04-29-2015, 18:52 | #1 (permalink) |
Freak Poster Join Date: Jan 2014 Location: developer world
Member: 2117327 Status: Offline Thanks Meter: 48 | ld d850 imei repair failed [Solved] Selected port: COM17 Selected model: D850 Reading info...OK Mode: Normal Model ID: LG-D850 Firmware compiled date: May 21 2014 Firmware compiled time: 02:00:00 Firmware released date: Jun 20 2014 Firmware released time: 09:52:24 SW Version: MPSS.DI.2.0.1.c1.13-00009-M8974AAAAANPZM-1 IMEI: 014065-00-252xxxx SPC: 000000 -------------------------------------------------------------------------------- Checking data...OK Platform: LG Qualcomm Selected port: COM17 Selected model: D850 Reading info...OK Mode: Normal Model ID: LG-D850 Firmware compiled date: May 21 2014 Firmware compiled time: 02:00:00 Firmware released date: Jun 20 2014 Firmware released time: 09:52:24 SW Version: MPSS.DI.2.0.1.c1.13-00009-M8974AAAAANPZM-1 IMEI: 014065-00-252896-3 SPC: 000000 Fixing IMEI... New IMEI: 014065-00-252xxxx Reading QCN... Send SPC...OK Reading Mobile Property...OK Reading Feature Mask...OK Reading Roaming List 0...OK Reading NV_Numbered Items...OK Reading NV_Numbered SIM1 Items...OK Reading NV_Numbered SIM2 Items...OK Reading NV Items...OK Reading EFS...OK Reading Provisioning Items...OK Reading QCN done! Backup saved to "D850_01406500252xxxx_29-04-2015_11-33-49.qcn" Switching to Download mode...OK Initializing flash...Failed! Initializing flash... Last edited by Octopus box; 05-01-2015 at 12:28. |
04-29-2015, 19:16 | #2 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,412 | Hello. Do the next: 1. Install required driver. 2. Install latest Software version. 3. Restart PC. 4. Repeat "Repair IMEI" operation. |
04-29-2015, 20:25 | #3 (permalink) |
Member: 2117327 Status: Offline Thanks Meter: 48 | not work! Welcome to Octoplus/Octopus Box LG Software version 1.9.2 -------------------------------------------------------------------------------- Platform: LG Qualcomm Selected port: COM43 Selected model: D850 Reading info...Failed! Port busy -------------------------------------------------------------------------------- Platform: LG Qualcomm Selected port: COM17 Selected model: D850 Reading info...OK Mode: Normal Model ID: LG-D850 Firmware compiled date: May 21 2014 Firmware compiled time: 02:00:00 Firmware released date: Jun 20 2014 Firmware released time: 09:52:24 SW Version: MPSS.DI.2.0.1.c1.13-00009-M8974AAAAANPZM-1 IMEI: 014065-00-252896-3 SPC: 000000 -------------------------------------------------------------------------------- Checking data...OK Platform: LG Qualcomm Selected port: COM17 Selected model: D850 Reading info...OK Mode: Normal Model ID: LG-D850 Firmware compiled date: May 21 2014 Firmware compiled time: 02:00:00 Firmware released date: Jun 20 2014 Firmware released time: 09:52:24 SW Version: MPSS.DI.2.0.1.c1.13-00009-M8974AAAAANPZM-1 IMEI: 014065-00-252896-3 SPC: 000000 Fixing IMEI... New IMEI: 014065-00-259066-6 Reading QCN... Send SPC...OK Reading Mobile Property...OK Reading Feature Mask...OK Reading Roaming List 0...OK Reading NV_Numbered Items...OK Reading NV_Numbered SIM1 Items...OK Reading NV_Numbered SIM2 Items...OK Reading NV Items...OK Reading EFS...OK Reading Provisioning Items...OK Reading QCN done! Backup saved to "D850_014065002528963_29-04-2015_13-07-55.qcn" Switching to Download mode...OK Initializing flash...Failed! Initializing flash... |
04-29-2015, 20:40 | #4 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,412 | Switch the phone to Download Mode manually (press and hold "Vol+" button and connect USB cable). Perform "Read Info" operation and post here full Software log. Also, what device appears in PC Device Manager after phone's connection? |
04-29-2015, 20:46 | #5 (permalink) |
Member: 2117327 Status: Offline Thanks Meter: 48 | Platform: LG Qualcomm Selected port: COM17 Selected model: D850 Reading info...OK Mode: Normal Model ID: LG-D850 SW Version: D85010d IMEI: 000000-00-000000-0 Android version: 4.4.2 Battery level: 100% |
04-29-2015, 20:57 | #6 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,412 | What device appears in PC Device Manager after You connect the phone in Download Mode? What is displayed on phone's screen? |
04-30-2015, 05:44 | #8 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,412 | What cable do You use exactly? You need to use the special LG P999 cable with 910 kOhm resistor inside, not standart Micro USB cabel. Please read Software manual ("Cable & Options" button in the Software). Try to perform "Repair IMEI" operation with enabled "Skip Read/Write QCN during the Repair IMEI/ Repair Network operations" and post here the result. |
04-30-2015, 19:27 | #9 (permalink) |
Member: 2117327 Status: Offline Thanks Meter: 48 | 100% working :D best support thanks! Checking data...OK Platform: LG Qualcomm Selected port: COM17 Selected model: D850 Reading info...OK Mode: Normal Model ID: LG-D850 Firmware compiled date: May 21 2014 Firmware compiled time: 02:00:00 Firmware released date: Jun 20 2014 Firmware released time: 09:52:24 SW Version: MPSS.DI.2.0.1.c1.13-00009-M8974AAAAANPZM-1 IMEI: 014065-00-252896-3 SPC: 000000 Fixing IMEI... New IMEI: 014065-00-256734-2 Skip Read/Write QCN Switching to Download mode...OK Initializing flash...OK Reading partition...OK Reading security area...OK Backup saved to "D850_014065002528963_30-04-2015_11-50-29.SEC" Writing security area...OK Switching to Normal mode... Found model LG-D850 at port COM11 IMEI successfully fixed! To complete the operation, please make Factory Reset (Go to "Settings" -> "General" -> "Backup & reset" -> "Factory data reset", press "Reset phone" and "Erase everything" buttons). |
