02-08-2015, 21:43 | #1 (permalink) |
No Life Poster Join Date: Mar 2012 Location: mediouna
Member: 1736062 Status: Offline Thanks Meter: 55 | How to unlock lg d505 [Solved] Checking data...OK Platform: LG Qualcomm Selected port: COM46 Selected model: D505 Reading info...OK Mode: Normal Model ID: LGD505 Firmware compiled date: Jun 25 2014 Firmware compiled time: 18:25:19 Firmware released date: Jun 25 2014 Firmware released time: 18:25:19 SW Version: LGD505 IMEI: 358950-05-117332-0 SPC: 000000 Unlocking... Initializing ADB...OK ADB Server was found. Trying to kill... Waiting for phone...Failed! Please, reconnect phone, enable USB debugging, and try again. To enable USB debugging, please perform the following steps: 1. Disconnect cable 2. Install LG Android ADB drivers 3. Enable "Settings" -> "Developer options" -> "USB debugging" option 4. Connect cable and check if ADB interface has appeared in PC Device Manager. Last edited by Octopus box; 02-10-2015 at 13:38. |
02-09-2015, 07:14 | #2 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,389 | Disconnect all other devices from PC, reboot the PC, re-start the phone, turn on USB Debugging Mode in the phone and repeat the Unlock operation again. Try to connect the phone directly to another USB motherboard USB port, don't use any USB hubs, this is important. |
02-09-2015, 17:10 | #4 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,389 | Reinstall required drivers and restart PC. LG United Mobile Driver v 3.6: http://octopusbox.com/files/drivers/...QL_Ver_3.6.exe Android ADB Driver http://octoplusbox.com/files/drivers...dADBDriver.exe Close all third party Software and repeat the operation. If problem will remain - try to perform the operation on another, clean (with only necessary drivers and Software) PC. |
02-10-2015, 13:12 | #5 (permalink) |
Member: 1736062 Status: Offline Thanks Meter: 55 | The problem was in the 4.4.2 firmware downgrade to 4.1.2 firmware and root Octopus Box Thank you my brother DZ-Developer جمال الدين Welcome to Octoplus/Octopus Box LG Software version 1.8.4 Converting files... Unpacking "PrimaryGPT"...OK Unpacking "modem"...OK Unpacking "sbl1"...OK Unpacking "sbl2"...OK Unpacking "sbl3"...OK Unpacking "aboot"...OK Unpacking "rpm"...OK Unpacking "boot"...OK Unpacking "tz"...OK Unpacking "system"...OK Unpacking "system"...OK Unpacking "system"...OK Unpacking "system"...OK Unpacking "system"...OK Unpacking "system"...OK Unpacking "system"...OK Unpacking "system"...OK Unpacking "system"...OK Unpacking "system"...OK Unpacking "system"...OK Unpacking "system"...OK Unpacking "system"...OK Unpacking "system"...OK Unpacking "system"...OK Unpacking "system"...OK Unpacking "system"...OK Unpacking "system"...OK Unpacking "system"...OK Unpacking "system"...OK Unpacking "system"...OK Unpacking "system"...OK Unpacking "system"...OK Unpacking "cache"...OK Unpacking "cache"...OK Unpacking "cache"...OK Unpacking "cache"...OK Unpacking "cache"...OK Unpacking "cache"...OK Unpacking "cache"...OK Unpacking "userdata"...OK Unpacking "userdata"...OK Unpacking "userdata"...OK Unpacking "userdata"...OK Unpacking "userdata"...OK Unpacking "userdata"...OK Unpacking "userdata"...OK Unpacking "userdata"...OK Unpacking "userdata"...OK Unpacking "userdata"...OK Unpacking "BackupGPT"...OK Unpacking "userdata"...OK Unpacking "userdata"...OK Unpacking "userdata"...OK Unpacking "userdata"...OK Unpacking "userdata"...OK Unpacking "userdata"...OK Unpacking "userdata"...OK Unpacking "userdata"...OK Unpacking "userdata"...OK Unpacking "userdata"...OK Unpacking "userdata"...OK Unpacking "userdata"...OK Unpacking "userdata"...OK Unpacking "userdata"...OK Unpacking "userdata"...OK Unpacking "userdata"...OK Unpacking "userdata"...OK Unpacking "userdata"...OK Unpacking "userdata"...OK Unpacking "userdata"...OK Unpacking "userdata"...OK Unpacking "userdata"...OK Unpacking "userdata"...OK Unpacking "userdata"...OK Unpacking "userdata"...OK Unpacking "userdata"...OK Unpacking "userdata"...OK Unpacking "userdata"...OK Unpacking "userdata"...OK Unpacking "persist"...OK Unpacking "recovery"...OK Unpacking done. Processing files... Identifying sub-files...OK Creating destination file...OK Deleting temporary files... Deleting directory "C:\DOCUME~1\ADMINI~1\LOCALS~1\Temp \LGD505AT-00-V10a-EUR-XX-AUG-15-2013+0\"... Deleting file "C:\DOCUME~1\ADMINI~1\LOCALS~1\Temp \LGD505AT-00-V10a-EUR-XX-AUG-15-2013+0\aboot.bin"...OK Deleting file "C:\DOCUME~1\ADMINI~1\LOCALS~1\Temp \LGD505AT-00-V10a-EUR-XX-AUG-15-2013+0 \BackupGPT.bin"...OK Deleting file "C:\DOCUME~1\ADMINI~1\LOCALS~1\Temp \LGD505AT-00-V10a-EUR-XX-AUG-15-2013+0\boot.bin"...OK Deleting file "C:\DOCUME~1\ADMINI~1\LOCALS~1\Temp \LGD505AT-00-V10a-EUR-XX-AUG-15-2013+0\cache.bin"...OK Deleting file "C:\DOCUME~1\ADMINI~1\LOCALS~1\Temp \LGD505AT-00-V10a-EUR-XX-AUG-15-2013+0\modem.bin"...OK Deleting file "C:\DOCUME~1\ADMINI~1\LOCALS~1\Temp \LGD505AT-00-V10a-EUR-XX-AUG-15-2013+0\parts.bin"...OK Deleting file "C:\DOCUME~1\ADMINI~1\LOCALS~1\Temp \LGD505AT-00-V10a-EUR-XX-AUG-15-2013+0\persist.bin"...OK Deleting file "C:\DOCUME~1\ADMINI~1\LOCALS~1\Temp \LGD505AT-00-V10a-EUR-XX-AUG-15-2013+0 \PrimaryGPT.bin"...OK Deleting file "C:\DOCUME~1\ADMINI~1\LOCALS~1\Temp \LGD505AT-00-V10a-EUR-XX-AUG-15-2013+0\recovery.bin"...OK Deleting file "C:\DOCUME~1\ADMINI~1\LOCALS~1\Temp \LGD505AT-00-V10a-EUR-XX-AUG-15-2013+0\rpm.bin"...OK Deleting file "C:\DOCUME~1\ADMINI~1\LOCALS~1\Temp \LGD505AT-00-V10a-EUR-XX-AUG-15-2013+0\sbl1.bin"...OK Deleting file "C:\DOCUME~1\ADMINI~1\LOCALS~1\Temp \LGD505AT-00-V10a-EUR-XX-AUG-15-2013+0\sbl2.bin"...OK Deleting file "C:\DOCUME~1\ADMINI~1\LOCALS~1\Temp \LGD505AT-00-V10a-EUR-XX-AUG-15-2013+0\sbl3.bin"...OK Deleting file "C:\DOCUME~1\ADMINI~1\LOCALS~1\Temp \LGD505AT-00-V10a-EUR-XX-AUG-15-2013+0\system.bin"...OK Deleting file "C:\DOCUME~1\ADMINI~1\LOCALS~1\Temp \LGD505AT-00-V10a-EUR-XX-AUG-15-2013+0\tz.bin"...OK Deleting file "C:\DOCUME~1\ADMINI~1\LOCALS~1\Temp \LGD505AT-00-V10a-EUR-XX-AUG-15-2013+0\userdata.bin"...OK Directory "C:\DOCUME~1\ADMINI~1\LOCALS~1\Temp\LGD505AT- 00-V10a-EUR-XX-AUG-15-2013+0\" succesfully deleted! Firmware convert done! -------------------------------------------------------------------------------- Checking data...OK Platform: LG Qualcomm Selected port: COM74 Selected model: D505 Reading info...OK Mode: Emergency Model ID: BS/LGD505/181100 SW version: LGD505AT-00-V20b-EUR-XX-JUN-25-2014+0 Product ID: CT65S140312002493 IMEI: 358950-05-117332-0 Opening "LGD505AT-00-V10a-EUR-XX-AUG-15-2013+0.oct"...OK Initializing flash...OK Testing connection...OK Writing modem...OK Writing sbl1...OK Writing sbl2...OK Writing sbl3...OK Writing aboot...OK Writing rpm...OK Writing boot...OK Writing tz...OK Writing system...OK Writing cache...OK Writing userdata...OK Writing persist...OK Writing recovery...OK Writing BackupGPT...OK Finalizing...OK Writing firmware done! -------------------------------------------------------------------------------- Platform: LG Qualcomm Selected port: COM3 Selected model: D505 Reading info...Failed! Could not detect mode! -------------------------------------------------------------------------------- Platform: LG Qualcomm Selected port: COM74 Selected model: D505 Reading info...OK Mode: Normal Model ID: LGD505 Firmware compiled date: Aug 13 2013 Firmware compiled time: 19:48:56 Firmware released date: Aug 13 2013 Firmware released time: 19:48:56 SW Version: LGD505 IMEI: 358950-05-117332-0 SPC: 000000 -------------------------------------------------------------------------------- Platform: LG Qualcomm Selected port: COM74 Selected model: D505 Reading info...OK Mode: Normal Model ID: LGD505 Firmware compiled date: Aug 13 2013 Firmware compiled time: 19:48:56 Firmware released date: Aug 13 2013 Firmware released time: 19:48:56 SW Version: LGD505 IMEI: 358950-05-117332-0 SPC: 000000 Initializing ADB...OK ADB Server was found. Trying to kill... Waiting for phone...OK Checking root access... Phone is not rooted. Sending exploit...OK Press "Grant" button on the phone every time when superuser dialog appears Checking root access... Phone is already rooted. Root access garanted! -------------------------------------------------------------------------------- Checking data...OK Platform: LG Qualcomm Selected port: COM74 Selected model: D505 Reading info...OK Mode: Normal Model ID: LGD505 Firmware compiled date: Aug 13 2013 Firmware compiled time: 19:48:56 Firmware released date: Aug 13 2013 Firmware released time: 19:48:56 SW Version: LGD505 IMEI: 358950-05-117332-0 SPC: 000000 Unlocking... Initializing ADB...OK Waiting for phone...OK Checking root access... Phone is already rooted. Skip Read/Write QCN Reading partition...OK Reading security area...OK Backup saved to "D505_358950051173320_10-02-2015_13-02- 26.SEC" Analyzing security...OK Rebooting phone... Found model LGD505 at port COM74 Phone successfully unlocked! Rebooting phone... |
