05-14-2020, 07:40 | #2 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,411 | Hello. Please, try to select from the list X420QN model and do Reset FRP operation, but only at your own risk, there is a chance that device can be stuck at logo! Last edited by Octopus box; 05-18-2020 at 08:39. |
09-17-2020, 18:51 | #7 (permalink) |
Freak Poster Join Date: May 2015 Location: Colombia
Member: 2393657 Status: Offline Thanks Meter: 47 | FULL FRP Welcome to Octoplus/Octopus Box LG Software version 3.0.3 Card S/N : 000008XXXX -------------------------------------------------------------------------------- Checking data...OK Platform: LG Qualcomm Selected port: COM77 Selected model: X420QN Please, put the phone into download mode manually (Power phone OFF (reconnect battery), press and hold "Vol+" button and connect the cable (or P999 cable)). Reading info... Model ID: LM-X220MB Incompatible model ID! IMEI: 358853-10-008186-8 Android version: 9 Battery level: 32% Mode: Emergency Initializing flash...OK Platform: msm8937 SW version: LMX220MBAT-02-V20a-310-160-OCT-22-2019- ARB00+0 Android version: 9 LAF Version: 1.1 Product ID: VP01S190718004007 IMEI: 358853-10-008186-8 Target operator: LAO Hardware: rev_10 Reading partitions...OK Connecting to server...OK Octopus smart card is present. Checking smart card...OK Username: MBuuffi12 Authorizing...OK Checking balance...OK Checking operation...OK Sending device information...OK Get credits, needed for current operation...OK Your balance: 100 credits. To perform "Reset FRP" operation you need to have 100 credits. Backup saved to "X420QN_358853100081868_17-09-2020_12- 45-54.oct" Reading partitions...OK Prepairing for change protect status... Reconnecting phone...OK Initializing flash...OK Removing write protection... Reconnecting phone... Please, perform the following steps: 1. Disconnect cable. 2. Wait until phone power ON. 3. Complete all startup settings. 4. Power phone OFF and put it to Download mode. 5. Connect the cable then press "OK" button. Note: If "Ok" button isn't active, then You should reconnect device! Note: If You will cancel operation or it wasn't completed full, the device may not work properly. The operation must be performed and completed according to Software instructions!OK Initializing flash...OK Reading partitions...OK Resetting FRP Lock... Reading partitions...OK Restore write protection... Reconnecting phone...OK Initializing flash...OK Reconnecting phone... Please, perform the following steps: 1. Disconnect cable. 2. Wait until phone power ON. 3. Complete all startup settings. 4. Power phone OFF and put it to Download mode. 5. Connect the cable then press "OK" button. Note: If "Ok" button isn't active, then You should reconnect device! Note: If You will cancel operation or it wasn't completed full, the device may not work properly. The operation must be performed and completed according to Software instructions!OK Initializing flash...OK Reading partitions...OK Resetting FRP lock successfully completed! Performed by 3.0.3 Software version. |
The Following User Says Thank You to soowil For This Useful Post: |
