06-04-2017, 13:20 | #1 (permalink) |
No Life Poster Join Date: Apr 2004 Location: srilanka
Member: 61595 Status: Offline Sonork: 100.1610188 Thanks Meter: 97 | K410a flash failed [Solved] then i try to flash but not successs logs **** 6/3/2017 3:02:23 PM > Checking data...6/3/2017 3:02:24 PM > OK 6/3/2017 3:02:24 PM > Platform: LG MTK 6/3/2017 3:02:24 PM > Selected port: COM100 6/3/2017 3:02:24 PM > Selected baudrate: 921600 6/3/2017 3:02:24 PM > Selected model: K410A 6/3/2017 3:02:24 PM > Selected USB connection type 6/3/2017 3:02:25 PM > Please, disconnect cable, reconnect battery, connect P999 cable (with 910k resistor) 6/3/2017 3:02:25 PM > or 6/3/2017 3:02:25 PM > Reconnect battery, press and hold "Vol+" for 10 seconds and connect Micro USB cable. 6/3/2017 3:02:26 PM > Phone found. 6/3/2017 3:02:30 PM > Mode: Emergency 6/3/2017 3:02:30 PM > Initializing flash...6/3/2017 3:02:33 PM > OK 6/3/2017 3:02:34 PM > Model ID: LG-K410A 6/3/2017 3:02:34 PM > SW version: LGK410AAT-00-V10b-SEA-XX-JAN-20-2016+0 6/3/2017 3:02:34 PM > LAF Version: 1.2 6/3/2017 3:02:34 PM > Product ID: CH32S160309001272 6/3/2017 3:02:34 PM > IMEI: 356527-07-015xxxx 6/3/2017 3:02:34 PM > Target operator: GLOBAL 6/3/2017 3:02:34 PM > Hardware: rev_10 6/3/2017 3:02:34 PM > Battery level: 17% 6/3/2017 3:02:34 PM > Reading partitions...6/3/2017 3:02:34 PM > Failed! 6/3/2017 3:02:34 PM > Reading partitions... 6/3/2017 3:02:34 PM > Performed by 2.6.4 Software version. please reply if any solution urgent Last edited by Octopus box; 06-05-2017 at 09:31. |
06-05-2017, 07:41 | #2 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,411 | Hello. Please, download and install the latest Software version, fully charge phone's battery, then repeat "Write Firmware" operation again. Post here full Software log. |
06-05-2017, 08:06 | #3 (permalink) |
Member: 61595 Status: Offline Sonork: 100.1610188 Thanks Meter: 97 | same with latest Software version Checking data...OK Platform: LG MTK Selected port: COM200 Selected baudrate: 921600 Selected model: K410A Selected USB connection type Please, disconnect cable, reconnect battery, connect P999 cable (with 910k resistor) or Reconnect battery, press and hold "Vol+" for 10 seconds and connect Micro USB cable. Phone found at port COM99 Mode: Emergency Initializing flash...OK Model ID: LG-K410A SW version: LGK410AAT-00-V10b-SEA-XX-JAN-20-2016+0 LAF Version: 1.2 Product ID: CH32S16030900xxxx IMEI: 356527-07-015369-9 Target operator: GLOBAL Hardware: rev_10 Battery level: 57% Reading partitions...Failed! Reading partitions... Performed by 2.6.7 Software version. |
06-05-2017, 08:56 | #4 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,411 | We have prepared test Software version for You. Please download and install it from the Support Area ("LG/TEST SOFTWARE" folder), then repeat "Write Firmware" operation again and post here the result. Last edited by Octopus box; 06-05-2017 at 09:31. |
