Korean Phone LG KU5900 HARD RESET Done By OctopusBox History: To Many Pattern lock http://i262.photobucket.com/albums/i...a/IMG_0032.jpg Here is the simple trick How to Hard RESET Korean Phone LG KU5900 using Octopus box LG Activated. Procedure 1. Open Octopus LG SW 2. Select Model: KP100 2. Phone Must be ON 3. Connect (Micro UART Cable) 4. Thick ( Factory Reset ) Press short power botton and wait the phone must be Restart http://i262.photobucket.com/albums/i...ra/KU59002.jpg http://i262.photobucket.com/albums/i...a/IMG_0033.jpg http://i262.photobucket.com/albums/i...a/IMG_0036.jpg Now here is the final result DONE http://i262.photobucket.com/albums/i...a/IMG_0034.jpg http://i262.photobucket.com/albums/i...a/IMG_0038.jpg |
Not working i checked on different cables still not work can u pleaes mention cable name ??? |
Hello. You should use LG Miacro UART cable. Don't forget to select correct (Box) COM port. |
good work 100000% ok |
1 select com port of box 2 use cable ( REXTOR MUAI) 3 . PRESS FACTORY wait until fini |
thanks a lot %100 working |
Thanx goes to octopus... Work 100% for me also. |
good work 100000000000000000000000% ok |
niccccccc bro 100% ok hardreset.......reset ok but w8 must set auto restart |
hi dear all not working i use rextor micro uart com port 24 please help? |
To make Factory reset please do the: 1. Run Octopus/Octoplus LG Software. 2. Select KP100 phone model. 3. Power on phone. 4. Connect the LG Micro UART cable. 5. Select correct (Box) COM port. 6. Press "Factory Reset" button in SOftware. 7. Shortly press "Power ON" botton on phone. 8. Wait till the phone will restart. Please try to use another Micro UART cable, maybe the problem is with your cable. |
would you provide a cable pinout please? |
To look at LG Micro UART cable's pinout picture, select, for example, GS101 phone model in the list and press "Cable" button in Software. |
thanks octopus -------------------------------------------------------------------------------- Platform: LG Infineon Selected port: COM17 Selected model: KP100 This action requires COM cable! Phone and phone lights should be powered ON Reseting...OK |
