05-01-2016, 14:02 | #1 (permalink) |
Insane Poster Join Date: Nov 2011 Location: sri lanka anuradhapura
Member: 1682813 Status: Offline Sonork: 123456 Thanks Meter: 1 | l70 mid change[Solved] Checking data...OK Platform: LG Qualcomm Selected port: COM14 Selected model: D325 Reading info... Model ID: LGMS323 Incompatible model ID! Please, select correct model! Performed by 2.2.8 software version. how to slow this error |
05-03-2016, 08:47 | #2 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,413 | Hello. Please, contact with us in PM, we will try to prepare test Software version for You. |
05-07-2016, 05:17 | #7 (permalink) |
Member: 1682813 Status: Offline Sonork: 123456 Thanks Meter: 1 | imei is not showing. here is log read info Welcome to Octoplus/Octopus Box LG Software version 2.2.8 -------------------------------------------------------------------------------- Platform: LG Qualcomm Selected port: COM93 Selected model: D325 Reading info... Model ID: Mode: Normal Performed by 2.2.8 software version. repair imei -------------------------------------------------------------------------------- Checking data...OK Platform: LG Qualcomm Selected port: COM93 Selected model: D325 Reading info... Model ID: Mode: Normal Fixing IMEI... New IMEI: 352270-06-612235-2 Reading QCN... Send SPC...OK Reading Mobile Property...OK Reading Feature Mask...OK Reading Roaming List 0...Failed! Reading NV_Numbered Items...OK Reading NV_Numbered SIM1 Items...OK Reading NV_Numbered SIM2 Items...OK Reading NV Items... Performed by 2.2.8 software version. |
05-07-2016, 10:29 | #8 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,413 | Please, select your phone model as MS323 and reflash the phone with correct firmware, then post here full Software log, after check baseband and imei. |
05-08-2016, 08:20 | #9 (permalink) |
Member: 1682813 Status: Offline Sonork: 123456 Thanks Meter: 1 | -------------------------------------------------------------------------------- Checking data...OK Platform: LG Qualcomm Selected port: COM93 Selected model: MS323 Reading info... Model ID: LG-D325 IMEI: 000000-00-000000-0 Android version: 4.4.2 Battery level: 76% Mode: Emergency Initializing flash...OK SW version: LGD325AT-00-V10e-OP1-SI-AUG-13-2014+0 LAF Version: 1.0 Product ID: CT66S140829000276 IMEI: 000000-00-000000-0 Target operator: GLOBAL Hardware: rev_10 Opening "D32510f_00.oct"...Failed! File declared for different phone model! Performed by 2.2.8 software version. |
05-09-2016, 09:31 | #10 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,413 | Please, power on phone and in normal mode, connect to PC, then run Software, select MS323 phone model and try to reflash the phone with correct firmware, after post here full Software log. |
