11-22-2016, 13:25 | #1 (permalink) |
Crazy Poster Join Date: Jun 2011 Location: South Africa
Member: 1591817 Status: Offline Thanks Meter: 5 | K535D FRP Problem Platform: LG Qualcomm Selected port: COM830 Selected model: K535D Please, put the phone into download mode manually (Power phone OFF, press and hold "Vol+" button and connect the cable (or P990 cable)). Reading info... Model ID: LG-K535D IMEI: --------------- Android version: 6.0.1 Battery level: 86% SW Version: K53510b Mode: Emergency Initializing flash...OK SW version: LGK535DAT-00-V10b-IND-XX-MAY-24-2016+0 Android version: 6.0.1 LAF Version: 1.1 Product ID: SM02S160701003892 IMEI: ----------------- Target operator: GLOBAL Hardware: rev_11 Reading partitions...OK Resetting FRP Lock... Step 1... Performed by 2.5.0 Software version. It just says Step 1 . . . And stops there . . |
11-22-2016, 13:34 | #2 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,412 | Hello. Please, perform Read Full Flash operation, read at least 2Gb, archive that file and send us, we will research it. |
11-23-2016, 08:35 | #5 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,412 | Thanks, we will check it and research where can be the problem with your phone and research for the solution. When solution will be ready, we will inform You. Last edited by Octopus box; 11-25-2016 at 09:03. |
11-24-2016, 17:01 | #7 (permalink) |
Member: 1591817 Status: Offline Thanks Meter: 5 | -------------------------------------------------------------------------------- Checking data...OK Platform: LG Qualcomm Selected port: COM867 Selected model: K535D Reading info... Model ID: LG-K535D IMEI: XXXXXXXXXXXXXXXX Android version: 6.0.1 Battery level: 94% SW Version: K53510b Mode: Normal Firmware compiled date: May 13 2016 Firmware compiled time: 18:00:00 Firmware released date: May 24 2016 Firmware released time: 13:56:22 SW Version: MPSS.JO.1.2.c2.1-00005-8937_GENNS_PACK- 2.52792.1.56085.1 IMEI: XXXXXXXXXXXXXXXXX IMEI B: XXXXXXXXXXXXXXXX SPC: 000000 Fixing IMEI... New IMEI A: XXXXX-XX-XXXXX-X New IMEI B: XXXXX-XX-XXXXX-X Skip Read/Write QCN Do you want to create security backup? Switching to Download mode...OK Initializing flash...OK Reading partitions...OK Reading security area...OK Backup saved to "K535D_XXXXXXXXXXXXXXX_24-11-2016_17-57-47.SEC" Switching to Normal mode... Found model LGK535DA: ÿd at port COM90 Writing security area...Failed! Performed by 2.5.0 Software version. |
11-25-2016, 09:04 | #8 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,412 | Please, perform Reset Security operation, then Repair IMEI with Skip Read /Write QCN option, after post here full Software log. |
