11-28-2014, 12:32 | #1 (permalink) |
No Life Poster Join Date: Oct 2010 Location: colombo
Member: 1418524 Status: Offline Thanks Meter: 186 | KU5400 flash problem -------------------------------------------------------------------------------- Platform: LG Infineon Connection mode: OMAP Selected model: KU5400 Opening "LGKU5400AT-00-V20d-450-08-JUL-11-2012_AP.oct"...OK Please, disconnect battery and connect P999 cable (with 910k resistor). Initializing device...OK Writing Firmware... Connecting to modem CPU...OK Sending preloader...Failed! -------------------------------------------------------------------------------- Platform: LG Infineon Connection mode: OMAP Selected model: KU5400 Opening "LGKU5400AT-00-V20d-450-08-JUL-11-2012_AP.oct"...OK Please, disconnect battery and connect P999 cable (with 910k resistor). Initializing device...OK Writing Firmware... Connecting to modem CPU...OK Sending preloader... |
11-28-2014, 13:25 | #2 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,413 | Hello. What is the state of your device exactly? What is the problem with it? Why You have decided to write firmware? To write firmware You should use the special LG P999 cable with 910k resistor inside (not standart Micro USB cable), connect the device directly to PC motherboard USB port, don't use any USB hubs or PCI USB extention cards, this is important. Try to use another cable. Try to write firmware on another PC. If the problem is still the same - most likely, this is HW problem. |
