared in PC Device Manager.OK Diagnostics ports are enbled! Switching to Serial Port... Failed! Trying to enable Diagnostics ports... Checking root access... Phone is not rooted. Please, root the phone manually! Please perform the following steps: 1. Disconnect cable 2. Put phone into Normal mode manually 3. Press "Ok" button Trying to enable Diagnostics ports... Failed! Writing security area... Performed by 2.4.9 Software version. Last edited by Octopus box; 12-11-2016 at 07:23. |
11-18-2016, 09:35 | #2 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,412 | Hello. Please, install the latest Software version, then enable "Port check" according to the Software manual: Type 277634#*#, go to "Port Check Test" (or "SVC Menu -> Port Check Test") and switch "Port Check Test" to "Enabled", You don't need to root the phone. |
12-11-2016, 05:38 | #3 (permalink) |
Member: 189984 Status: Offline Thanks Meter: 112 | Tested and Works thanks Octopus Box! Platform: LG Qualcomm Selected port: COM28 Selected model: H735P Reading info... Model ID: LG-H735P IMEI: samusprime Android version: 6.0 Battery level: 100% SW Version: H73520a Trying to enable Diagnostics ports... Found model FAAAANVZ: ÿd at port COM28 Unlocking... Skip Read/Write QCN Do you want to create security backup? Switching to Download mode... OK Initializing flash... OK Reading partitions... OK Reading security area... OK Backup saved to "H735P_samusprime_10-12-2016_15-02-03.SEC" Switching to Normal mode... Found model FAAAANVZ: ÿd at port COM28 Writing security area...OK Rebooting phone... Found model FAAAANVZ: ÿd at port COM28 Phone successfully unlocked! Please, reboot the phone manually. Performed by 2.5.3 Software version. |
