03-21-2015, 17:37 | #1 (permalink) |
No Life Poster Join Date: Jan 2014 Location: africa mali
Member: 2098907 Status: Offline Thanks Meter: 154 | Lg c360 flash fail -------------------------------------------------------------------------------- Platform: LG MTK Selected port: COM7 Selected baudrate: 921600 Selected model: C360 Please, disconnect battery and connect cable...OK Phone found. Setting power state...OK Sending loader...OK Synchronizing with loader...OK Detecting NOR flash chip...OK Detecting NAND flash chip...OK Reading info...OK Checking security...OK -------------------------------------------------------------------------------- IMEI: 358331-04-199224-6 Bluetooth address: F8:0C:F3:30:16:0A NAND flash chip: Hynix NAND size: 256 Mb NAND page size: 2048 b NAND spare size: 64 b NAND pages per block: 64 -------------------------------------------------------------------------------- Opening "LGC360AT-00-V10a-234-XXX-JUL-17-2011+0.oct"...OK Checking boot...OK Writing boot...OK Writing extended boot...OK Prepairing firmware...OK Writing code...OK Writing filesystem... Error code: BE4 Block #04CB Error code: BE4 Block #04CD Error code: BE4 Block #04CF Error code: BE4 Block #04DA Error code: BE4 Block #04DC Error code: BE4 Block #04DD Error code: BE4 Block #04E5 Error code: BE4 Block #04F1 Error code: BE4 Block #04F7Failed! -------------------------------------------------------------------------------- Platform: LG MTK Selected port: COM7 Selected baudrate: 921600 Selected model: C360 Please, disconnect battery and connect cable...OK Phone found. Setting power state...OK Sending loader...OK Synchronizing with loader...OK Detecting NOR flash chip...OK Detecting NAND flash chip...OK Reading info...OK Checking security...OK -------------------------------------------------------------------------------- IMEI: 358331-04-199224-6 Bluetooth address: F8:0C:F3:30:16:0A NAND flash chip: Hynix NAND size: 256 Mb NAND page size: 2048 b NAND spare size: 64 b NAND pages per block: 64 -------------------------------------------------------------------------------- Opening "LGC360AT-00-V10a-234-XXX-JUL-17-2011+0.oct"...OK Checking boot...OK Writing boot...OK Writing extended boot...OK Prepairing firmware...OK Writing code...OK Writing filesystem... Error code: BE4 Block #04CB Error code: BE4 Block #04CD Error code: BE4 Block #04CF Error code: BE4 Block #04DA Error code: BE4 Block #04DC Error code: BE4 Block #04DD Error code: BE4 Block #04E5 Error code: BE4 Block #04F1 Error code: BE4 Block #04F7Failed! |
03-21-2015, 17:46 | #2 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,412 | Hello. What is exact state of the phone? Why did You decide to reflash it? Install latest Software version (Software), repeat "Write Firmware" operation and post here full Software log. |
03-22-2015, 09:18 | #4 (permalink) | |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,412 | This errors: Quote:
Anyway, snstall latest Software version (Software), and try to write firmwares other firmwares from the Support Area. If the problem is the same - check HW. | |
