04-29-2016, 05:32 | #3 (permalink) |
Insane Poster Join Date: Feb 2016
Member: 2527617 Status: Offline Sonork: 51214 Thanks Meter: 3 | Welcome to Octoplus/Octopus Box LG Software version 2.2.7 -------------------------------------------------------------------------------- Platform: LG Qualcomm Selected port: COM111 Selected model: D801 Reading info... Model ID: Mode: Normal Firmware compiled date: Firmware compiled time: Firmware released date: Firmware released time: SW Version: Performed by 2.2.7 software version. -------------------------------------------------------------------------------- Checking data...OK Platform: LG Qualcomm Selected port: COM111 Selected model: D801 Reading info... Could not detect mode! Performed by 2.2.7 software version. -------------------------------------------------------------------------------- Checking data...OK Platform: LG Qualcomm Selected port: COM111 Selected model: D801 Reading info... Mode: Normal Firmware compiled date: Firmware compiled time: Firmware released date: Firmware released time: SW Version: Fixing IMEI... New IMEI: 354456-45-678645-4 Skip Read/Write QCN Do you want to create security backup? Switching to Download mode...Failed! Please perform the following steps: 1. Disconnect cable 2. Put phone into download mode manually (Power phone OFF, press and hold "Vol+" button and connect the cable (or P990 cable)) 3. Connect cable and press "Ok" button. Initializing flash...OK Reading partition...OK Reading security area...OK Backup saved to "D801_Bad_29-04-2016_21-12-45.SEC" Switching to Normal mode... Found model at port COM111 Writing security area...Failed! Performed by 2.2.7 software version. -------------------------------------------------------------------------------- Checking data...OK Platform: LG Qualcomm Selected port: COM111 Selected model: D801 Reading info... Model ID: Mode: Normal Firmware compiled date: Firmware compiled time: Firmware released date: Firmware released time: Switching to Download mode...Failed! Please perform the following steps: 1. Disconnect cable 2. Put phone into download mode manually (Power phone OFF, press and hold "Vol+" button and connect the cable (or P990 cable)) 3. Connect cable and press "Ok" button. Initializing flash...OK Reading partition...OK Reading security area...OK Backup saved to "D801_Bad_29-04-2016_21-23-12.SEC" Writing security area...OK Rebooting phone... Performed by 2.2.7 software version. -------------------------------------------------------------------------------- Checking data...OK Platform: LG Qualcomm Selected port: COM111 Selected model: D801 Reading info... Model ID: LG-D801 IMEI: 000000-00-000000-0 Android version: 4.4.2 Battery level: 35% Mode: Normal Firmware compiled date: Jan 03 2014 Firmware compiled time: 14:00:00 Firmware released date: Apr 16 2014 Firmware released time: 13:53:28 SW Version: M8974A-AAAANAZM-1.0.190082 SPC: 000000 Fixing IMEI... New IMEI: 354456-45-678645-4 Skip Read/Write QCN Do you want to create security backup? Writing security area...OK Switching to Normal mode... Found model D801_VTR* ÿh°‘ at port COM111 IMEI successfully fixed! To complete the operation, please make Factory Reset (Go to "Settings" -> "General" -> "Backup & reset" -> "Factory data reset", press "Reset phone" and "Erase everything" buttons). Performed by 2.2.7 software version. |
04-29-2016, 08:44 | #4 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,412 | Please, make sure that You perform these steps: To complete the operation, please make Factory Reset (Go to "Settings" -> "General" -> "Backup & reset" -> "Factory data reset", press "Reset phone" and "Erase everything" buttons). after Repair IMEI operation is complete, then check imei. |
