08-07-2017, 07:00 | #1 (permalink) |
No Life Poster Join Date: Aug 2007 Location: on forum
Member: 566122 Status: Offline Thanks Meter: 322 | How to unlock lg ls-980 [Solved] Welcome to Octoplus/Octopus Box LG Software version 2.7.0 -------------------------------------------------------------------------------- Platform: LG Qualcomm Selected port: COM8 Selected model: LS980 Reading info...Failed! Port busy Initializing ADB...OK Waiting for phone... Please, reconnect phone, enable USB debugging, and try again. To enable USB debugging, please perform the following steps: 1. Disconnect cable 2. Install LG Android ADB drivers 3. Go to "Settings" -> "About phone" -> "Software information" 4. Click on Build number 5 times 5. Enable "Settings" -> "Developer options" -> "USB debugging" option 6. Connect the cable and check, whether ADB interface has appeared in PC Device Manager.Failed! Please, reconnect phone, enable USB debugging, and try again. To enable USB debugging, please perform the following steps: 1. Disconnect cable 2. Install LG Android ADB drivers 3. Go to "Settings" -> "About phone" -> "Software information" 4. Click on Build number 5 times 5. Enable "Settings" -> "Developer options" -> "USB debugging" option 6. Connect the cable and check, whether ADB interface has appeared in PC Device Manager. Performed by 2.7.0 Software version. -------------------------------------------------------------------------------- Platform: LG Qualcomm Selected port: COM8 Selected model: LS980 Reading info...Failed! Port busy Initializing ADB...OK Waiting for phone...OK Model ID: LG-LS980 Phone firmware version: LS980ZVE_03 Kernel version: 3.4.0-perf-gbb21862 (lgmobile@LGEACI1R9) (gcc version 4.7 (GCC) ) #1 SMP PREEMPT Tue Sep 16 13:17:20 KST 201 Android version: 4.4.2 Hardware: Qualcomm MSM 8974 (Flattened Device Tree) ARMv7 Processor rev 0 (v7l) Please, type ##3424# to get SPC / MSL / Service Code...OK Go to "Diag" menu and select "Enable" option. Performed by 2.7.0 Software version. -------------------------------------------------------------------------------- Checking data...OK Platform: LG Qualcomm Selected port: COM8 Selected model: LS980 Reading info...Failed! Port busy Initializing ADB...OK Waiting for phone... Please, reconnect phone, enable USB debugging, and try again. To enable USB debugging, please perform the following steps: 1. Disconnect cable 2. Install LG Android ADB drivers 3. Go to "Settings" -> "About phone" -> "Software information" 4. Click on Build number 5 times 5. Enable "Settings" -> "Developer options" -> "USB debugging" option 6. Connect the cable and check, whether ADB interface has appeared in PC Device Manager.Failed! Please, reconnect phone, enable USB debugging, and try again. To enable USB debugging, please perform the following steps: 1. Disconnect cable 2. Install LG Android ADB drivers 3. Go to "Settings" -> "About phone" -> "Software information" 4. Click on Build number 5 times 5. Enable "Settings" -> "Developer options" -> "USB debugging" option 6. Connect the cable and check, whether ADB interface has appeared in PC Device Manager. Performed by 2.7.0 Software version. -------------------------------------------------------------------------------- Checking data...OK Platform: LG Qualcomm Selected port: COM8 Selected model: LS980 Reading info...Failed! Port busy Initializing ADB...OK Waiting for phone... Please, reconnect phone, enable USB debugging, and try again. To enable USB debugging, please perform the following steps: 1. Disconnect cable 2. Install LG Android ADB drivers 3. Go to "Settings" -> "About phone" -> "Software information" 4. Click on Build number 5 times 5. Enable "Settings" -> "Developer options" -> "USB debugging" option 6. Connect the cable and check, whether ADB interface has appeared in PC Device Manager. Performed by 2.7.0 Software version. -------------------------------------------------------------------------------- Checking data...OK Platform: LG Qualcomm Selected port: COM8 Selected model: LS980 Reading info...Failed! Port busy Initializing ADB...OK Waiting for phone...OK Model ID: LG-LS980 Phone firmware version: LS980ZVE_03 Kernel version: 3.4.0-perf-gbb21862 (lgmobile@LGEACI1R9) (gcc version 4.7 (GCC) ) #1 SMP PREEMPT Tue Sep 16 13:17:20 KST 201 Android version: 4.4.2 Hardware: Qualcomm MSM 8974 (Flattened Device Tree) ARMv7 Processor rev 0 (v7l) Please, type ##3424# to get SPC / MSL / Service Code...OK Go to "Diag" menu and select "Enable" option. Performed by 2.7.0 Software version. waiting for kind replies ,,,from supporters ,,, Last edited by Octopus box; 08-07-2017 at 09:08. |
08-07-2017, 07:24 | #2 (permalink) |
Member: 566122 Status: Offline Thanks Meter: 322 | this one is the screen shot of my problem -" http://imageshack.com/i/pm3jmfxvp[/EMAIL]"]http://imageshack.com/i/pm3jmfxvp waiting for kind replies |
08-07-2017, 08:17 | #4 (permalink) | |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,412 | Hello. 1. Remove SD and SIM cards from the phone; 2. Go to "Settings" -> "About phone" -> "Software information"; 3. Click on Build number 5 times; 4. Enable USB debugging ("Settings" -> "Developer options" -> "USB Debugging"); 5. Connect powered-on phone directly to USB port of PC motherboard. Don't use any kind of USB hubs for connection; 6. Install necessary driver; 7. Click "Unlock" button; 8. Follow software instructions (prompts). Note: To connect the phone in Normal Mode You nee to select "Charge Phone" in "USB PC Connection" menu. Also, make sure that You have installed necessary drivers: http://octopusbox.com/files/drivers/..._ver_3.8.1.rar, http://octoplusbox.com/files/drivers...dADBDriver.exe Quote:
