11-23-2016, 21:01 | #1 (permalink) |
No Life Poster Join Date: Oct 2009 Location: GRAN ALACANT SPAIN
Member: 1147852 Status: Offline Thanks Meter: 587 | Lg 2.5.1 error in interface i WANTED TO FLASH AN LG P700 BUT SOFTWARE INTERFACE IS INCOMPLETE CAN T CLICK THE 3 POINTS TO CHOOSE FLASH FILE. PLZ CHECK AND GIVE SOLUTION. TO LET YOU KNOW THAT I WAS HAVING THIS ERROR IN OLD PREVIOUS VERSIONS BUT WAS SOLVED AFTER UPDATE. BUT NOW ERROR IS BACK. BEST REGARDS PUNTO-MOVIL |
11-24-2016, 08:04 | #2 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,407 | Hello. Please, check your Monitor resolution and check your Screen resolution option in Windows try yo change it to another one, if problem still remain try to re-install drivers for graphic card. |
11-24-2016, 10:14 | #3 (permalink) |
Member: 1147852 Status: Offline Thanks Meter: 587 | there is no relation between resolution and this error. simply because the previous version was working fine with the same settings. i was having this same issue in older versions but it was solved by itself after some update. in all cases i changed resolution but still the same problem. |
11-24-2016, 10:25 | #4 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,407 | Please, re-install Software, if problem still remain, check monitor resolution and screen resolution in Display settings, try to set up another resolution manually. Also read this from thread Octoplus Fix error |
11-27-2016, 19:00 | #5 (permalink) |
Member: 1147852 Status: Offline Thanks Meter: 587 | the fix you provided solved the problem. the software was working just fien with 125% of magnifying option but not worked with latest update. i have a 23inch screen and icons are small with 100% that s why i use 125%. in all cases thanks for your help. Best Regards. Punto-Movil |
11-28-2016, 08:38 | #6 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,407 | @Punto-Móvil Hello. If You still have problem with Software, download and install test Software version form the Support Area (LG/TEST SOFTWARE/) then check Software again. |
