03-03-2014, 11:27 | #1 (permalink) |
No Life Poster Join Date: Jan 2012 Location: YOUR HEART
Member: 1712884 Status: Offline Thanks Meter: 857 | kc550 & ke970 need help [Solved] I have one kc550 and ke970 phone in hand this phone good work whaitout sim but after turn on by sim hang on logo and dead. I need firmware for flashing please change name this file for me (KC550AT-00-V10e-ARB-XXX-SEP-05-2008+0_TotalBin.zip) please delete xxx name and upload for me eprom for this 2 phones Last edited by Octopus box; 03-03-2014 at 12:13. |
03-03-2014, 11:46 | #2 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,411 | Hello. We have renamed firmwares and uploaded for You EEPROM for KC550 to your PM. |
03-03-2014, 12:08 | #3 (permalink) |
Member: 1712884 Status: Offline Thanks Meter: 857 | thanks: ke970 problem solved after repair eprom and unlock and flashing Code: Welcome to Octoplus/Octopus Box LG Software version 1.4.7 -------------------------------------------------------------------------------- Platform: LG Infineon Selected port: COM11 Selected baudrate: 921600 Selected model: KE970 Please reconnect battery, PRESS AND HOLD power button... Phone found. Sending preloader...OK Sending loader...OK Release power button Flash ID: 89B0 Flash type: Intel Reading EEPROM...OK Backup saved to "KE970-_03-03-2014_13-46-24.eep" Repairing EEPROM...OK -------------------------------------------------------------------------------- To finish the operation, please perform the following steps: 1. Click "Disconnect" 2. Power ON the phone (Please hold the power button for 30 sec) 3. Restore the original IMEI using the "IMEI fix" option. Unlocking... Reading security area... Backup saved to "KE970-_03-03-2014_13-46-43.eep" Writing security area... Phone successfully unlocked! Opening "KE970P40-ARB-V10h-XXX-XX AUG 01 2007.oct"...OK Erasing...Please wait...OK Writing Firmware...OK Writing Firmware done! Disconnected. Connecting to server octopus-server0.no-ip.biz:82...OK Authorizing...OK -------------------------------------------------------------------------------- Platform: LG Infineon Selected port: COM11 Selected baudrate: 921600 Selected model: KE970 Please reconnect battery, PRESS AND HOLD power button... Phone found. Sending preloader...OK Sending loader...Failed! Release power button Disconnected. -------------------------------------------------------------------------------- Platform: LG Infineon Selected port: COM11 Selected baudrate: 921600 Selected model: KE970 Please reconnect battery, PRESS AND HOLD power button... Phone found. Sending preloader...OK Sending loader...OK Release power button Flash ID: 89B0 Flash type: Intel Unlocking... Reading security area... Backup saved to "KE970-_03-03-2014_14-31-05.eep" Writing security area... Phone successfully unlocked! |
The Following User Says Thank You to Moh3en.pc For This Useful Post: |
03-03-2014, 12:25 | #4 (permalink) |
Member: 1712884 Status: Offline Thanks Meter: 857 | kc550 error in flashing and dead please help: Code: Welcome to Octoplus/Octopus Box LG Software version 1.4.7 -------------------------------------------------------------------------------- Platform: LG Infineon Selected port: USB Selected model: KC550 Disconnect battery and connect USB cable to phone...Canceled! Disconnected. -------------------------------------------------------------------------------- Platform: LG Infineon Selected port: COM11 Selected baudrate: 921600 Selected model: KC550 Please reconnect battery, press and hold power button... Phone found. Release power button. Sending loader...OK Reading info...Failed! Certificate load error Reconnecting in safe mode... Please reconnect battery, press and hold power button... Phone found. Release power button. Sending loader...OK This mode only supports firmware writing. Opening "KC550AT-00-V10e-ARB-XXX-SEP-05-2008+0_TotalBin.oct"...OK Writing Firmware... Error writing at adress 0x38114000! Disconnected. -------------------------------------------------------------------------------- Platform: LG Infineon Selected port: USB Selected model: KC550 Disconnect battery and connect USB cable to phone...Canceled! Disconnected. -------------------------------------------------------------------------------- Platform: LG Infineon Selected port: COM11 Selected baudrate: 921600 Selected model: KC550 Please reconnect battery, press and hold power button... Phone found. Release power button. Sending loader...OK Reading info...Failed! Certificate load error Reconnecting in safe mode... Please reconnect battery, press and hold power button... Phone found. Release power button. Sending loader...OK This mode only supports firmware writing. Opening "KC550AT-00-V10e-ARB-XXX-SEP-05-2008+0_TotalBin.oct"...OK Writing Firmware... Error writing at adress 0x38114000! Disconnected. -------------------------------------------------------------------------------- Platform: LG Infineon Selected port: COM11 Selected model: KC550 This action requires COM cable! Phone and phone lights should be powered ON Reading phone info...Failed! -------------------------------------------------------------------------------- Platform: LG Infineon Selected port: COM11 Selected baudrate: 921600 Selected model: KC550 Please reconnect battery, press and hold power button... Phone found. Release power button. Sending loader...OK Reading info...Failed! Certificate load error Reconnecting in safe mode... Please reconnect battery, press and hold power button... Phone found. Release power button. Sending loader...OK This mode only supports firmware writing. Opening "KC550AT-00-V10e-ARB-XXX-SEP-05-2008+0_TotalBin.oct"...OK Writing Firmware... Error writing at adress 0x38114000! Disconnected. -------------------------------------------------------------------------------- Platform: LG Infineon Selected port: COM11 Selected baudrate: 921600 Selected model: KC550 Please reconnect battery, press and hold power button...Canceled! Disconnected. |
03-03-2014, 12:31 | #5 (permalink) | ||
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,411 | Quote:
