07-02-2015, 09:54 | #2 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,411 | Hello. Please reconnect phone's battery, then connect the phone directly to PC via P999 cable (with 910kOm resistor) and check what devices appear in PC device manager, and what appears on phone's screen. |
07-02-2015, 10:32 | #3 (permalink) | |
No Life Poster Join Date: Oct 2007
Member: 608370 Status: Offline Thanks Meter: 89 | Quote:
thanks for response detection is done but flashing is failed............... Welcome to Octoplus/Octopus Box LG Software version 1.9.9 -------------------------------------------------------------------------------- Platform: LG Qualcomm Selected port: COM39 Selected model: D170 Reading info... Mode: Emergency Initializing flash...OK SW version: LGD170AT-00-V10a-AME-XX-MAR-05-2014+0 LAF Version: 1.0 Product ID: CB46S140913006822 IMEI: 352875-06-486913-3 Target operator: GLOBAL Hardware: rev_10 -------------------------------------------------------------------------------- Checking data...OK Platform: LG Qualcomm Selected port: COM39 Selected model: D170 Reading info... Model ID: LG-D170 IMEI: 000000-00-000000-0 Android version: 4.4.2 Battery level: 74% Mode: Emergency Initializing flash...OK SW version: LGD170AT-00-V10a-AME-XX-MAR-05-2014+0 LAF Version: 1.0 Product ID: CB46S140913006822 IMEI: 352875-06-486913-3 Target operator: GLOBAL Hardware: rev_10 Opening "d17010b_00.oct"...OK Setting options...OK Reading partition...OK Formating USERDATA...OK Writing PrimaryGPT...OK Writing modem...OK Writing sbl1...OK Writing rpm...OK Writing tz...OK Writing sdi...OK Writing aboot...OK Writing rpmb...OK Writing tzb...OK Writing abootb...OK Writing persist...OK Writing laf...OK Writing boot...OK Writing recovery...OK Writing factory...OK Writing sbl1b...OK Writing cust...OK Writing system...OK Writing BackupGPT...OK Reading partition...Failed! Error code: ZXLCALSZXC | |
07-04-2015, 11:43 | #8 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,411 | If phone turns on only with P999, then your phone has problems with powering. This may be caused by damaged battery (try to use another battery) or by HW problem. |
