06-20-2017, 20:56 | #1 (permalink) |
Freak Poster Join Date: Jul 2016 Location: U.S.A
Member: 2604559 Status: Offline Sonork: Ventaslaredo Thanks Meter: 131 | Lg aristo metropcs frp done.! By octoplus lg Platform: LG Qualcomm Selected port: COM82 Selected model: MS210 Please, put the phone into download mode manually (Power phone OFF (reconnect battery), press and hold "Vol+" button and connect the cable (or P999 cable)). Reading info... Mode: Emergency Initializing flash...OK SW version: LGMS210AT-02-V10f-310-160-DEC-17-2016-ARB00+2 Android version: 7.0 LAF Version: 1.1 Product ID: CD23S170107002831 IMEI: 353662-08-44xxx-xx Target operator: MPCS Hardware: rev_10 Reset FRP operation for MS210 will delete all user data on the phone (contacts, pictures and others)! Do You want to continue? Reading partitions...OK Resetting FRP Lock... Writing loader...OK Writing userdata...OK Formating encrypt...OK Restoring loader...OK Resetting FRP lock successfully completed! Rebooting phone... To complete the operation, please make Factory Reset (Go to "Settings" -> "General" -> "Backup & reset" -> "Factory data reset", press "Reset phone" and "Erase everything" buttons). Performed by 2.6.8 Software version. If u think this is a good post. push tnks botoom to continue uploadin more useful post. tnks.// if u need help , PM. Last edited by Octopus box; 06-21-2017 at 06:39. |
The Following 2 Users Say Thank You to ventaslaredo For This Useful Post: |
07-10-2017, 20:37 | #2 (permalink) |
Junior Member Join Date: Dec 2016
Member: 2658627 Status: Offline Thanks Meter: 1 | You will likely need to downgrade to firmware F I was on H when i got the phone. I tried the FRP reset and the phone ended up being stuck in download mode. I then found the H firmware and flashed it with that and restored the phone, but FRP was still locked. I then downgraded to F and was successful. Once I did that I was able to use Octoplus FRP reset with no problems. Thank you Team Octoplus! |
The Following User Says Thank You to technologyrep For This Useful Post: |
