10-20-2016, 07:45 | #1 (permalink) |
No Life Poster Join Date: Oct 2007 Location: chennai Age: 38
Member: 616909 Status: Offline Sonork: 1672125 Thanks Meter: 648 | lg d415 servive provider lock (connection help) in octopus Note: To connect the phone in Normal Mode, do the next: Go to "Settings -> PC connection -> USB connection type -> Select USB Connection method" and select "LG Software" ("PC Software"). not have option in mob |
10-20-2016, 08:02 | #2 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,412 | Hello. Please, enable USB Debugging mode ON in your phone, then connect phone via USB cable and select "Charge only" type of connection, then try to perform Read info operation, post here Software log. |
10-20-2016, 14:31 | #3 (permalink) | |
Member: 616909 Status: Offline Sonork: 1672125 Thanks Meter: 648 | Quote:
Platform: LG Qualcomm Selected port: COM223 Selected model: D415 Reading info... Model ID: LG-D415 IMEI: 014330-00-532496-2 Android version: 5.0.2 Battery level: 60% SW Version: D41520c Mode: Normal Firmware compiled date: Dec 30 2014 Firmware compiled time: 03:00:00 Firmware released date: Aug 14 2015 Firmware released time: 17:39:59 SW Version: M8626A-AAAANAZM-1.0.6063 IMEI: 014330-00-532496-2 SPC: 000000 Unlocking... Reading QCN... Send SPC...OK Reading Mobile Property...OK Reading Feature Mask...OK Reading Roaming List 0...OK Reading NV_Numbered Items...OK Reading NV_Numbered SIM1 Items...OK Reading NV_Numbered SIM2 Items...OK Reading NV Items...OK Reading EFS...OK Reading Provisioning Items...OK Reading QCN done! Backup saved to "D415_014330005324962_20-10-2016_18-47-21.qcn" Do you want to create security backup? Switching to Download mode...OK Initializing flash...OK Reading partitions...OK Reading security area...OK Backup saved to "D415_014330005324962_20-10-2016_18-56-40.SEC" Switching to Normal mode... Trying to enable Diagnostics ports... Initializing ADB...OK Waiting for phone...OK Diagnostics ports are enbled! Switching to Serial Port... Failed! Trying to enable Diagnostics ports... Checking root access... Phone is not rooted. Please, root the phone manually! Please perform the following steps: 1. Disconnect cable 2. Put phone into Normal mode manually 3. Press "Ok" button Trying to enable Diagnostics ports... Failed! Writing security area... Performed by 2.4.6 Software version. | |
10-20-2016, 14:37 | #4 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,412 | To connect the phone in Normal Mode, do one of the following: Enable "USB Debugging" mode; Type 277634#*# or *#546368#*810# or 3845*#415#, go to "Port Check Test" (or "SVC Menu -> Port Check Test") and switch "Port Check Test" to "Enabled". |
