12-02-2016, 09:28 | #2 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,410 | Hello. Please, select your phone as K520k and try to perform Reset FRP operation. Then post here full Software log. Last edited by Octopus box; 12-02-2016 at 10:38. |
12-02-2016, 11:40 | #3 (permalink) |
Freak Poster Join Date: Mar 2005 Location: TURKEY Age: 42
Member: 127987 Status: Offline Thanks Meter: 6 | Welcome to Octoplus/Octopus Box LG Software version 2.5.1 Connecting to server support.octoplusbox.com:82...OK Authorizing...OK -------------------------------------------------------------------------------- Checking data...OK Platform: LG Qualcomm Selected port: COM5 Selected model: K520K Please, put the phone into download mode manually (Power phone OFF, press and hold "Vol+" button and connect the cable (or P990 cable)). Reading info... Could not detect mode! Performed by 2.5.1 Software version. -------------------------------------------------------------------------------- Checking data...OK Platform: LG Qualcomm Selected port: COM5 Selected model: K520K Please, put the phone into download mode manually (Power phone OFF, press and hold "Vol+" button and connect the cable (or P990 cable)). Reading info... Could not detect mode! Performed by 2.5.1 Software version. -------------------------------------------------------------------------------- Checking data...OK Platform: LG Qualcomm Selected port: COM28 Selected model: K520K Please, put the phone into download mode manually (Power phone OFF, press and hold "Vol+" button and connect the cable (or P990 cable)). Reading info... Model ID: LG-K520TR IMEI: 358386-07--------5 Android version: 6.0.1 Battery level: 63% SW Version: K52010c Mode: Emergency Initializing flash...OK SW version: LGK520TRAT-00-V10c-TUR-XX-OCT-24-2016+0 Android version: 6.0.1 LAF Version: 1.1 Product ID: CT69S160515002591 IMEI: 358386-07-018492-5 Target operator: GLOBAL Hardware: rev_10 Reading partitions...OK Resetting FRP Lock... Step 1...Failed! Performed by 2.5.1 Software version. -------------------------------------------------------------------------------- Checking data...OK Platform: LG Qualcomm Selected port: COM28 Selected model: K520K Please, put the phone into download mode manually (Power phone OFF, press and hold "Vol+" button and connect the cable (or P990 cable)). Reading info... Model ID: LG-K520TR IMEI: 358386-07--------5 Android version: 6.0.1 Battery level: 63% SW Version: K52010c Mode: Emergency Initializing flash...OK SW version: LGK520TRAT-00-V10c-TUR-XX-OCT-24-2016+0 Android version: 6.0.1 LAF Version: 1.1 Product ID: CT69S160515002591 IMEI: 358386-07--------5 Target operator: GLOBAL Hardware: rev_10 Reading partitions...OK Resetting FRP Lock... Step 1...Failed! Performed by 2.5.1 Software version. |
12-02-2016, 11:50 | #4 (permalink) | |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,410 | Hello In the latest Software version 2.5.2 we have improved Reset FRP operation: Quote:
Please install the latest Software version 2.5.2 (Software), repeat Reset FRP operation and post here the result. | |
12-02-2016, 14:04 | #5 (permalink) |
Member: 127987 Status: Offline Thanks Meter: 6 | Welcome to Octoplus/Octopus Box LG Software version 2.5.2 -------------------------------------------------------------------------------- Checking data...OK Platform: LG Qualcomm Selected port: COM28 Selected model: K520K Please, put the phone into download mode manually (Power phone OFF, press and hold "Vol+" button and connect the cable (or P990 cable)). Reading info... Model ID: LG-K520TR IMEI: 358386-07-018492-5 Android version: 6.0.1 Battery level: 100% SW Version: K52010c Mode: Emergency Initializing flash...OK SW version: LGK520TRAT-00-V10c-TUR-XX-OCT-24-2016+0 Android version: 6.0.1 LAF Version: 1.1 Product ID: CT69S160515002591 IMEI: 358386-07--------5 Target operator: GLOBAL Hardware: rev_10 Reading partitions...OK Resetting FRP Lock... Step 1...Failed! Performed by 2.5.2 Software version. |
12-02-2016, 15:24 | #6 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,410 | @ozturkcep Please, download and install test Software version form the Support Area (LG/TEST SOFTWARE/) select your phone model K520TR and perform Reset FRP operation, post here full Software log. |
01-17-2017, 15:52 | #7 (permalink) |
Product Supporter Join Date: Dec 2004 Location: Furious Team ... GPGIndustries Age: 45
Member: 95960 Status: Offline Sonork: 100.1574721 Thanks Meter: 14,045 | Same here Code: Welcome to Octoplus/Octopus Box LG Software version 2.5.6 -------------------------------------------------------------------------------- Checking data...OK Platform: LG Qualcomm Selected port: COM129 Selected model: K520TR Please, put the phone into download mode manually (Power phone OFF, press and hold "Vol+" button and connect the cable (or P999 cable)). Reading info... Model ID: LG-K520TR IMEI: xxxxxxxxx Android version: 7.0 Battery level: 100% SW Version: K52020a Mode: Emergency Initializing flash...OK SW version: LGK520TRAT-00-V20a-TUR-XX-DEC-16-2016+0 Android version: 7.0 LAF Version: 1.1 Product ID: CT01S160428002341 IMEI: xxxxxxxx Target operator: GLOBAL Hardware: rev_10 Reading partitions...OK Resetting FRP Lock... Step 1... LAF Error: 80000121. Reset FRP operation is currently not supported for your phone's firmware.Failed! Reading partitions...OK Resetting FRP Lock... Resetting FRP lock successfully completed! Performed by 2.5.6 Software version. |
01-17-2017, 16:05 | #10 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,410 | Downgrading is not possible, V20 firmwares for this phone contain signatures and it is not possible to write lower firmware version without signature. |
01-17-2017, 16:21 | #12 (permalink) |
Product Supporter Join Date: Mar 2011 Location: Octopus-team
Member: 1538383 Status: Offline Sonork: 100.1587278 Thanks Meter: 3,398 | We have not tested on this device exactly, but in general, should work on devices, which based on Qualcomm CPUs. If You have eMMC pinout for this phone, try to connect the device. If connection will be successful, contact us and we will try to help with FRP removing. |
