06-13-2017, 10:18 | #1 (permalink) |
No Life Poster Join Date: Oct 2006 Location: yaoundé (av kennedy)
Member: 361348 Status: Offline Thanks Meter: 635 | LG D722J repair imei Welcome to Octoplus/Octopus Box LG Software version 2.6.8 -------------------------------------------------------------------------------- Checking data...OK Platform: LG Qualcomm Selected port: COM472 Selected model: D722J Reading info... Model ID: LG-D722J IMEI: XXXXXXXXXXXXXX Android version: 4.4.2 Battery level: 100% SW Version: D722J10e Mode: Normal Fixing IMEI... New IMEI: XXXXXXXXXXXXXX Reading QCN... Send SPC...OK Reading Mobile Property...OK Reading Feature Mask...OK Reading Roaming List 0...Failed! Reading NV_Numbered Items... IN OCTOPUS server i just see only d722 firmware but not D722J ISt same firmware? |
The Following 2 Users Say Thank You to hippolyte85 For This Useful Post: |
06-13-2017, 11:50 | #2 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,411 | Hello. Please, try to repeat Repair IMEI operation with "Skip Read /Write QCN during operation" option, then post here full Software log. The D722 and D722J are different phone models, firmwares may not be compatible. Also, please try to perform next steps, before Repair IMEI operation: To connect the phone in Normal Mode, do the next: Go to "Settings -> Networks -> Tethering & Networks -> Turn on "USB tethering". |
06-15-2017, 09:58 | #3 (permalink) |
Member: 361348 Status: Offline Thanks Meter: 635 | thx after "Skip Read /Write QCN during operation" solved first probleme but now asked me switching to normal mode : i av tried many setting but still not ok plz any issu for me? Welcome to Octoplus/Octopus Box LG Software version 2.6.8 -------------------------------------------------------------------------------- Checking data...OK Platform: LG Qualcomm Selected port: COM473 Selected model: D722J Reading info... Model ID: LG-D722J IMEI: XXXXXXXXXXXXXX Android version: 4.4.2 Battery level: 100% SW Version: D722J10e Mode: Normal Fixing IMEI... New IMEI: XXXXXXXXXXXXXX Skip Read/Write QCN Do you want to create security backup? Switching to Download mode...OK Initializing flash...OK Reading partitions...OK Reading security area...OK Backup saved to "D722J_XXXXXXXXXXXXX_15-06-2017_10-47-11.SEC" Switching to Normal mode... Please perform the following steps: 1. Disconnect cable 2. Put phone into Normal mode manually 3. Press "Ok" buttonFailed! Performed by 2.6.8 Software version. |
06-15-2017, 11:56 | #4 (permalink) | |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,411 | Quote:
Important: To connect the phone in Normal Mode, do the next: Go to "Settings -> Networks -> Tethering & Networks -> Turn on "USB tethering". Last edited by Octopus box; 06-15-2017 at 12:24. | |
06-15-2017, 12:46 | #5 (permalink) |
Member: 361348 Status: Offline Thanks Meter: 635 | after ask to switch in normal mode nothing happen after few times say Please perform the following steps: 1. Disconnect cable 2. Put phone into Normal mode manually 3. Press "Ok" buttonFailed! https://www.4shared.com/photo/PGJbNd...-00-01-21.html |
The Following User Says Thank You to hippolyte85 For This Useful Post: |
06-15-2017, 13:02 | #6 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,411 | Important: To connect the phone in Normal Mode, do the next: Go to "Settings -> Networks -> Tethering & Networks -> Turn on "USB tethering". |
06-15-2017, 13:51 | #7 (permalink) |
Member: 361348 Status: Offline Thanks Meter: 635 | thx bro may be this phone av some probleme bcoz on your first reply u tell me how to connect this phone ; i done same but still not ok i choosse first tethering mode after charging mode and mtp mode to see without success |
06-15-2017, 15:29 | #8 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,411 | You can try to connect your phone to another clean PC with installed drivers and Software, after repeat operation there. |
The Following 2 Users Say Thank You to Octopus box For This Useful Post: |
