08-23-2016, 12:10 | #1 (permalink) |
No Life Poster Join Date: Dec 2010 Location: pakistan
Member: 1456426 Status: Offline Sonork: 100.1625000 Thanks Meter: 104 | how to unlock -------------------------------------------------------------------------------- Platform: LG Qualcomm Selected port: COM86 Selected model: F320K Reading info... Model ID: LG-F320K IMEI: 356457-05-205263-8 Android version: 5.0.1 Battery level: 37% Mode: Normal Performed by 2.3.9 software version. -------------------------------------------------------------------------------- Checking data...OK Platform: LG Qualcomm Selected port: COM86 Selected model: F320K Reading info... Model ID: LG-F320K IMEI: 356457-05-205263-8 Android version: 5.0.1 Battery level: 37% Trying to enable Diagnostics ports... Initializing ADB...OK Waiting for phone... Please, reconnect phone, enable USB debugging, and try again. To enable USB debugging, please perform the following steps: 1. Disconnect cable 2. Install LG Android ADB drivers 3. Go to "Settings" -> "About phone" -> "Software information" 4. Click on Build number 5 times 5. Enable "Settings" -> "Developer options" -> "USB debugging" option 6. Connect the cable and check, whether ADB interface has appeared in PC Device Manager. Performed by 2.3.9 software version. -------------------------------------------------------------------------------- Platform: LG Qualcomm Selected port: COM54 Selected model: F320K Reading info... Could not detect mode! Performed by 2.3.9 software version. -------------------------------------------------------------------------------- Platform: LG Qualcomm Selected port: COM86 Selected model: F320K Reading info... Model ID: LG-F320K IMEI: 356457-05-205263-8 Android version: 5.0.1 Battery level: 38% Mode: Normal Performed by 2.3.9 software version. -------------------------------------------------------------------------------- Checking data...OK Platform: LG Qualcomm Selected port: COM86 Selected model: F320K Reading info... Model ID: LG-F320K IMEI: 356457-05-205263-8 Android version: 5.0.1 Battery level: 38% Trying to enable Diagnostics ports... Initializing ADB...OK Waiting for phone... Please, reconnect phone, enable USB debugging, and try again. To enable USB debugging, please perform the following steps: 1. Disconnect cable 2. Install LG Android ADB drivers 3. Go to "Settings" -> "About phone" -> "Software information" 4. Click on Build number 5 times 5. Enable "Settings" -> "Developer options" -> "USB debugging" option 6. Connect the cable and check, whether ADB interface has appeared in PC Device Manager.Canceled! Performed by 2.3.9 software version. -------------------------------------------------------------------------------- Platform: LG Qualcomm Selected port: COM86 Selected model: F320K Reading info... Model ID: LG-F320K IMEI: 356457-05-205263-8 Android version: 5.0.1 Battery level: 38% Mode: Normal Performed by 2.3.9 software version. -------------------------------------------------------------------------------- Checking data...OK Platform: LG Qualcomm Selected port: COM86 Selected model: F320K Reading info... Model ID: LG-F320K IMEI: 356457-05-205263-8 Android version: 5.0.1 Battery level: 38% Trying to enable Diagnostics ports... Initializing ADB...OK Waiting for phone... Please, reconnect phone, enable USB debugging, and try again. To enable USB debugging, please perform the following steps: 1. Disconnect cable 2. Install LG Android ADB drivers 3. Go to "Settings" -> "About phone" -> "Software information" 4. Click on Build number 5 times 5. Enable "Settings" -> "Developer options" -> "USB debugging" option 6. Connect the cable and check, whether ADB interface has appeared in PC Device Manager. Performed by 2.3.9 software version. -------------------------------------------------------------------------------- Platform: LG Qualcomm Selected port: COM86 Selected model: F320K Reading info... Model ID: LG-F320K IMEI: 356457-05-205263-8 Android version: 5.0.1 Battery level: 42% Mode: Emergency Initializing flash...OK SW version: LGF320KAT-00-V30d-KT-KR-JAN-07-2015+0 LAF Version: 1.1 Product ID: PT03S131114002160 IMEI: 356457-05-205263-8 Target operator: KT Hardware: rev_10 Performed by 2.3.9 software version. -------------------------------------------------------------------------------- Checking data...OK Platform: LG Qualcomm Selected port: COM86 Selected model: F320K Reading info... Model ID: LG-F320K IMEI: 356457-05-205263-8 Android version: 5.0.1 Battery level: 42% Mode: Emergency Initializing flash...OK SW version: LGF320KAT-00-V30d-KT-KR-JAN-07-2015+0 LAF Version: 1.1 Product ID: PT03S131114002160 IMEI: 356457-05-205263-8 Target operator: KT Hardware: rev_10 Opening "F320K30D_00 5.0.1 Lollipop.oct"...OK Setting options...OK Reading partitions...OK Formating USERDATA...OK Writing PrimaryGPT...OK Writing modem...OK Writing sbl1...OK Writing dbi...OK Writing aboot...OK Writing rpm...OK Writing boot...OK Writing tz...OK Writing persist...OK Writing recovery...OK Writing laf...OK Writing system...OK Writing BackupGPT...OK Reading partitions...OK Formating RCT...OK Formating MPT...OK Finalizing...OK Writing firmware done! Performed by 2.3.9 software version. -------------------------------------------------------------------------------- Platform: LG Qualcomm Selected port: COM86 Selected model: F320K Reading info... Model ID: LG-F320K IMEI: 356457-05-205263-8 Android version: 5.0.1 Battery level: 18% Mode: Normal Performed by 2.3.9 software version. -------------------------------------------------------------------------------- Checking data...OK Platform: LG Qualcomm Selected port: COM86 Selected model: F320K Reading info... Model ID: LG-F320K IMEI: 356457-05-205263-8 Android version: 5.0.1 Battery level: 18% Trying to enable Diagnostics ports... Initializing ADB...OK Waiting for phone... Please, reconnect phone, enable USB debugging, and try again. To enable USB debugging, please perform the following steps: 1. Disconnect cable 2. Install LG Android ADB drivers 3. Go to "Settings" -> "About phone" -> "Software information" 4. Click on Build number 5 times 5. Enable "Settings" -> "Developer options" -> "USB debugging" option 6. Connect the cable and check, whether ADB interface has appeared in PC Device Manager. |
08-23-2016, 13:06 | #2 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,411 | Hello. Please install "LG United Mobile Driver v 3.6" and "LG Android ADB Driver" drivers, then restart PC. http://octopusbox.com/files/drivers/...QL_Ver_3.6.exe, http://octoplusbox.com/files/drivers...dADBDriver.exe Also, You need to enabled USB Debugging, as it prompted by Software. |
