03-02-2014, 09:23 | #2 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,412 | Hello. Do You use the special LG P999 cable (with 910k resistor inside)? If yes, try to use another LG P999 cable, connect the device directly to motherboard USB port (don't use any USB hubs and USB PCI cards) and try to make "Repair" again. If the problem will be same - most likely, this is HW problem. |
03-02-2014, 09:30 | #3 (permalink) | |
No Life Poster Join Date: May 2012 Age: 27
Member: 1764566 Status: Offline Sonork: SUSPENDED Thanks Meter: 5,763 | Quote:
yes i m using usb cable with 910k resistance and also not using hubs means direcly connecting to pc port and phones was dead during updating so i think its may not be hw problem | |
03-03-2014, 07:34 | #4 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,412 | Your device doesn't answer to Software's CMDs, so it is not possible to perform "Repair" procedure. Most likely, this is HW problem. |
