Go Back   GSM-Forum > Product Support Sections > Hard/Software Products (official support) > Octopus/Octoplus > Octopus LG/Octoplus LG
Old 12-20-2013, 10:14   #1 (permalink)
Member: 362622
Thanks Meter: 43
lg d802 adb ???? [Solved]
hi dears
i have 3 units to unlock but there a mistake in unlocking i can t have adb mode in pc
Welcome to Octoplus/Octopus Box LG Software version 1.4.0
Platform: LG Qualcomm
Selected port: COM139
Selected model: D802
Reading info...OK
Mode: Normal
Model ID: AAAAANAZ: ÿh°œ
Firmware compiled date: Aug 05 2013
Firmware compiled time: 17:00:00
Firmware released date: Aug 20 2013
Firmware released time: 21:52:53
SW Version: M8974A-AAAANAZM-1.0.190036
IMEI: 357246-05-xxxxxxx
Unlocking...
Initializing ADB...OK
Waiting for phone...Failed!
Please, reconnect phone, enable USB debugging, and try again.
To enable USB debugging, please perform the following steps:
1. Disconnect cable
2. Install LG Android ADB drivers
3. Go to "Settings" -> "About phone" -> "Software information"
4. Click on Build number 5 times3. Enable "Settings" -> "Developer
options" -> "USB debugging" option
4. Connect cable and check if ADB interface has appeared in PC Device
Manager.
i follow instructions i have message that already in debug usb
any help please ?
thanks
Old 12-20-2013, 10:20   #2 (permalink)
Octopus box's Avatar
Member: 1146942
Sonork: 100.1587278
Thanks Meter: 27,405
Hello.
Please look here: http://forum.gsmhosting.com/vbb/f799...76/index2.html.
The Following User Says Thank You to Octopus box For This Useful Post:
Old 12-21-2013, 03:26   #3 (permalink)
Registered User
Member: 1290061
Thanks Meter: 61
Is possible unlock the Sprint Variant ?
Old 12-21-2013, 09:14   #4 (permalink)
Member: 1146942
Sonork: 100.1587278
@ george241312
Hello.
Yes You can unlock such device.
Old 12-21-2013, 16:39   #5 (permalink)
agentot's Avatar
Member: 107027
Thanks Meter: 269
d802 imei repair issue
imei repair seems to work but phone have still same original imei
Selected port: COM14
Reading info...OK
Mode: Normal
Model ID: AAAAANAZ: ÿh°í
Firmware released date: Nov 23 2013
Firmware released time: 15:54:37
IMEI: 357246-05-xxxxxx-3
Reading info...OK
Mode: Normal
Fixing IMEI...
New IMEI: 357246-05-691560-4
Checking root access...
Device is already rooted.
Reading NVM...OK
Backup saved to "D802_357246055xxxxxx_21-12-2013_15-53-45.NVM"
Reading partition...OK
Reading security area...OK
Backup saved to "D802_357246055xxxxxx_21-12-2013_15-58-00.SEC"
Analyzing security...OK
Checking data...OK
Repairing NVM...OK
NVM succesfully repaired.
IMEI successfully fixed!
Please, reboot the phone manually.
any advice?
br
ss
The Following User Says Thank You to agentot For This Useful Post:
Old 12-21-2013, 16:46   #6 (permalink)
Member: 1146942
Sonork: 100.1587278
To Repair IMEI please do the next:
1. Disconnect all other devices from PC.
2. Install correct ADB drivers: http://octopusbox.com/files/drivers/...dADBDriver.exe.
3. Install the latest Software version: https://mega.co.nz/#!3pgwCAxK!dMbdQ1...uHbm_Erb9-XA8k.
4. Autoroot operation is included in the Software for all tested firmwares. If the phone will not be rooted by the Software automaticly, you need to Root device manually by using this root exploit: https://mega.co.nz/#!PlpzXISR!TBLc5k..._iw9R5wFQTDEKo.
5. Perform Repair IMEI operation, accept all requests which appear in phone's screen during of performing operation.
Old 12-21-2013, 17:28   #7 (permalink)
agentot's Avatar
Member: 107027
Thanks Meter: 269
solved
please add this trick
even phone is already unlocked
1st unlock
2nd repair imei
br
ss
Old 12-25-2013, 16:52   #8 (permalink)
Member: 1146942
Sonork: 100.1587278
Thanks for your report. But we have a small question - have You rebooted the device manually after of performing "Repair IMEI" operation?:
In order to apply IMEI changing, You need to reboot device manually.
Old 03-19-2014, 11:15   #9 (permalink)
GTECH MOBILE's Avatar
Member: 1343470
Thanks Meter: 64
plzzz share here... windows xp 32bit adb driver .........
Old 03-19-2014, 11:24   #10 (permalink)
Member: 1146942
Sonork: 100.1587278
All drivers You can find here: Octopus Box Downloads - Software, Drivers, Manual.
http://octopusbox.com/files/drivers/...dADBDriver.exe,
https://mega.co.nz/#!OlxHUKzC!j5qLEU..._sS4v0fK02kQUg.
Page generated in 0.21091 seconds with 8 queries
