09-22-2017, 13:37 | #1 (permalink) |
Freak Poster Join Date: Oct 2015
Member: 2478777 Status: Offline Sonork: 1669951 Thanks Meter: 103 | K500N Imei Repair Platform: LG Qualcomm Selected port: COM343 Selected model: K500N Reading info... Model ID: LG-K500n IMEI: 358************ Android version: 6.0.1 Battery level: 37% SW Version: K500n10e Mode: Normal Firmware compiled date: Apr 27 2016 Firmware compiled time: 07:00:00 Firmware released date: Jun 21 2016 Firmware released time: 11:28:35 SW Version: MPSS.DPM.2.0.c11-00058-M8936FAAAANUZM- 4.49899.1.53954.1 IMEI: 358************ SPC: 000000 Fixing IMEI... New IMEI: 354************ Reading QCN... Send SPC...OK Reading Mobile Property...OK Reading Feature Mask...OK Reading Roaming List 0...OK Reading NV_Numbered Items...OK Reading NV_Numbered SIM1 Items...OK Reading NV_Numbered SIM2 Items...OK Reading NV Items...OK Reading EFS...OK Reading Provisioning Items...OK Reading QCN done! Backup saved to "K500N_358************_22-09-2017_15-21-33.qcn" Do you want to create security backup? Writing security area...OK Rebooting phone... Trying to enable Diagnostics ports...Failed! Trying to enable Diagnostics ports... Initializing ADB...OK ADB Server was found. Trying to kill... Waiting for phone... Please, reconnect phone, enable USB debugging, and try again. To enable USB debugging, please perform the following steps: 1. Disconnect cable 2. Install LG Android ADB drivers 3. Go to "Settings" -> "About phone" -> "Software information" 4. Click on Build number 5 times 5. Enable "Settings" -> "Developer options" -> "USB debugging" option 6. Connect the cable and check, whether ADB interface has appeared in PC Device Manager.Failed! Please, reconnect phone, enable USB debugging, and try again. To enable USB debugging, please perform the following steps: 1. Disconnect cable 2. Install LG Android ADB drivers 3. Go to "Settings" -> "About phone" -> "Software information" 4. Click on Build number 5 times 5. Enable "Settings" -> "Developer options" -> "USB debugging" option 6. Connect the cable and check, whether ADB interface has appeared in PC Device Manager. Please perform the following steps: 1. Disconnect cable 2. Put phone into Normal mode manually 3. Press "Ok" button Trying to enable Diagnostics ports...Failed! Trying to enable Diagnostics ports... Initializing ADB...OK Waiting for phone...OK Diagnostics ports are enbled! Switching to Serial Port... Found model EAAAANUZ: ÿd at port COM343 IMEI successfully fixed! Rebooting phone... Performed by 2.7.6 Software version. |
The Following User Says Thank You to AhmetSuat For This Useful Post: |
