01-27-2015, 16:16 | #1 (permalink) |
Freak Poster Join Date: Apr 2014 Location: IRAN
Member: 2166265 Status: Offline Thanks Meter: 35 | I need firmware for LG-P500 for Octopus [Solved] I can not download from the support. I need to LG-P500 (farsi- ARB)flash. tnx support team Last edited by Octopus box; 01-27-2015 at 17:51. |
01-27-2015, 16:19 | #2 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,407 | Hello. What is the problem with downloading exactly? |
01-27-2015, 17:09 | #3 (permalink) |
Member: 2166265 Status: Offline Thanks Meter: 35 | When I download it I get the following message. http://dc742.4shared.com/img/co_xNNf...94232173636556 This site is blocked in my country. Thanks for the help |
01-27-2015, 17:13 | #4 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,407 | Ok, we will upload firmware somewhere and give You the link. For which phone and which firmware do You need exactly? For KP500 or for P500? Also, You can download firmwares from Boot-Loader: https://www.boot-loader.com/eng. |
01-27-2015, 17:37 | #5 (permalink) | |
Member: 2166265 Status: Offline Thanks Meter: 35 | Quote:
tnx | |
01-27-2015, 20:26 | #7 (permalink) |
Member: 2166265 Status: Offline Thanks Meter: 35 | hi The following warning will flash. http://dc741.4shared.com/img/9F5EQd3...33679263968952 Where is the problem? LG Qualcomm : پلاتفورم COM54 : انتخاب پورت P500 : انتخاب مدل در حال خواندن اطلاعات...OK Mode: Normal Model ID: P500 تاریخ اتمام فایل فلش: Sep 02 2010 زمان اتمام فایل فلش: 14:00:00 تاریخ اتمام فایل فلش: Nov 17 2010 زمان انتشار فایل فلش: 14:55:22 ورژن نرم*افزار: P500-M76XX-V10b-NOV-17-2010-XX IMEI: 354043-04-618416-6 Bluetooth address: 8C:54:1D:FF:8D:70 ------------------------------- Checking data...OK LG Qualcomm : پلاتفورم COM56 : انتخاب پورت P500 : انتخاب مدل در حال خواندن اطلاعات...OK Mode: Emergency Model ID: BS/P500/7D درحال باز شدن "LGP500AT-00-V10h-IRQ-XX-DEC-06-2011.oct"...OK بررسی پارتیشن...OK Write BootLoaders: خیر ...AMSS در حال فلشOK ...Boot image در حال فلشOK ...System در حال فلشاشتباه شده! |
01-28-2015, 07:11 | #9 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,407 | @ MR.Ali Write firmware with phone's boot loaders - check (select) "Write boot loaders" option in the Software, select firmware file, put the phone into Emergency/Download Mode manually (disconnect the cable, reconnect the battery, press and hold "Back"+"Vol+"+"Power ON" buttons and connect the cable.) and press the "Write Firmware" button. Note: if it is not possible to write firmware or during firmware writing occures error, you need to disconnect phone's battery and put manualy phone into Emergency Mode, this is important! Also note: make sure the phone's battery is fully charged. Disconnect all other devices from the computer (including phones, modems, etc.) and close all other running programs. To avoid errors in the flashing process, use a clean PC (without any installed drivers for other Qualcomm-based devices). You should not run any other programs or attach new devices to your computer during the flashing! Please, follow these simple precautions to avoid damaging your phone. |
