07-02-2016, 04:50 | #1 (permalink) |
Freak Poster Join Date: Feb 2011
Member: 1514778 Status: Offline Thanks Meter: 48 | I bricked an LG LS770 after converting ZV8 tot into an OCT file and flashed |
07-02-2016, 09:08 | #3 (permalink) |
Member: 1514778 Status: Offline Thanks Meter: 48 | Oukay, that is going to be difficult, it was like a week ago. Where should i look for that log? From a week ago? Also, is in terms of knowing what happened right? I guess to check if it was an Octoplus bug or if it was something else? Since i wont be able to resurrect that phone anyway. Anyway, for the sake of progress i will try to |
07-02-2016, 09:10 | #4 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,413 | To know exactly the reason we need to check Software log, You can find it by this path: C:\Program Files (x86)\Octoplus\Octoplus_LG\LOG sort files by date. |
07-02-2016, 09:16 | #5 (permalink) |
Member: 1514778 Status: Offline Thanks Meter: 48 | Ok so my guess is that this is the file convertion proccess. Log file "C:\Program Files (x86)\Octoplus\Octoplus_LG\LOG\11-06-2016_01-15-23.log" created. 6/11/2016 1:15:30 AM > Welcome to Octoplus/Octopus Box LG Software version 2.3.4 6/11/2016 1:17:10 AM > Converting files... 6/11/2016 1:17:10 AM > Unpacking "PrimaryGPT"...6/11/2016 1:17:10 AM > OK 6/11/2016 1:17:10 AM > Unpacking "sbl1"...6/11/2016 1:17:10 AM > OK 6/11/2016 1:17:10 AM > Unpacking "tz"...6/11/2016 1:17:10 AM > OK 6/11/2016 1:17:10 AM > Unpacking "hyp"...6/11/2016 1:17:10 AM > OK 6/11/2016 1:17:10 AM > Unpacking "rpm"...6/11/2016 1:17:10 AM > OK 6/11/2016 1:17:10 AM > Unpacking "aboot"...6/11/2016 1:17:10 AM > OK 6/11/2016 1:17:10 AM > Unpacking "sbl1bak"...6/11/2016 1:17:10 AM > OK 6/11/2016 1:17:10 AM > Unpacking "tzbak"...6/11/2016 1:17:10 AM > OK 6/11/2016 1:17:10 AM > Unpacking "hypbak"...6/11/2016 1:17:10 AM > OK 6/11/2016 1:17:11 AM > Unpacking "rpmbak"...6/11/2016 1:17:11 AM > OK 6/11/2016 1:17:11 AM > Unpacking "abootbak"...6/11/2016 1:17:11 AM > OK 6/11/2016 1:17:11 AM > Unpacking "persist"...6/11/2016 1:17:11 AM > OK 6/11/2016 1:17:11 AM > Unpacking "metadata"...6/11/2016 1:17:11 AM > OK 6/11/2016 1:17:11 AM > Unpacking "laf"...6/11/2016 1:17:11 AM > OK 6/11/2016 1:17:11 AM > Unpacking "boot"...6/11/2016 1:17:12 AM > OK 6/11/2016 1:17:12 AM > Unpacking "recovery"...6/11/2016 1:17:12 AM > OK 6/11/2016 1:17:12 AM > Unpacking "sec"...6/11/2016 1:17:12 AM > OK 6/11/2016 1:17:12 AM > Unpacking "factory"...6/11/2016 1:17:12 AM > OK 6/11/2016 1:17:12 AM > Unpacking "modem"...6/11/2016 1:17:13 AM > OK 6/11/2016 1:17:13 AM > Unpacking "pad2"...6/11/2016 1:17:13 AM > OK 6/11/2016 1:17:13 AM > Unpacking "carrier"...6/11/2016 1:17:14 AM > OK 6/11/2016 1:17:14 AM > Unpacking "system"...6/11/2016 1:18:35 AM > OK 6/11/2016 1:18:35 AM > Unpacking done. Processing files... 6/11/2016 1:18:35 AM > Identifying sub-files...6/11/2016 1:18:35 AM > OK 6/11/2016 1:18:35 AM > Creating destination file...6/11/2016 1:21:18 AM > OK 6/11/2016 1:21:18 AM > Deleting temporary files... 6/11/2016 1:21:18 AM > Deleting directory "C:\Users\ARTURO~1\AppData\Local\Temp\LS770_ZV7\". .. 6/11/2016 1:21:18 AM > Deleting file "C:\Users\ARTURO~1\AppData\Local\Temp\LS770_ZV7\ab oot"...6/11/2016 1:21:18 AM > OK 6/11/2016 1:21:18 AM > Deleting file "C:\Users\ARTURO~1\AppData\Local\Temp\LS770_ZV7\ab ootbak"...6/11/2016 1:21:18 AM > OK 6/11/2016 1:21:18 AM > Deleting file "C:\Users\ARTURO~1\AppData\Local\Temp\LS770_ZV7\bo ot"...6/11/2016 1:21:18 AM > OK 6/11/2016 1:21:18 AM > Deleting file "C:\Users\ARTURO~1\AppData\Local\Temp\LS770_ZV7\ca rrier"...6/11/2016 1:21:18 AM > OK 6/11/2016 1:21:18 AM > Deleting file "C:\Users\ARTURO~1\AppData\Local\Temp\LS770_ZV7\fa ctory"...6/11/2016 1:21:18 AM > OK 6/11/2016 1:21:18 AM > Deleting file "C:\Users\ARTURO~1\AppData\Local\Temp\LS770_ZV7\hy p"...6/11/2016 1:21:18 AM > OK 6/11/2016 1:21:18 AM > Deleting file "C:\Users\ARTURO~1\AppData\Local\Temp\LS770_ZV7\hy pbak"...6/11/2016 1:21:18 AM > OK 6/11/2016 1:21:18 AM > Deleting file "C:\Users\ARTURO~1\AppData\Local\Temp\LS770_ZV7\la f"...6/11/2016 1:21:18 AM > OK 6/11/2016 1:21:18 AM > Deleting file "C:\Users\ARTURO~1\AppData\Local\Temp\LS770_ZV7\me tadata"...6/11/2016 1:21:18 AM > OK 6/11/2016 1:21:18 AM > Deleting file "C:\Users\ARTURO~1\AppData\Local\Temp\LS770_ZV7\mo dem"...6/11/2016 1:21:18 AM > OK 6/11/2016 1:21:18 AM > Deleting file "C:\Users\ARTURO~1\AppData\Local\Temp\LS770_ZV7\pa d2"...6/11/2016 1:21:18 AM > OK 6/11/2016 1:21:18 AM > Deleting file "C:\Users\ARTURO~1\AppData\Local\Temp\LS770_ZV7\pa rts.bin"...6/11/2016 1:21:18 AM > OK 6/11/2016 1:21:18 AM > Deleting file "C:\Users\ARTURO~1\AppData\Local\Temp\LS770_ZV7\pe rsist"...6/11/2016 1:21:18 AM > OK 6/11/2016 1:21:18 AM > Deleting file "C:\Users\ARTURO~1\AppData\Local\Temp\LS770_ZV7\Pr imaryGPT"...6/11/2016 1:21:18 AM > OK 6/11/2016 1:21:18 AM > Deleting file "C:\Users\ARTURO~1\AppData\Local\Temp\LS770_ZV7\re covery"...6/11/2016 1:21:18 AM > OK 6/11/2016 1:21:18 AM > Deleting file "C:\Users\ARTURO~1\AppData\Local\Temp\LS770_ZV7\rp m"...6/11/2016 1:21:19 AM > OK 6/11/2016 1:21:19 AM > Deleting file "C:\Users\ARTURO~1\AppData\Local\Temp\LS770_ZV7\rp mbak"...6/11/2016 1:21:19 AM > OK 6/11/2016 1:21:19 AM > Deleting file "C:\Users\ARTURO~1\AppData\Local\Temp\LS770_ZV7\sb l1"...6/11/2016 1:21:19 AM > OK 6/11/2016 1:21:19 AM > Deleting file "C:\Users\ARTURO~1\AppData\Local\Temp\LS770_ZV7\sb l1bak"...6/11/2016 1:21:19 AM > OK 6/11/2016 1:21:19 AM > Deleting file "C:\Users\ARTURO~1\AppData\Local\Temp\LS770_ZV7\se c"...6/11/2016 1:21:19 AM > OK 6/11/2016 1:21:19 AM > Deleting file "C:\Users\ARTURO~1\AppData\Local\Temp\LS770_ZV7\sy stem"...6/11/2016 1:21:19 AM > OK 6/11/2016 1:21:19 AM > Deleting file "C:\Users\ARTURO~1\AppData\Local\Temp\LS770_ZV7\tz "...6/11/2016 1:21:19 AM > OK 6/11/2016 1:21:19 AM > Deleting file "C:\Users\ARTURO~1\AppData\Local\Temp\LS770_ZV7\tz bak"...6/11/2016 1:21:19 AM > OK 6/11/2016 1:21:19 AM > Directory "C:\Users\ARTURO~1\AppData\Local\Temp\LS770_ZV 7\" succesfully deleted! 6/11/2016 1:21:19 AM > Firmware convert done! 6/11/2016 1:22:16 AM > -------------------------------------------------------------------------------- 6/11/2016 1:22:16 AM > Checking data...6/11/2016 1:22:17 AM > OK 6/11/2016 1:22:17 AM > Platform: LG Qualcomm 6/11/2016 1:22:17 AM > Selected port: COM14 6/11/2016 1:22:17 AM > Selected model: LS770 6/11/2016 1:22:17 AM > Reading info... 6/11/2016 1:22:20 AM > Model ID: LGLS770 6/11/2016 1:22:20 AM > IMEI: 350305-26-000000-4 6/11/2016 1:22:20 AM > Android version: 5.1.1 6/11/2016 1:22:20 AM > Battery level: 100% 6/11/2016 1:22:22 AM > Mode: Emergency 6/11/2016 1:22:22 AM > Initializing flash...6/11/2016 1:22:24 AM > OK 6/11/2016 1:22:25 AM > SW version: LS770ZV8_06 6/11/2016 1:22:25 AM > LAF Version: 1.1 6/11/2016 1:22:25 AM > Product ID: CH32S151201003688 6/11/2016 1:22:25 AM > IMEI: 356434-07-078613-3 6/11/2016 1:22:25 AM > Target operator: SPR 6/11/2016 1:22:25 AM > Hardware: rev_10 6/11/2016 1:22:25 AM > Opening "LS770_ZV7.oct"...6/11/2016 1:22:25 AM > OK 6/11/2016 1:22:25 AM > Setting options...6/11/2016 1:22:27 AM > OK 6/11/2016 1:22:27 AM > Reading partitions...6/11/2016 1:22:29 AM > OK 6/11/2016 1:22:29 AM > Formating USERDATA...6/11/2016 1:22:33 AM > OK 6/11/2016 1:22:33 AM > Writing PrimaryGPT...6/11/2016 1:22:34 AM > OK 6/11/2016 1:22:34 AM > Writing sbl1...6/11/2016 1:22:34 AM > OK 6/11/2016 1:22:34 AM > Writing tz...6/11/2016 1:22:34 AM > OK 6/11/2016 1:22:34 AM > Writing hyp...6/11/2016 1:22:35 AM > OK 6/11/2016 1:22:35 AM > Writing rpm...6/11/2016 1:22:35 AM > OK 6/11/2016 1:22:35 AM > Writing aboot...6/11/2016 1:22:36 AM > OK 6/11/2016 1:22:36 AM > Writing sbl1bak...6/11/2016 1:22:36 AM > OK 6/11/2016 1:22:36 AM > Writing tzbak...6/11/2016 1:22:36 AM > OK 6/11/2016 1:22:36 AM > Writing hypbak...6/11/2016 1:22:36 AM > OK 6/11/2016 1:22:37 AM > Writing rpmbak...6/11/2016 1:22:37 AM > OK 6/11/2016 1:22:37 AM > Writing abootbak...6/11/2016 1:22:37 AM > OK 6/11/2016 1:22:37 AM > Writing persist...6/11/2016 1:22:40 AM > OK 6/11/2016 1:22:40 AM > Writing metadata...6/11/2016 1:22:40 AM > OK 6/11/2016 1:22:40 AM > Writing laf...6/11/2016 1:22:44 AM > OK 6/11/2016 1:22:44 AM > Writing boot...6/11/2016 1:22:48 AM > OK 6/11/2016 1:22:48 AM > Writing recovery...6/11/2016 1:22:52 AM > OK 6/11/2016 1:22:52 AM > Writing sec...6/11/2016 1:22:53 AM > OK 6/11/2016 1:22:53 AM > Writing factory...6/11/2016 1:22:58 AM > OK 6/11/2016 1:22:58 AM > Writing modem...6/11/2016 1:23:08 AM > OK 6/11/2016 1:23:08 AM > Writing pad2...6/11/2016 1:23:09 AM > OK 6/11/2016 1:23:09 AM > Writing carrier...6/11/2016 1:23:15 AM > OK 6/11/2016 1:23:15 AM > Writing system...6/11/2016 1:30:09 AM > OK 6/11/2016 1:30:09 AM > Reading partitions...6/11/2016 1:30:11 AM > OK 6/11/2016 1:30:11 AM > Formating RCT...6/11/2016 1:30:15 AM > OK 6/11/2016 1:30:15 AM > Formating MPT...6/11/2016 1:30:19 AM > OK 6/11/2016 1:30:19 AM > Finalizing...6/11/2016 1:30:21 AM > OK 6/11/2016 1:30:21 AM > Writing firmware done! 6/11/2016 1:30:21 AM > Performed by 2.3.4 software version. 6/11/2016 1:32:51 AM > Converting files... 6/11/2016 1:32:51 AM > Unpacking "PrimaryGPT"...6/11/2016 1:32:52 AM > OK 6/11/2016 1:32:52 AM > Unpacking "sbl1"...6/11/2016 1:32:52 AM > OK 6/11/2016 1:32:52 AM > Unpacking "tz"...6/11/2016 1:32:52 AM > OK 6/11/2016 1:32:52 AM > Unpacking "hyp"...6/11/2016 1:32:52 AM > OK 6/11/2016 1:32:52 AM > Unpacking "rpm"...6/11/2016 1:32:52 AM > OK 6/11/2016 1:32:52 AM > Unpacking "aboot"...6/11/2016 1:32:52 AM > OK 6/11/2016 1:32:52 AM > Unpacking "pad"...6/11/2016 1:32:52 AM > OK 6/11/2016 1:32:52 AM > Unpacking "sbl1bak"...6/11/2016 1:32:52 AM > OK 6/11/2016 1:32:52 AM > Unpacking "tzbak"...6/11/2016 1:32:52 AM > OK 6/11/2016 1:32:52 AM > Unpacking "hypbak"...6/11/2016 1:32:52 AM > OK 6/11/2016 1:32:52 AM > Unpacking "rpmbak"...6/11/2016 1:32:52 AM > OK 6/11/2016 1:32:52 AM > Unpacking "abootbak"...6/11/2016 1:32:52 AM > OK 6/11/2016 1:32:52 AM > Unpacking "misc"...6/11/2016 1:32:52 AM > OK 6/11/2016 1:32:52 AM > Unpacking "persist"...6/11/2016 1:32:53 AM > OK 6/11/2016 1:32:53 AM > Unpacking "metadata"...6/11/2016 1:32:53 AM > OK 6/11/2016 1:32:53 AM > Unpacking "laf"...6/11/2016 1:32:53 AM > OK 6/11/2016 1:32:53 AM > Unpacking "boot"...6/11/2016 1:32:53 AM > OK 6/11/2016 1:32:53 AM > Unpacking "recovery"...6/11/2016 1:32:54 AM > OK 6/11/2016 1:32:54 AM > Unpacking "fsc"...6/11/2016 1:32:54 AM > OK 6/11/2016 1:32:54 AM > Unpacking "ssd"...6/11/2016 1:32:54 AM > OK 6/11/2016 1:32:54 AM > Unpacking "DDR"...6/11/2016 1:32:54 AM > OK 6/11/2016 1:32:54 AM > Unpacking "sec"...6/11/2016 1:32:54 AM > OK 6/11/2016 1:32:54 AM > Unpacking "encrypt"...6/11/2016 1:32:54 AM > OK 6/11/2016 1:32:54 AM > Unpacking "eksst"...6/11/2016 1:32:54 AM > OK 6/11/2016 1:32:54 AM > Unpacking "rct"...6/11/2016 1:32:54 AM > OK 6/11/2016 1:32:54 AM > Unpacking "sns"...6/11/2016 1:32:54 AM > OK 6/11/2016 1:32:54 AM > Unpacking "factory"...6/11/2016 1:32:56 AM > OK 6/11/2016 1:32:56 AM > Unpacking "drm"...6/11/2016 1:32:56 AM > OK 6/11/2016 1:32:56 AM > Unpacking "mpt"...6/11/2016 1:32:57 AM > OK 6/11/2016 1:32:57 AM > Unpacking "modem"...6/11/2016 1:32:58 AM > OK 6/11/2016 1:32:58 AM > Unpacking "persistent"...6/11/2016 1:32:58 AM > OK 6/11/2016 1:32:58 AM > Unpacking "pad2"...6/11/2016 1:32:58 AM > OK 6/11/2016 1:32:59 AM > Unpacking "carrier"...6/11/2016 1:32:59 AM > OK 6/11/2016 1:32:59 AM > Unpacking "system"...6/11/2016 1:34:21 AM > OK 6/11/2016 1:34:21 AM > Unpacking "grow"...6/11/2016 1:34:23 AM > OK 6/11/2016 1:34:23 AM > Unpacking "BackupGPT"...6/11/2016 1:34:23 AM > OK 6/11/2016 1:34:23 AM > Unpacking done. Processing files... 6/11/2016 1:34:23 AM > Identifying sub-files...6/11/2016 1:34:25 AM > OK 6/11/2016 1:34:25 AM > Creating destination file...6/11/2016 1:37:40 AM > OK 6/11/2016 1:37:41 AM > Deleting temporary files... 6/11/2016 1:37:41 AM > Deleting directory "C:\Users\ARTURO~1\AppData\Local\Temp\LS770ZV8_06\ "... 6/11/2016 1:37:41 AM > Deleting file "C:\Users\ARTURO~1\AppData\Local\Temp\LS770ZV8_06\ aboot"...6/11/2016 1:37:41 AM > OK 6/11/2016 1:37:41 AM > Deleting file "C:\Users\ARTURO~1\AppData\Local\Temp\LS770ZV8_06\ abootbak"...6/11/2016 1:37:41 AM > OK 6/11/2016 1:37:41 AM > Deleting file "C:\Users\ARTURO~1\AppData\Local\Temp\LS770ZV8_06\ BackupGPT"...6/11/2016 1:37:41 AM > OK 6/11/2016 1:37:41 AM > Deleting file "C:\Users\ARTURO~1\AppData\Local\Temp\LS770ZV8_06\ boot"...6/11/2016 1:37:41 AM > OK 6/11/2016 1:37:41 AM > Deleting file "C:\Users\ARTURO~1\AppData\Local\Temp\LS770ZV8_06\ carrier"...6/11/2016 1:37:41 AM > OK 6/11/2016 1:37:41 AM > Deleting file "C:\Users\ARTURO~1\AppData\Local\Temp\LS770ZV8_06\ DDR"...6/11/2016 1:37:41 AM > OK 6/11/2016 1:37:41 AM > Deleting file "C:\Users\ARTURO~1\AppData\Local\Temp\LS770ZV8_06\ drm"...6/11/2016 1:37:41 AM > OK 6/11/2016 1:37:41 AM > Deleting file "C:\Users\ARTURO~1\AppData\Local\Temp\LS770ZV8_06\ eksst"...6/11/2016 1:37:41 AM > OK 6/11/2016 1:37:41 AM > Deleting file "C:\Users\ARTURO~1\AppData\Local\Temp\LS770ZV8_06\ encrypt"...6/11/2016 1:37:41 AM > OK 6/11/2016 1:37:41 AM > Deleting file "C:\Users\ARTURO~1\AppData\Local\Temp\LS770ZV8_06\ factory"...6/11/2016 1:37:41 AM > OK 6/11/2016 1:37:41 AM > Deleting file "C:\Users\ARTURO~1\AppData\Local\Temp\LS770ZV8_06\ fsc"...6/11/2016 1:37:41 AM > OK 6/11/2016 1:37:41 AM > Deleting file "C:\Users\ARTURO~1\AppData\Local\Temp\LS770ZV8_06\ grow"...6/11/2016 1:37:41 AM > OK 6/11/2016 1:37:41 AM > Deleting file "C:\Users\ARTURO~1\AppData\Local\Temp\LS770ZV8_06\ hyp"...6/11/2016 1:37:41 AM > OK 6/11/2016 1:37:41 AM > Deleting file "C:\Users\ARTURO~1\AppData\Local\Temp\LS770ZV8_06\ hypbak"...6/11/2016 1:37:41 AM > OK 6/11/2016 1:37:41 AM > Deleting file "C:\Users\ARTURO~1\AppData\Local\Temp\LS770ZV8_06\ laf"...6/11/2016 1:37:41 AM > OK 6/11/2016 1:37:41 AM > Deleting file "C:\Users\ARTURO~1\AppData\Local\Temp\LS770ZV8_06\ metadata"...6/11/2016 1:37:41 AM > OK 6/11/2016 1:37:41 AM > Deleting file "C:\Users\ARTURO~1\AppData\Local\Temp\LS770ZV8_06\ misc"...6/11/2016 1:37:41 AM > OK 6/11/2016 1:37:41 AM > Deleting file "C:\Users\ARTURO~1\AppData\Local\Temp\LS770ZV8_06\ modem"...6/11/2016 1:37:41 AM > OK 6/11/2016 1:37:41 AM > Deleting file "C:\Users\ARTURO~1\AppData\Local\Temp\LS770ZV8_06\ mpt"...6/11/2016 1:37:41 AM > OK 6/11/2016 1:37:41 AM > Deleting file "C:\Users\ARTURO~1\AppData\Local\Temp\LS770ZV8_06\ pad"...6/11/2016 1:37:41 AM > OK 6/11/2016 1:37:41 AM > Deleting file "C:\Users\ARTURO~1\AppData\Local\Temp\LS770ZV8_06\ pad2"...6/11/2016 1:37:41 AM > OK 6/11/2016 1:37:42 AM > Deleting file "C:\Users\ARTURO~1\AppData\Local\Temp\LS770ZV8_06\ parts.bin"...6/11/2016 1:37:42 AM > OK 6/11/2016 1:37:42 AM > Deleting file "C:\Users\ARTURO~1\AppData\Local\Temp\LS770ZV8_06\ persist"...6/11/2016 1:37:42 AM > OK 6/11/2016 1:37:42 AM > Deleting file "C:\Users\ARTURO~1\AppData\Local\Temp\LS770ZV8_06\ persistent"...6/11/2016 1:37:42 AM > OK 6/11/2016 1:37:42 AM > Deleting file "C:\Users\ARTURO~1\AppData\Local\Temp\LS770ZV8_06\ PrimaryGPT"...6/11/2016 1:37:42 AM > OK 6/11/2016 1:37:42 AM > Deleting file "C:\Users\ARTURO~1\AppData\Local\Temp\LS770ZV8_06\ rct"...6/11/2016 1:37:42 AM > OK 6/11/2016 1:37:42 AM > Deleting file "C:\Users\ARTURO~1\AppData\Local\Temp\LS770ZV8_06\ recovery"...6/11/2016 1:37:42 AM > OK 6/11/2016 1:37:42 AM > Deleting file "C:\Users\ARTURO~1\AppData\Local\Temp\LS770ZV8_06\ rpm"...6/11/2016 1:37:42 AM > OK 6/11/2016 1:37:42 AM > Deleting file "C:\Users\ARTURO~1\AppData\Local\Temp\LS770ZV8_06\ rpmbak"...6/11/2016 1:37:42 AM > OK 6/11/2016 1:37:42 AM > Deleting file "C:\Users\ARTURO~1\AppData\Local\Temp\LS770ZV8_06\ sbl1"...6/11/2016 1:37:42 AM > OK 6/11/2016 1:37:42 AM > Deleting file "C:\Users\ARTURO~1\AppData\Local\Temp\LS770ZV8_06\ sbl1bak"...6/11/2016 1:37:42 AM > OK 6/11/2016 1:37:42 AM > Deleting file "C:\Users\ARTURO~1\AppData\Local\Temp\LS770ZV8_06\ sec"...6/11/2016 1:37:42 AM > OK 6/11/2016 1:37:42 AM > Deleting file "C:\Users\ARTURO~1\AppData\Local\Temp\LS770ZV8_06\ sns"...6/11/2016 1:37:42 AM > OK 6/11/2016 1:37:42 AM > Deleting file "C:\Users\ARTURO~1\AppData\Local\Temp\LS770ZV8_06\ ssd"...6/11/2016 1:37:42 AM > OK 6/11/2016 1:37:42 AM > Deleting file "C:\Users\ARTURO~1\AppData\Local\Temp\LS770ZV8_06\ system"...6/11/2016 1:37:42 AM > OK 6/11/2016 1:37:42 AM > Deleting file "C:\Users\ARTURO~1\AppData\Local\Temp\LS770ZV8_06\ tz"...6/11/2016 1:37:42 AM > OK 6/11/2016 1:37:42 AM > Deleting file "C:\Users\ARTURO~1\AppData\Local\Temp\LS770ZV8_06\ tzbak"...6/11/2016 1:37:42 AM > OK 6/11/2016 1:37:43 AM > Directory "C:\Users\ARTURO~1\AppData\Local\Temp\LS770ZV8_06\ " succesfully deleted! 6/11/2016 1:37:43 AM > Firmware convert done! |
07-02-2016, 09:39 | #7 (permalink) | |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,413 | Quote:
07-02-2016, 09:45 | #8 (permalink) |
Member: 1514778 Status: Offline Thanks Meter: 48 | Oh yeah, i see that. Errrrm, i guess i triggered the infamous fuse. I do have the ZV7 version and it may have happened. Thanks for carifying that. I guess i bricked the phone myself if i did that then. I was very aware it cant be downgraded so i guess its my fault. Allrighty then, time to spend some money on a new LS770 since i bricked the customers phone he he.... Not so much fun but hey. Should have check twice before flashing. Thanks a lot guys, as always, the only support that really responds fast when we ask |
The Following User Says Thank You to Enelyam For This Useful Post: |
