04-04-2018, 20:18 | #1 (permalink) |
Freak Poster Join Date: Jun 2011
Member: 1606451 Status: Offline Thanks Meter: 53 | K600HK FRP question [Answered] -------------------------------------------------------------------------------- Checking data...OK Platform: LG Qualcomm Selected port: COM49 Selected model: K600HK Please, put the phone into download mode manually (Power phone OFF (reconnect battery), press and hold "Vol+" button and connect the cable (or P999 cable)). Reading info... Mode: Emergency Initializing flash...OK SW version: LK46010g_00 Android version: 7.1.1 LAF Version: 1.1 Product ID: 00000000000000000000000000000 IMEI: 358195-08-069205-2 Target operator: SPR Hardware: rev_10 Reading partitions...OK Resetting FRP Lock...Failed! Error code: WHU8CHON7C Reset FRP operation for K600HK will delete all user data on the phone (contacts, pictures and others)! Do You want to continue? Reading partitions...OK Resetting FRP Lock... Writing loader... Step 1... Step 2... Step 3... Step 4... Step 5... Step 6... Step 7... Step 8... Step 9... Step 10...OK Writing userdata...OK Formating encrypt...OK Restoring loader...OK Resetting FRP lock successfully completed! Rebooting phone... To complete the operation, please make Factory Reset (Go to "Settings" -> "General" -> "Backup & reset" -> "Factory data reset", press "Reset phone" and "Erase everything" buttons). Performed by 2.8.0 Software version. Last edited by Octopus box; 04-05-2018 at 05:48. |
04-05-2018, 05:49 | #2 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,407 | Hello. What is your device model exactly, K600HK or LK460? You have selected K600HK , but device is detected by Software as LK460? |
04-06-2018, 05:57 | #4 (permalink) | |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,407 | Quote:
08-14-2018, 07:37 | #6 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,407 | We will try to buy this device and research the solution. Do You have this device in hands right now? If yes, we can prepare test Software version for You. |
08-14-2018, 15:55 | #7 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,407 | We have prepared and sent You test Software version to PM. If You have this device, try to use this test Software and post here the result. |
