07-29-2015, 06:24 | #1 (permalink) |
No Life Poster Join Date: Apr 2013 Location: Calgary
Member: 1918024 Status: Offline Sonork: 100.1638888 Thanks Meter: 45 | LG-D722K still unlock after unlock following the instruction step by step factory reset after unlock dial 2945#*722# get the message "the phone is permanently lock and can not be unlocked" LG-D722K on android 5.0.2 software version V20a-GLOBAL-YT try P999 and normal cable the result is same please check my log here. Thanks Welcome to Octoplus/Octopus Box LG Software version 2.0.2 -------------------------------------------------------------------------------- Platform: LG Qualcomm Selected port: COM41 Selected model: D722K Reading info... Model ID: LG-D722k IMEI: 355537-06-001040-4 Android version: 5.0.2 Battery level: 94% Mode: Normal -------------------------------------------------------------------------------- Checking data...OK Platform: LG Qualcomm Selected port: COM41 Selected model: D722K Reading info... Model ID: LG-D722k IMEI: 355537-06-001040-4 Android version: 5.0.2 Battery level: 96% Trying to enable Diagnostics ports... Initializing ADB...OK ADB Server was found. Trying to kill... Waiting for phone...OK Diagnostics ports are enbled! Switching to Serial Port... Found model DAAAANAZ* ÿj| at port COM41 Unlocking... Skip Read/Write QCN Switching to Download mode...OK Initializing flash...OK Reading partition...OK Reading security area...OK Backup saved to "D722K_355537060010404_28-07-2015_22-41-52.SEC" Writing security area...OK Switching to Normal mode... Found model DAAAANAZ* ÿj| at port COM41 Phone successfully unlocked! To complete the operation, please make Factory Reset (Go to "Settings" -> "General" -> "Backup & reset" -> "Factory data reset", press "Reset phone" and "Erase everything" buttons). -------------------------------------------------------------------------------- |
07-30-2015, 16:18 | #3 (permalink) | |
Member: 1918024 Status: Offline Sonork: 100.1638888 Thanks Meter: 45 | Quote:
the phone show invalid sim It means the phone still lock with the original carrier. I saw you have LG-D722 firmware in support area, can I flash the firmware to this phone (LG-D722K) ? Maybe downgrade the android version can fix the problem? | |
07-30-2015, 16:28 | #4 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,413 | Please remove SD and SIM cards from phone, connect powered-on phone to PC with P999 cable and repeat "Unlock" operation with latest Software version. Post here results and full Software log of the operation. It is not recommended to write firmwares designed for another model. You can try to do it only on your own risk. |
08-01-2015, 05:27 | #5 (permalink) |
Member: 1918024 Status: Offline Sonork: 100.1638888 Thanks Meter: 45 | Follow the instruction take out sim and SD card use P999 cable when unlock done factory reset the phone insert unacceptable sim still show invalid sim the log is perfect just can't real unlock the D722K Here is the log -------------------------------------------------------------------------------- Platform: LG Qualcomm Selected port: COM41 Selected model: D722K Reading info... Model ID: LG-D722k IMEI: 355537-06-001040-4 Android version: 5.0.2 Battery level: 80% Mode: Normal Firmware compiled date: Feb 26 2015 Firmware compiled time: 22:00:00 Firmware released date: Apr 13 2015 Firmware released time: 11:54:20 SW Version: MPSS.DI.2.0.1.c1.15-00044-M8926DAAAANAZM-1 IMEI: 355537-06-001040-4 SPC: 000000 -------------------------------------------------------------------------------- Checking data...OK Platform: LG Qualcomm Selected port: COM41 Selected model: D722K Reading info... Model ID: LG-D722k IMEI: 355537-06-001040-4 Android version: 5.0.2 Battery level: 80% Mode: Normal Firmware compiled date: Feb 26 2015 Firmware compiled time: 22:00:00 Firmware released date: Apr 13 2015 Firmware released time: 11:54:20 SW Version: MPSS.DI.2.0.1.c1.15-00044-M8926DAAAANAZM-1 IMEI: 355537-06-001040-4 SPC: 000000 Unlocking... Reading QCN... Send SPC...OK Reading Mobile Property...OK Reading Feature Mask...OK Reading Roaming List 0...OK Reading NV_Numbered Items...OK Reading NV_Numbered SIM1 Items...OK Reading NV_Numbered SIM2 Items...OK Reading NV Items...OK Reading EFS...OK Reading Provisioning Items...OK Reading QCN done! Backup saved to "D722K_355537060010404_31-07-2015_21-57- 10.qcn" Switching to Download mode...OK Initializing flash...OK Reading partition...OK Reading security area...OK Backup saved to "D722K_355537060010404_31-07-2015_22-08- 09.SEC" Writing security area...OK Switching to Normal mode... Found model DAAAANAZ* ÿj| at port COM107 Send SPC...OK Writing QCN... Writing NV_Numbered Items...OK Writing NV_Numbered SIM1 Items...OK Writing NV_Numbered SIM2 Items...OK Writing QCN done! Phone successfully unlocked! To complete the operation, please make Factory Reset (Go to "Settings" -> "General" -> "Backup & reset" -> "Factory data reset", press "Reset phone" and "Erase everything" buttons). still lock after unlock using Version 2.0.3 -------------------------------------------------------------------------------- Welcome to Octoplus/Octopus Box LG Software version 2.0.3 -------------------------------------------------------------------------------- Platform: LG Qualcomm Selected port: COM41 Selected model: D722K Reading info... Model ID: LG-D722k IMEI: 000000-00-000000-0 Android version: 5.0.2 Battery level: 84% Mode: Normal Firmware compiled date: Feb 26 2015 Firmware compiled time: 22:00:00 Firmware released date: Apr 13 2015 Firmware released time: 11:54:20 SW Version: MPSS.DI.2.0.1.c1.15-00044-M8926DAAAANAZM-1 SPC: 000000 -------------------------------------------------------------------------------- Checking data...OK Platform: LG Qualcomm Selected port: COM41 Selected model: D722K Reading info... Model ID: LG-D722k IMEI: 000000-00-000000-0 Android version: 5.0.2 Battery level: 84% Mode: Normal Firmware compiled date: Feb 26 2015 Firmware compiled time: 22:00:00 Firmware released date: Apr 13 2015 Firmware released time: 11:54:20 SW Version: MPSS.DI.2.0.1.c1.15-00044-M8926DAAAANAZM-1 SPC: 000000 Unlocking... Skip Read/Write QCN Switching to Download mode...OK Initializing flash...OK Reading partition...OK Reading security area...OK Backup saved to "D722K_000000000000000_08-08-2015_09-15-46.SEC" Writing security area...OK Switching to Normal mode... Found model DAAAANAZ* ÿj| at port COM41 Phone successfully unlocked! To complete the operation, please make Factory Reset (Go to "Settings" -> "General" -> "Backup & reset" -> "Factory data reset", press "Reset phone" and "Erase everything" buttons). -------------------------------------------------------------------------------- Platform: LG Qualcomm Selected port: COM41 Selected model: D722K Reading info... Model ID: LG-D722k IMEI: 000000-00-000000-0 Android version: 5.0.2 Battery level: 84% Mode: Normal Firmware compiled date: Feb 26 2015 Firmware compiled time: 22:00:00 Firmware released date: Apr 13 2015 Firmware released time: 11:54:20 SW Version: MPSS.DI.2.0.1.c1.15-00044-M8926DAAAANAZM-1 IMEI: 000000-00-000000-0 SPC: 000000 Selecting input file...OK Source file: "D722K_355537060010404_28-07-2015_18-37-40.qcn" Do You want to write IMEI from QCN file or to leave current IMEI? Write IMEI from QCN file! Send SPC...OK Writing QCN... The ESN in QCN file and the phone do not match. Do you still want to write this file? Writing EFS...OK Writing NV_Numbered Items...OK Writing NV_Numbered SIM1 Items...OK Writing NV_Numbered SIM2 Items...OK Writing Provisioning Items...OK Writing QCN done! -------------------------------------------------------------------------------- Platform: LG Qualcomm Selected port: COM41 Selected model: D722K Reading info... Model ID: LG-D722k IMEI: 355537-06-001040-4 Android version: 5.0.2 Battery level: 85% Mode: Normal --------------------------------------------- Last edited by Octopus box; 08-10-2015 at 09:28. |
